Corrupted kernel panics
It looks like the system crashes every time I compile dotnet-core.
CPU: Intel(R) Core™ i7-9850H CPU @ 2.60GHz
GPU: Nvidia Quatro T2000. Using nvidia-open.
Panic logs:
ummmm….
Could you give me your specs more in detail? Try inxi -FAZ
You could also try downloading via snap package it it interests you.
Kernel: 6.17.2-arch1-1 arch: x86_64 bits: 64
Desktop: KDE Plasma v: 6.4.5 Distro: EndeavourOS
Type: Laptop System: HP product: HP ZBook 15 G6 v: SBKPF
serial:
Mobo: HP model: 860F v: KBC Version 65.39.00 serial:
UEFI: HP v: R92 Ver. 01.32.00 date: 03/04/2025
Battery:
ID-1: BAT0 charge: 14.2 Wh (23.3%) condition: 61.1/90 Wh (67.9%)
Info: 6-core model: Intel Core i7-9850H bits: 64 type: MT MCP cache:
L2: 1.5 MiB
Speed (MHz): avg: 1000 min/max: 800/4600 cores: 1: 1000 2: 1000 3: 1000
4: 1000 5: 1000 6: 1000 7: 1000 8: 1000 9: 1000 10: 1000 11: 1000 12: 1000
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] driver: i915 v: kernel
Device-2: NVIDIA TU117GLM [Quadro T2000 Mobile / Max-Q] driver: nvidia
v: 580.95.05
Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
Integrated Webcam driver: uvcvideo type: USB
Display: wayland server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8
compositor: kwin_wayland driver: X: loaded: modesetting,nvidia dri: iris
gpu: i915 resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: iris,nvidia,swrast
platforms: gbm,wayland,x11,surfaceless,device
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.2.4-arch1.2
renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
API: Vulkan v: 1.4.328 drivers: nvidia surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Cannon Lake PCH cAVS driver: sof-audio-pci-intel-cnl
Device-2: Sony DualShock 4 [CUH-ZCT1x]
driver: playstation,snd-usb-audio,usbhid type: USB
API: ALSA v: k6.17.2-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.4.9 status: active
Device-1: Intel Ethernet I219-LM driver: e1000e
IF: enp0s31f6 state: down mac: f8:0d:ac:0e:1a:a2
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi
IF: wlan0 state: up mac: 9c:fc:e8:cb:d1:1c
Bluetooth:
Device-1: Intel AX200 Bluetooth driver: btusb type: USB
Report: btmgmt ID: hci0 state: up address: 9C:FC:E8:CB:D1:20 bt-v: 5.2
Local Storage: total: 476.94 GiB used: 177.05 GiB (37.1%)
ID-1: /dev/nvme0n1 vendor: Silicon Power model: SPCC M.2 PCIe SSD
ID-1: / size: 68.35 GiB used: 58.59 GiB (85.7%) fs: ext4 dev: /dev/nvme0n1p6
ID-2: /boot/efi size: 96 MiB used: 76.4 MiB (79.5%) fs: vfat
dev: /dev/nvme0n1p2
ID-3: /home size: 149.06 GiB used: 118.38 GiB (79.4%) fs: ext4
dev: /dev/nvme0n1p7
System Temperatures: cpu: 32.0 C pch: 47.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 32 GiB note: est. available: 30.94 GiB used: 5.49 GiB (17.7%)
Processes: 391 Uptime: 4h 3m Shell: Bash inxi: 3.3.39
Well for your information the kernel is now at 6.17.5 version and plasma on 6.5.0 , makes me wonder how often you run a update ?
Yep. @MrSoup678 DEFINITELY needs to update EOS.
I wonder if it’s running out of memory, and with no swap defined… You could set up zram and swap to see if that fixes it.
Try downloading via snap and update your system.
Update no longer crashes this.
