Hello everyone :] I’ve had a blast using Endeavour so far with no issues. (Atleast ones I couldn’t troubleshoot easily haha) However I do have a question about my driver I’m a bit confused about, so I figured I’d bite my pride and just ask for clarification. I’m not the most knowledgeable about drivers and would hate to make a bigger issue for myself.
For context, when first installing I chose the non-Nvidia driver option since it sounded like a more safe bet. After finishing install and getting the system up to date it appears it have detected my Nvidia drivers already? Heres system specs:
Kernel: 6.13.2-arch1-1 arch: x86_64 bits: 64
Desktop: KDE Plasma v: 6.2.5 Distro: EndeavourOS
Type: Desktop Mobo: ASRock model: A320M/ac serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: P1.90 date: 01/03/2020
Info: 6-core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP cache: L2: 3 MiB
Speed (MHz): avg: 3400 min/max: 1550/3400 cores: 1: 3400 2: 3400 3: 3400
4: 3400 5: 3400 6: 3400 7: 3400 8: 3400 9: 3400 10: 3400 11: 3400 12: 3400
Device-1: NVIDIA TU116 [GeForce GTX 1660] driver: nvidia v: 570.86.16
Display: wayland server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.5
compositor: kwin_wayland driver: X: loaded: nvidia unloaded: modesetting
gpu: nvidia,nvidia-nvswitch resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: nvidia
platforms: gbm,wayland,x11,surfaceless,device
API: OpenGL v: 4.6.0 vendor: nvidia v: 570.86.16 renderer: NVIDIA GeForce
GTX 1660/PCIe/SSE2
API: Vulkan v: 1.4.303 drivers: N/A surfaces: xcb,xlib,wayland
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: NVIDIA TU116 High Definition Audio driver: snd_hda_intel
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio
API: ALSA v: k6.13.2-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.2.7 status: active
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
IF: wlan0 state: up mac: bc:54:2f:2e:b3:82
Device-2: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
driver: r8169
IF: enp5s0 state: down mac: a8:a1:59:34:e6:38
Bluetooth:
Device-1: Intel Wireless-AC 3168 Bluetooth driver: btusb type: USB
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: disabled
Local Storage: total: 465.76 GiB used: 10.47 GiB (2.2%)
ID-1: /dev/sda vendor: PNY model: CS900 500GB SSD size: 465.76 GiB
ID-1: / size: 457.38 GiB used: 10.47 GiB (2.3%) fs: ext4 dev: /dev/sda1
System Temperatures: cpu: 43.6 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 8 GiB available: 7.68 GiB used: 2.99 GiB (38.9%)
Processes: 298 Uptime: 27m Shell: Bash inxi: 3.3.37
Anyways, tldr, my question is, am I good to go? Do I need to install anything? Thanks :]
