Hey y’all, I recently made the switch to Linux and EndeavorOS a couple months ago and since then I’ve been having constant issues with programs crashing, namely Firefox (tabs or the whole browser), Discord (freezes), Steam (crashes and restarts), Arc Raiders (crashes or corrupts one of the files and has to be re-installed, and War Thunder (freezes).
Firefox is the biggest offender by far with it sometimes being stable but often with tabs crashing immediately and repeatedly when attempting to open many websites. Discord is probably the most problematic, with the program randomly freezing and a system reboot being required to get it to relaunch maybe half the time, even after opening the task manager and killing the program off entirely.
I’ve been experiencing these issues since I installed Linux, but I do believe they got noticeably worse with Nvidia’s 580.105.08 drivers. I did try reverting those for another reason (secondary monitor has been stuck at the wrong resolution and aspect ratio for a month now without Nvidia fixing it yet), but I ran into issues with that and had to re-update everything. That said, these issues did exist before 580.105.08. I also can’t switch to the open drivers because my GTX 1080 isn’t supported.
- I checked the health of my boot drive and the NVME SSD I have Steam/games installed on via
smartctland it said they’re healthy. - I tried switched between wayland and xorg, but it crashes if I try logging in with xorg.
- As far as I know everything is up to date (although if there’s some driver causing issues which isn’t being updated via
yaythen I don’t know how to check or fix that.
I’m very new to Linux and could use any and all help troubleshooting this.
I figure it may be the first thing asked for, so including my inxi -F output below.
Host: Makhnovshchina Kernel: 6.17.9-arch1-1 arch: x86_64 bits: 64
Desktop: Xfce v: 4.20.1 Distro: EndeavourOS
Type: Desktop Mobo: Micro-Star model: Z370-A PRO (MS-7B48) v: 1.0
serial: Firmware: UEFI vendor: American Megatrends
v: 2.30 date: 12/21/2017
Info: 6-core model: Intel Core i7-8700K bits: 64 type: MT MCP cache:
L2: 1.5 MiB
Speed (MHz): avg: 4503 min/max: 800/4700 cores: 1: 4503 2: 4503 3: 4503
4: 4503 5: 4503 6: 4503 7: 4503 8: 4503 9: 4503 10: 4503 11: 4503 12: 4503
Device-1: NVIDIA GP104 [GeForce GTX 1080] driver: nvidia v: 580.105.08
Display: x11 server: ``X.Org`` v: 21.1.21 with: Xwayland v: 24.1.9 driver: X:
loaded: nvidia gpu: nvidia,nvidia-nvswitch resolution: 1: 3440x1440~100Hz
2: 1920x1080~60Hz
API: EGL v: 1.5 drivers: nvidia,swrast
platforms: gbm,x11,surfaceless,device
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.105.08
renderer: NVIDIA GeForce GTX 1080/PCIe/SSE2
Info: Tools: api: eglinfo,glxinfo de: xfce4-display-settings
gpu: nvidia-settings,nvidia-smi x11: xdriinfo, xdpyinfo, xprop, xrandr
Device-1: Intel 200 Series PCH HD Audio driver: snd_hda_intel
Device-2: NVIDIA GP104 High Definition Audio driver: snd_hda_intel
Device-3: JMTek LLC. USB PnP Audio Device
driver: hid-generic,snd-usb-audio,usbhid type: USB
Device-4: SteelSeries ApS Arctis 5
API: ALSA v: k6.17.9-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.4.9 status: active
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
driver: r8169
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: 30:9c:23:9d:99:d8
Local Storage: total: 3.75 TiB used: 721.78 GiB (18.8%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WD BLACK SN850X 2000GB
ID-2: /dev/sda vendor: Western Digital model: WDS100T2B0A-00SM50
ID-3: /dev/sdb vendor: Western Digital model: WD10EZEX-08WN4A0
ID-4: /dev/sdc vendor: SanDisk model: SDSSDA120G size: 111.79 GiB
ID-1: / size: 913.85 GiB used: 235.85 GiB (25.8%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 40.0 C mobo: N/A gpu: nvidia temp: 57 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Memory: total: 64 GiB note: est. available: 62.75 GiB used: 5.54 GiB (8.8%)
Processes: 341 Uptime: 1h 27m Shell: Bash inxi: 3.3.40
