momo
January 23, 2023, 4:35am
1
Hey guys I’m running EndeavourOS gnome 43 in wayland at 3840x2160 resolution @ 60 Hz with 200% scaling.
For some reason the mouse cursor Icon gets stuck at random Icon for example in resizing mode. Any idea why this is happening ? I tried to install a different icon theme, but it didn’t make a difference.
Any help would be greatly appreciated.
Thanks
Is this a virtual machine?
momo
January 23, 2023, 6:27am
3
no Running it natively on my PC
zoli62
January 23, 2023, 9:00am
4
What is the default icon theme? Have you tried a reset?
momo
January 23, 2023, 5:28pm
5
its the default Adwaita theme. How do I reset it?
zoli62
January 23, 2023, 5:31pm
6
I meant to go back to the default theme, but you said you tried that and it didn’t help.
momo
January 23, 2023, 5:35pm
7
correct, not sure why its acting like that
Echoa
January 23, 2023, 6:13pm
8
This seems similar to this issue
Even if not the exactly same this is likely something with mutter, have you tried it without 200% scaling?
momo
January 23, 2023, 6:21pm
9
Thanks!, turning off the zoom fixed the issue. definitely a bug with wayland
Echoa
January 23, 2023, 6:29pm
10
it also happens in X11 under certain circumstances so its something to do with some sort of mutter bug in general
system
Closed
January 25, 2023, 6:29pm
11
