Counter Strike 2 slideshow to system freeze
I just had an update for CS2 and did a system update with pacman -Syu after a reboot I started the game. I noticed that a black window opened in the right bottom corner of my primary screen, which was odd since the game started usually in full screen. After that it goes to the CS2 startup screen in full screen like I’m used to it. After this everything runs fine until I join a game.
After a few second the frame rate drops to a slideshow and I cant exit the game with ALT F4 the whole system freezes. I have to manually restart the PC.
I seems to happen only to CS2 I tried Hitman 3 and Cyberpunk and they worked fine.
Any suggestions are welcome, I can provide any logs as long you can tell me how to create them.
