Hi,
since last kernel update, my CPU never goes under 11% load and it warms a lot, looks like xorg server is getting the most of the load :
ps a :
PID TTY STAT TIME COMMAND
771 tty7 Rsl+ 4:26 /usr/lib/Xorg :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
1958 pts/0 Ss 0:00 bash
588092 pts/0 R+ 0:00 ps a
top
771 root 20 0 1111612 160548 107020 R 30.5 1.1 5:18.33 /usr/lib/Xorg :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
441471 jessbont 20 0 175164 17408 13952 S 11.9 0.1 0:45.88 i3bar --transparency --bar_id=bar-0 --socket=/run/user/1000/i3/ipc-socket.813
441480 jessbont 20 0 7516 3584 3200 S 5.3 0.0 0:20.71 bash /home/jessbont/.config/i3/scripts/i3-focusedwindow 79
864 jessbont 20 0 769676 131808 98264 S 3.3 0.9 0:33.62 picom
441477 jessbont 20 0 2492 1664 1536 S 1.3 0.0 0:05.42 i3blocks -c /home/jessbont/.config/i3/i3blocks.conf
58343 jessbont 20 0 5672972 577720 253884 S 1.0 3.8 0:36.92 /usr/bin/python3 /usr/bin/qutebrowser
265 root -2 0 0 0 0 S 0.7 0.0 0:05.60 [gfx_0.0.0]
438 root -51 0 0 0 0 S 0.7 0.0 0:01.81 [irq/60-ELAN0678:00]
823 jessbont 20 0 9084 4992 4224 S 0.7 0.0 0:02.31 /usr/bin/dbus-daemon --session --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
90511 jessbont 20 0 1134.9g 255168 103648 S 0.7 1.7 0:40.17 /usr/lib/qt6/QtWebEngineProcess --type=renderer --webengine-schemes=qute:lL;qrc:sV --disable-speech-api --enable-t+
535135 root 20 0 0 0 0 D 0.7 0.0 0:00.24 [kworker/u32:3+events_unbound]
693944 jessbont 20 0 12256 6016 3840 R 0.7 0.0 0:00.05 top
tried to disable bar transparancy, killed picom and switching to zen kernel
Edit :
Hardware :
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 48 bits physical, 48 bits virtual
Byte Order: Little Endian
CPU(s): 16
On-line CPU(s) list: 0-15
Vendor ID: AuthenticAMD
Model name: AMD Ryzen 7 PRO 6850U with Radeon Graphics
CPU family: 25
Model: 68
Thread(s) per core: 2
Core(s) per socket: 8
Socket(s): 1
Stepping: 1
