Cups issue: printing not possible
FYI
bug report with solution
Since a few days I have an issue with printing. Apps in gnome which use the systems print dialog do not print anymore. The print dialog is hanging and I need to stop the apps to recover. That is true for apps like gimp, papers, eye of gnome, epiphany, etc. Not affected is libreoffice for example. There is no trace of any problem in the logs. cups is running fine.
Today I found the solution:
Packages cups and libcups 2.4.15-1 are the problem. On my system they were install 27. Nov. 2025
Downgrading cups and libcups to 2.4.14-1 is the solution.
I rebooted the computer after the downgrade and printing works again.
FYI
Issue has been reported to cups on github. Offending commit has been identified.
I assume we will see a new release shortly.
Thanks. Couldn’t print from Evolution email or anywhere else for that matter.
Issue is fixed with new
Version : 2:2.4.15-2
And the issue is indeed already resolved with latest cups package as far as i know, underlaying issue was a bit more complex, but i had the issue yesterday and while i was investigating it was already resolved with a new cups package.
So no need for any workaround from what i know. Simply update.
very early .. sad i was not reading this before. Would have protected me from the investigations, strange that I didn’t find the report. but was somehow obsessed with GTK printing.
Totally unrelated but intersting detail on Linux Printing:
Till Kamppeter:
noob question … how to downgrade ?
If it’s not installed, install downgrade. Run sudo downgrade packagename and pick your target from a list.
Thank you for the quick reply, how to put cups again same as sane for the scanner to work, before update it worked good now not anymore, and is there an command for if it works to stay like the same ?
for example telling the system to keep same versions … so my printer and scanner keep on working fine ? i downgrade 3 times to different versions and nothing works so waiting again for when to work now
thank you in advance and sorry for my noob repeating problem
i would suggest open a new thread give some more info about your printer and setup.
This thread is 3 month old. And your question is partly unrelated to the topic itself too.
