I recently installed endeavourOS kde on my old MacBook Air 7,2 and while everything (except sleep) works well the WiFi has been bugging out on me. While it DOES detect connections trying to connect to my WiFi bugs out and deactivates the connection.
Coincidentally this happened after switching to Rogers from Telus. My phones does work for wifi so it’s NOT a connection issue and so does my PC (which also runs arch linux).
To be clear, it is IDENTIFYING available networks, but it is NOT connecting to mine.
It had NO PROBLEM connecting to Telus’s networks. But Rogers is putting up a fight.
I am not to familiar with the Rogers from Telus part. I’m just trying to work out the setup as in my country I have no idea of rogers and telus but found them to be internet providers.
I’m just trying to work out the setup, is the old router changed to a different one from the new provider or is this your own router (Same router) used from old provider to new?
Is the Arch Linux PC using WiFi as well or is that through cable?
