This only happened when I started setting up fluidsynth.
Now even
abeep -f 750 -r 5 -d 100 -n -f 1000 -r 3 -d 200 -n -f 2000 -r 3 -d 200
causes crackling, but a couple weeks ago (when I didn’t have fluidsynth setup) it works.
I’m using pipewire btw.
Kernel: 5.19.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=91691606-aa74-48ac-9cb5-34b6d123b103 rw rootflags=subvol=@
sysrq_always_enabled=1 loglevel=3 nowatchdog nvme_load=YES
Desktop: KDE Plasma v: 5.25.4 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
dm: SDDM Distro: EndeavourOS base: Arch Linux
Type: Laptop System: HP product: HP Laptop 15-bs0xx v: Type1ProductConfigId
Mobo: HP model: 832C v: 25.56 serial: <superuser required> UEFI: Insyde
v: F.68 date: 07/22/2021
Battery:
ID-1: BAT1 charge: 23.4 Wh (100.0%) condition: 23.4/31.1 Wh (75.4%)
volts: 12.5 min: 11.1 model: COMPAL PABAS0241231 type: Li-ion
serial: <filter> status: full
Device-1: hidpp_battery_0 model: Logitech K350 serial: <filter> charge: 70%
(should be ignored) rechargeable: yes status: discharging
Device-2: hidpp_battery_1 model: Logitech Marathon Mouse/Performance Plus
M705 serial: <filter> charge: 10% (should be ignored) rechargeable: yes
status: discharging
Info: model: Intel Pentium N3710 bits: 64 type: MCP arch: Airmont
built: 2015-17 process: Intel 14nm family: 6 model-id: 0x4C (76)
stepping: 4 microcode: 0x411
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
desc: d-4x24 KiB; i-4x32 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 1606 high: 1933 min/max: 480/2560 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1933 2: 1907 3: 1316
4: 1271 bogomips: 12800
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Vulnerabilities:
Type: mds mitigation: Clear CPU buffers; SMT disabled
Type: spec_store_bypass status: Not affected
sanitization
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics vendor: Hewlett-Packard driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:22b1
class-ID: 0300
Device-2: Chicony HP Webcam type: USB driver: uvcvideo bus-ID: 1-5.2:5
chip-ID: 04f2:b5db class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,intel,vesa gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x10ec built: 2016 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 405 (BSW) v: 4.6 Mesa 22.1.6
direct render: Yes
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
High Definition Audio vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:2284 class-ID: 0403
Sound Server-1: ALSA v: k5.19.3-zen1-1-zen running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.56 running: yes
Device-1: Realtek RTL8188EE Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8188ee v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8179
class-ID: 0280
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 1000 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: eno1 state: down mac: <filter>
Local Storage: total: 465.76 GiB used: 335.93 GiB (72.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LT012-1DG142
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: YAM1
scheme: GPT
ID-1: / raw-size: 60 GiB size: 60 GiB (100.00%) used: 38.57 GiB (64.3%)
fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 153 MiB
(59.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 60 GiB size: 60 GiB (100.00%) used: 38.57 GiB
(64.3%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-4: /var/log raw-size: 60 GiB size: 60 GiB (100.00%) used: 38.57 GiB
System Temperatures: cpu: 51.0 C mobo: N/A
Fan Speeds (RPM): N/A
Processes: 194 Uptime: 48m wakeups: 14 Memory: 3.74 GiB used: 1.88 GiB
(50.3%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pacman: 1296 lib: 324 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.20
coolcrew45@CoolCrew45-HP-Laptop-UNDERKILL-15bs0xx ~>
