Cursed mutter issue
Hey guys,
I am using the budgie environment and am trying to upgrade via pacman -Syu, but mutter is stopping me from doing so…if its even there. Not really sure how to proceed from here.
resolving dependencies...
:: mutter and mutter43 are in conflict. Remove mutter43? [y/N] n
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
[jake@jake ~]$ sudo pacman -Rdd mutter
error: target not found: mutter
Try sudo pacman -Syu mutter43
If that doesn’t work, you will need to figure out what is pulling in mutter as a dependency and remove it before upgrading.
Do you also have gnome installed?
Yeah I did and Rdd’ing it resolved the issue, Strueth need to avoid gnome while trying to budgie around.
