CPU running 100% and freezing tasks
Your htop screen shot also seems to suggest that htop is seeing only one cpu.
Perhaps htop has a setting to show all cores as one cpu? Not sure
Maybe hold your finger on the purchase of new stuff, I’m not sure this one’s quite case closed just yet :sweat_smile:
What’s the output of:
nproc
(should be reporting 12?)
Have you sought a BIOS update for your motherboard? I suspect the most recent update might be from mid 2023, but you’re running a version from mid 2019.
Do you have intel-ucode installed?`
yay -Q intel-ucode
I just solved the problem, and it was all thanks to @Bink’s suggestion. When I typed inxi -Ccsxx --za, I saw that only one core was seen, and I started digging.
My OS was only seeing one core of the CPU, which actually have six cores. I rebooted into BIOS and searched inside the options, just to find out that the Multiprocessing option was disabled. I switched that on, and… well, it was that simple.
Thanks everybody for the efforts, at least now I have an optimized version of the hardware acceleration… (because that needed to be fixed)
