This is a color scheme I made that is based on the Arc theme, incidentally also very close in color to the actual logo (color hues a bit darker).
I THINK this is all the info you need to parse the config file for the terminal theme, should you chose to use it:
ColorPalette=rgb(56,59,73);rgb(202,78,108);rgb(88,142,90);rgb(246,139,62);rgb(38,139,210);rgb(211,54,130);rgb(42,161,152);rgb(238,232,213);rgb(64,69,82);rgb(228,123,115);rgb(138,203,158);rgb(213,214,90);rgb(93,136,166);rgb(157,89,120);rgb(108,172,168);rgb(135,135,135)
ColorForeground=#eeeee8e8d5d5
ColorBackground=#1b1b1c1c2222
ColorCursor=#93a1a1
ColorBold=#848585
ColorBoldUseDefault=FALSE
TabActivityColor=#dc322f
