Copied the pipewire.conf to pipewire.conf.d now I have nothing for sound and the speaker toolbar botton is empty!
Yes I did. I thought it was a reasonable thing to do based on the comments within the pipewire.conf.
What do I do to get my sound back. I deleted the pipewire.conf from pipewire.conf,d and even deleted pipewire.conf.d but after trying to reinstall everything it still will not work.
[x@x-xylon ~]$ systemctl --user status pipewire pipewire-pulse wireplumber
● pipewire.service - PipeWire Multimedia Service
     Loaded: loaded (/usr/lib/systemd/user/pipewire.service; enabled; preset: enabled)
     Active: active (running) since Sat 2026-01-10 09:12:55 EST; 1h 26min ago
 Invocation: 7d16fefcbc374563bbee238824ebcfed
TriggeredBy: ● pipewire.socket
   Main PID: 1200 (pipewire)
      Tasks: 3 (limit: 38139)
     Memory: 8.2M (peak: 9.5M)
        CPU: 157ms
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
             └─1200 /usr/bin/pipewire
Jan 10 09:12:55 x-xylon systemd[1180]: Started PipeWire Multimedia Service.
× pipewire-pulse.service - PipeWire PulseAudio
     Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; enabled; preset: enabled)
     Active: failed (Result: exit-code) since Sat 2026-01-10 10:21:06 EST; 18min ago
   Duration: 23ms
 Invocation: 14ab9fd04145456e95ffa9e91caef7e6
TriggeredBy: × pipewire-pulse.socket
    Process: 8288 ExecStart=/usr/bin/pipewire-pulse (code=exited, status=245/KSM)
   Main PID: 8288 (code=exited, status=245/KSM)
   Mem peak: 2.2M
        CPU: 16ms
Jan 10 10:21:06 x-xylon systemd[1180]: pipewire-pulse.service: Scheduled restart job, restart counter is at 5.
Jan 10 10:21:06 x-xylon systemd[1180]: pipewire-pulse.service: Start request repeated too quickly.
Jan 10 10:21:06 x-xylon systemd[1180]: pipewire-pulse.service: Failed with result 'exit-code'.
Jan 10 10:21:06 x-xylon systemd[1180]: Failed to start PipeWire PulseAudio.
● wireplumber.service - Multimedia Service Session Manager
     Loaded: loaded (/usr/lib/systemd/user/wireplumber.service; enabled; preset: enabled)
 Invocation: 91ba8f4650974b31ac61bde972e4a389
   Main PID: 1201 (wireplumber)
      Tasks: 6 (limit: 38139)
     Memory: 54.6M (peak: 55.4M)
        CPU: 1.197s
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/wireplumber.service
             └─1201 /usr/bin/wireplumber
lines 1-41...skipping...
        CPU: 157ms
   Duration: 23ms
   Mem peak: 2.2M
        CPU: 16ms
        CPU: 1.197s
Jan 10 09:12:55 x-xylon systemd[1180]: Started Multimedia Service Session Manager.
lines 1-42...skipping...
        CPU: 157ms
   Duration: 23ms
   Mem peak: 2.2M
        CPU: 16ms
        CPU: 1.197s
Jan 10 09:12:55 x-xylon wireplumber[1201]: wp-device: SPA handle 'api.libcamera.enum.manager' could not be loaded; is it installed?
lines 1-43...skipping...
        CPU: 157ms
   Duration: 23ms
   Mem peak: 2.2M
        CPU: 16ms
        CPU: 1.197s
Jan 10 09:12:55 x-xylon wireplumber[1201]: s-monitors-libcamera: PipeWire's libcamera SPA plugin is missing or broken. Some camera types may not >
lines 1-44...skipping...
        CPU: 157ms
   Duration: 23ms
   Mem peak: 2.2M
        CPU: 16ms
        CPU: 1.197s
Jan 10 09:12:56 x-xylon wireplumber[1201]: default: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwner
lines 1-45...skipping...
        CPU: 157ms
   Duration: 23ms
   Mem peak: 2.2M
        CPU: 16ms
        CPU: 1.197s
Jan 10 09:12:56 x-xylon wireplumber[1201]: spa.bluez5: BlueZ system service is not available
lines 1-46...skipping...
        CPU: 157ms
   Duration: 23ms
   Mem peak: 2.2M
        CPU: 16ms
        CPU: 1.197s
Jan 10 10:39:16 x-xylon wireplumber[1201]: wp-event-dispatcher: <WpAsyncEventHook:0x5578a24146c0> failed: <WpSiStandardLink:0x5578a257a7d0> link >
lines 1-47...skipping...
        CPU: 157ms
   Duration: 23ms
   Mem peak: 2.2M
        CPU: 16ms
        CPU: 1.197s
lines 1-47/47 (END)...skipping...
        CPU: 157ms
   Duration: 23ms
   Mem peak: 2.2M
        CPU: 16ms
        CPU: 1.197s
        CPU: 157ms
   Duration: 23ms
   Mem peak: 2.2M
        CPU: 16ms
        CPU: 1.197s
        CPU: 157ms
   Duration: 23ms
   Mem peak: 2.2M
        CPU: 16ms
        CPU: 1.197s
        CPU: 157ms
   Duration: 23ms
   Mem peak: 2.2M
        CPU: 16ms
        CPU: 1.197s
        CPU: 157ms
   Duration: 23ms
   Mem peak: 2.2M
        CPU: 16ms
        CPU: 1.197s
        CPU: 157ms
   Duration: 23ms
   Mem peak: 2.2M
        CPU: 16ms
        CPU: 1.197s
        CPU: 157ms
   Duration: 23ms
   Mem peak: 2.2M
        CPU: 16ms
        CPU: 1.197s
        CPU: 157ms
   Duration: 23ms
   Mem peak: 2.2M
        CPU: 16ms
        CPU: 1.197s
        CPU: 157ms
   Duration: 23ms
   Mem peak: 2.2M
        CPU: 16ms
        CPU: 1.197s
        CPU: 157ms
   Duration: 23ms
   Mem peak: 2.2M
        CPU: 16ms
        CPU: 1.197s
lines 1-47/47 (END)
Also what do I do to exit after I run this command? I usually just close the console.
Any help is much appreciated.
I know just enough to get myself into trouble. :upside_down_face:
[edit] I forgot to mention that when I tried to save pipewire.conf to pipewire.conf.d I got an error at line 30 so I uncommented lines 30-37. Then I restarted after it saved and then when it finished booting I had lost my sound.
https://0x0.st/PXQH.txt
