CS2 not launching
CS2 (counter strike) Does not launch. I am using the Flatpak version, it shows valve splash screen and after a few while, it exits.
I initially used the native version of Steam, but it did not work there too.
note that i am using my second drive which is ext4 formatted. My SSD does not have extra space to download the game.
CS2 Flatpak Log
[arefin@arefin-veriton-m4660g ~]$ flatpak run com.valvesoftware.Steam
INFO:root:https://github.com/flathub/com.valvesoftware.Steam/wiki
INFO:root:Will set XDG dirs prefix to /home/arefin/.var/app/com.valvesoftware.Steam
DEBUG:root:Checking input devices permissions
WARNING:root:Missing permissions for input devices
INFO:root:Overriding TZ to Asia/Dhaka
steam.sh[2]: Running Steam on org.freedesktop.platform 23.08 64-bit
steam.sh[2]: STEAM_RUNTIME is enabled automatically
setup.sh[69]: Steam runtime environment up-to-date!
steam.sh[2]: Steam client's requirements are satisfied
[2024-10-18 21:46:48] Startup - updater built Sep 17 2024 20:02:19
[2024-10-18 21:46:48] Startup - Steam Client launched with: '/home/arefin/.var/app/com.valvesoftware.Steam/.local/share/Steam/ubuntu12_32/steam' '-srt-logger-opened' '-no-cef-sandbox'
10/18 21:46:48 minidumps folder is set to /tmp/dumps
10/18 21:46:48 Init: Installing breakpad exception handler for appid(steam)/version(1726604483)/tid(135)
[2024-10-18 21:46:48] Loading cached metrics from disk (/home/arefin/.var/app/com.valvesoftware.Steam/.local/share/Steam/package/steam_client_metrics.bin)
[2024-10-18 21:46:48] Using the following download hosts for Public, Realm steamglobal
[2024-10-18 21:46:48] 1. https://client-update.fastly.steamstatic.com, /, Realm 'steamglobal', weight was 900, source = 'update_hosts_cached.vdf'
[2024-10-18 21:46:48] 2. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2024-10-18 21:46:48] 3. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'update_hosts_cached.vdf'
[2024-10-18 21:46:48] 4. https://client-update.steamstatic.com, /, Realm 'steamglobal', weight was 1, source = 'baked in'
[2024-10-18 21:46:48] Verifying installation...
[2024-10-18 21:46:48] Verification complete
UpdateUI: skip show logo
Steam logging initialized: directory: /home/arefin/.var/app/com.valvesoftware.Steam/.local/share/Steam/logs
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xead0a8f0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xead091c0
steamwebhelper.sh[153]: Using supervisor /home/arefin/.var/app/com.valvesoftware.Steam/.local/share/Steam/ubuntu12_32/steam-runtime/amd64/usr/bin/steam-runtime-supervisor
steamwebhelper.sh[153]: Starting steamwebhelper under bootstrap sniper steam runtime via /home/arefin/.var/app/com.valvesoftware.Steam/.local/share/Steam/ubuntu12_64/steam-runtime-sniper.sh
steamwebhelper.sh[153]: CEF sandbox already disabled
steamwebhelper.sh[153]: Starting steamwebhelper with Sniper steam runtime at /home/arefin/.var/app/com.valvesoftware.Steam/.local/share/Steam/ubuntu12_64/steam-runtime-sniper/_v2-entry-point
Steam Runtime Launch Service: starting steam-runtime-launcher-service
Steam Runtime Launch Service: steam-runtime-launcher-service is running pid 223
bus_name=com.steampowered.PressureVessel.LaunchAlongsideSteam
/bin/bash: /usr/lib/pressure-vessel/overrides/lib/x86_64-linux-gnu/libtinfo.so.6: no version information available (required by /bin/bash)
exec ./steamwebhelper -lang=en_US -cachedir=/home/arefin/.var/app/com.valvesoftware.Steam/.local/share/Steam/config/htmlcache -steampid=135 -buildid=1726604483 -steamid=0 -logdir=/home/arefin/.var/app/com.valvesoftware.Steam/.local/share/Steam/logs -uimode=7 -startcount=0 -userdatadir=/home/arefin/.var/app/com.valvesoftware.Steam/.local/share/Steam/config/cefdata -steamuniverse=Public -realm=Global -clientui=/home/arefin/.var/app/com.valvesoftware.Steam/.local/share/Steam/clientui -steampath=/home/arefin/.var/app/com.valvesoftware.Steam/.local/share/Steam/ubuntu12_32/steam -launcher=0 -no-restart-on-ui-mode-change --valve-enable-site-isolation --enable-smooth-scrolling --no-sandbox --password-store=basic --log-file=/home/arefin/.var/app/com.valvesoftware.Steam/.local/share/Steam/logs/cef_log.txt --disable-quick-menu --enable-features=PlatformHEVCDecoderSupport --disable-features=SpareRendererForSitePerProcess,DcheckIsFatal
BRefreshApplicationsInLibrary 1: 0ms
Desktop state changed: desktop: { pos:    0,   0 size: 1920,1080 } primary: { pos:    0,   0 size: 1920,1080 }
BuildCompleteAppOverviewChange: 125 apps
RegisterForAppOverview 1: 2ms
RegisterForAppOverview 2: 2ms
WARNING: discarding _NET_WM_PID 1433 as invalid for X11 window - use specialized XCB_X11_TO_PID function!
WARNING: discarding _NET_WM_PID 3530 as invalid for X11 window - use specialized XCB_X11_TO_PID function!
chdir "/mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive"
ERROR: ld.so: object '/home/arefin/.var/app/com.valvesoftware.Steam/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
ERROR: ld.so: object '/home/arefin/.var/app/com.valvesoftware.Steam/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
Adding process 548 for gameID 730
Adding process 549 for gameID 730
Adding process 550 for gameID 730
WARNING: discarding _NET_WM_PID 854 as invalid for X11 window - use specialized XCB_X11_TO_PID function!
pid 640 != 639, skipping destruction (fork without exec?)
basename: extra operand 'Offensive/game/cs2.sh'
Try 'basename --help' for more information.
pid 642 != 639, skipping destruction (fork without exec?)
Adding process 639 for gameID 730
Adding process 641 for gameID 730
Adding process 643 for gameID 730
Adding process 644 for gameID 730
Adding process 645 for gameID 730
Adding process 646 for gameID 730
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libengine2.so, got 0x5e10891ff130
Using breakpad crash handler
[S_API] SteamAPI_Init(): Loaded '/home/arefin/.var/app/com.valvesoftware.Steam/.local/share/Steam/linux64/steamclient.so' OK.
Setting breakpad minidump AppID = 730
Forcing breakpad minidump interfaces to load
Looking up breakpad interfaces from steamclient
Calling BreakpadMiniDumpSystemInit
10/18 21:47:54 minidumps folder is set to /tmp/dumps
10/18 21:47:54 Init: Installing breakpad exception handler for appid(730)/version(9267356)/tid(644)
SteamInternal_SetMinidumpSteamID:  Caching Steam ID:  76561199614944778 [API loaded yes]
SteamInternal_SetMinidumpSteamID:  Setting Steam ID:  76561199614944778
Setting breakpad minidump AppID = 2347771
Loaded libSDL3.so.0, got 0x5e1089325b80
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libtier0.so, got 0x5e10891de270
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libfilesystem_stdio.so, got 0x5e1089380aa0
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libinputsystem.so, got 0x5e108939d630
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/liblocalize.so, got 0x5e10893815f0
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/librendersystemvulkan.so, got 0x5e1089381d30
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libresourcesystem.so, got 0x5e1089383260
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libschemasystem.so, got 0x5e1089383b70
ATTENTION: default value of option radv_override_graphics_shader_version overridden by environment.
Fossilize INFO: Overriding serialization path: "/mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/shadercache/730/fozpipelinesv6/steamapprun_pipeline_cache".
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libmaterialsystem2.so, got 0x5e108b84eb20
Loaded libpangoft2-1.0.so, got (nil)
 failed to dlopen "libpangoft2-1.0.so" error=libpangoft2-1.0.so: cannot open shared object file: No such file or directory
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libpanorama_text_pango.so, got 0x5e108b891f00
Fontconfig warning: "/mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/csgo/panorama/fonts/fonts.conf", line 39: unknown element "fontpattern"
Fontconfig warning: "/mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/csgo/panorama/fonts/fonts.conf", line 40: unknown element "fontpattern"
Fontconfig warning: "/mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/csgo/panorama/fonts/fonts.conf", line 41: unknown element "fontpattern"
Fontconfig warning: "/mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/csgo/panorama/fonts/fonts.conf", line 42: unknown element "fontpattern"
Fontconfig warning: "/mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/csgo/panorama/fonts/fonts.conf", line 43: unknown element "fontpattern"
Fontconfig warning: "/mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/csgo/panorama/fonts/fonts.conf", line 86: saw string, expected range
Fontconfig warning: "/mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/csgo/panorama/fonts/../../../core/panorama/fonts/conf.d/41-repl-os-win.conf", line 148: Having multiple values in <test> isn't supported and may not work as expected
Fontconfig warning: "/mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/csgo/panorama/fonts/../../../core/panorama/fonts/conf.d/41-repl-os-win.conf", line 160: Having multiple values in <test> isn't supported and may not work as expected
Loaded libfreetype.so.6, got 0x5e108b892f90
Loaded libfontconfig.so.1, got 0x5e108b893480
GameOverlay: started '/home/arefin/.var/app/com.valvesoftware.Steam/.local/share/Steam/ubuntu12_32/gameoverlayui' (pid 666) for game process 644
10/18 21:47:57 minidumps folder is set to /tmp/dumps
10/18 21:47:57 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(20240917200232)/tid(666)
10/18 21:47:57 Init: Installing breakpad exception handler for appid(gameoverlayui)/version(1.0)/tid(666)
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libmeshsystem.so, got 0x5e108b94e640
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libworldrenderer.so, got 0x5e108b9619b0
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libpulse_system.so, got 0x5e108b973b30
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libvscript.so, got 0x5e108b987e30
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libnetworksystem.so, got 0x5e108b999fa0
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libanimationsystem.so, got 0x5e108b9ae640
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libvphysics2.so, got 0x5e108b9c49c0
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libsoundsystem.so, got 0x5e108b9d7790
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libsteamaudio.so, got 0x5e108b9edf30
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libscenesystem.so, got 0x5e108ba01d60
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libparticles.so, got 0x5e108ba17ff0
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libpanoramauiclient.so, got 0x5e108ba2b4f0
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libv8system.so, got 0x5e108ba54400
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libpanorama.so, got 0x5e108ba396b0
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/librenderdoc.so, got (nil)
 failed to dlopen "/mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/librenderdoc.so" error=/mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/librenderdoc.so: cannot open shared object file: No such file or directory
Loaded librenderdoc.so, got (nil)
 failed to dlopen "librenderdoc.so" error=librenderdoc.so: cannot open shared object file: No such file or directory
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/csgo/bin/linuxsteamrt64/libserver.so, got 0x5e108cb961c0
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/csgo/bin/linuxsteamrt64/libclient.so, got 0x5e108cbc62e0
Loaded libmpg123.so.0, got 0x5e108cc04e00
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libcairo.so, got 0x5e108d14b0e0
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/csgo/bin/linuxsteamrt64/libhost.so, got 0x5e108d241f60
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/bin/linuxsteamrt64/libscenefilecache.so, got 0x5e108d2557b0
Loaded /mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/csgo/bin/linuxsteamrt64/libmatchmaking.so, got 0x5e108d267b40
crash_20241018214827_2.dmp[687]: Uploading dump (out-of-process)
/tmp/dumps/crash_20241018214827_2.dmp
Adding process 686 for gameID 730
crash_20241018214827_2.dmp[687]: Finished uploading minidump (out-of-process): success = yes
crash_20241018214827_2.dmp[687]: response: Discarded=1
crash_20241018214827_2.dmp[687]: file ''/tmp/dumps/crash_20241018214827_2.dmp'', upload yes: ''Discarded=1''
pid 687 != 686, skipping destruction (fork without exec?)
/mnt/e9274e05-5b1e-443c-9278-96c87cf3f8d5/SteamLibrary/steamapps/common/Counter-Strike Global Offensive/game/cs2.sh: line 98:   644 Segmentation fault      (core dumped) ${STEAM_RUNTIME_PREFIX} ${GAME_DEBUGGER} "${GAMEROOT}"/${GAMEEXE} "$@"
Game 730 created interface STEAMAPPS_INTERFACE_VERSION008 /
Game 730 created interface STEAMHTMLSURFACE_INTERFACE_VERSION_005 /
Game 730 created interface STEAMHTTP_INTERFACE_VERSION003 / HTTP
Game 730 created interface STEAMREMOTESTORAGE_INTERFACE_VERSION016 /
Game 730 created interface STEAMTIMELINE_INTERFACE_V001 /
Game 730 created interface STEAMUSERSTATS_INTERFACE_VERSION012 /
Game 730 created interface SteamAppDisableUpdate001 /
Game 730 created interface SteamFriends017 /
Game 730 created interface SteamGameCoordinator001 /
Game 730 created interface SteamGameStats001 /
Game 730 created interface SteamMatchMaking009 /
Game 730 created interface SteamNetworking006 /
Game 730 created interface SteamNetworkingSocketsSerialized005 /
Game 730 created interface SteamUser023 /
Game 730 created interface SteamUser023 / User
Game 730 created interface SteamUtils010 /
Game 730 created interface SteamUtils010 / Utils
Game 730 method call count for IClientNetworkingSocketsSerialized::GetSTUNServer : 2
Game 730 method call count for IClientNetworkingSocketsSerialized::GetCachedRelayTicketCount : 1
Game 730 method call count for IClientNetworkingSocketsSerialized::GetCertAsync : 1
Game 730 method call count for IClientTimeline::SetTimelineGameMode : 1
Game 730 method call count for IClientHTTP::SendHTTPRequest : 1
Game 730 method call count for IClientHTTP::SetHTTPRequestHeaderValue : 1
Game 730 method call count for IClientHTTP::CreateHTTPRequest : 1
Game 730 method call count for IClientGameStats::GetNewSession : 1
Game 730 method call count for IClientGameCoordinator::SendMessage : 1
Game 730 method call count for IClientRemoteStorage::FileExists : 1
Game 730 method call count for IClientRemoteStorage::GetFileSize : 2
Game 730 method call count for IClientNetworking::GetMaxPacketSize : 1
Game 730 method call count for IClientUserStats::DeprecatedPublic_RequestCurrentStats : 1
Game 730 method call count for IClientAppManager::GetCurrentLanguage : 1
Game 730 method call count for IClientAppManager::GetAppStateInfo : 1
Game 730 method call count for IClientAppManager::BIsDlcEnabled : 1
Game 730 method call count for IClientUtils::RecordSteamInterfaceCreation : 31
Game 730 method call count for IClientUtils::InitFilterText : 1
Game 730 method call count for IClientUtils::IsSteamChina : 1
Game 730 method call count for IClientUtils::GetLauncherType : 1
Game 730 method call count for IClientUtils::GetSteamUILanguage : 1
Game 730 method call count for IClientUtils::GetAppID : 38
Game 730 method call count for IClientUtils::GetIPCountry : 3
Game 730 method call count for IClientUtils::GetServerRealTime : 2
Game 730 method call count for IClientFriends::RequestEquippedProfileItems : 1
Game 730 method call count for IClientFriends::GetFriendPersonaName_Public : 3
Game 730 method call count for IClientFriends::GetFriendCount : 1
Game 730 method call count for IClientUser::BSetDurationControlOnlineState : 1
Game 730 method call count for IClientUser::BIsSubscribedApp : 2
Game 730 method call count for IClientUser::GetUserDataFolder : 1
Game 730 method call count for IClientUser::GetSteamID : 22
Game 730 method call count for IClientUser::BLoggedOn : 5
Uploaded AppInterfaceStats to Steam
Removing process 686 for gameID 730
Removing process 646 for gameID 730
Removing process 645 for gameID 730
Removing process 644 for gameID 730
Removing process 643 for gameID 730
Removing process 641 for gameID 730
Removing process 639 for gameID 730
Removing process 550 for gameID 730
Removing process 549 for gameID 730
Removing process 548 for gameID 730
[2024-10-18 21:48:49] Background update loop checking for update. . .
[2024-10-18 21:48:49] Checking for available updates...
[2024-10-18 21:48:49] Downloading manifest: https://client-update.fastly.steamstatic.com/steam_client_ubuntu12
[2024-10-18 21:48:49] Manifest download: send request
[2024-10-18 21:48:50] Manifest download: waiting for download to finish
[2024-10-18 21:48:50] Manifest download: finished
[2024-10-18 21:48:50] Download skipped: /steam_client_ubuntu12 version 1726604483, installed version 1726604483, existing pending version 0
[2024-10-18 21:48:50] Nothing to do
(process:666): GLib-GObject-CRITICAL **: 21:48:52.905: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
reaping pid: 666 -- gameoverlayui
WARNING: discarding _NET_WM_PID 8367 as invalid for X11 window - use specialized XCB_X11_TO_PID function!
Please help me as my friends play it, i want to play it too. They are laughing about linux as i cant play with them.
My system Info:Operating System: EndeavourOS
KDE Plasma Version: 6.2.1
KDE Frameworks Version: 6.7.0
Qt Version: 6.8.0
Kernel Version: 6.11.3-arch1-1 (64-bit)
Graphics Platform: X11
Processors: 4 × Intel® Core™ i3-9100 CPU @ 3.60GHz
Memory: 7.5 GiB of RAM
Graphics Processor: Mesa Intel® UHD Graphics 630
Manufacturer: Acer
Product Name: Veriton M4660G
System Version: P21-B0
I have played quite a few games new and old on Linux fine without issues, other than applying additional WINE configuration on some but most of the time just Steam proton works for windows versions.
Try some of the launcher settings found here to see if this works. https://www.protondb.com/app/730
Other than this the only thing I can think of is Flatpak can sometimes not work with other drives due to permission issues as I had an issue like this trying to get a piece of software working via flatpak bottles, but I never bothered troubleshooting this at the time so I wouldn’t know how to get around it other than knowing there is a way to do it. Is this the only game having this issue on another drive?
Someone else may have to step in regarding flatpak version of Steam since the Native version of CS2 should work without issue but as I don’t own the game I can’t test this. I have the Arch repository version of Steam installed and not Flatpak version and all games are on a different drive and haven’t encountered any issues.
Note: I should mention my reasoning for issues accessing between disks is the error seems unable to reach certain libraries. I could be wrong but I had the same issue with other Flatpak applications and read about it needing flatpak apps to be granted access to mounted drives.
I have tried different launcher settings but it does not work. By the way I am using Intel UHD Graphics @_Six .
@ArefinKarim
The windows weakens the ability to delve into some machine-related topics.
I started the examination of steam and with
GPU: Intel Iris Plus Graphics G1 in Plasma and i3 my best result are as follows
yay steam
IDK if within steam Proton 9 download is crucial or not.
I tested with Fishing Planet, Combat Master, CS2D they all work.
Unfortunately CS2 is not free for steam/linux.
I don’t play this game anymore and I haven’t tried it on Linux yet, so I went ahead and did that on my pure Arch installation.
It works just fine with the default Proton version that Steam uses. Granted, I am using a Radeon GPU.
Try forcing it to use Proton-GE through ProtonPlus or by downloading it yourself. It may not allow you to join VAC secured servers though but it will run. WIth Steam’s Proton, I can join VAC secured servers just fine.
The proton one works, but the native one does not run, I tried it on bazzite, but no luck. Proton works tho.
Anyways, the proton one runs very bad on my machine, I just gave up.
Thanks for responding.
