Conflicting packages: installing openblas64 (0.3.23-3) breaks dependency 'blas64' required by lapack64
Updating packages gives this error:
:: installing openblas64 (0.3.23-3) breaks dependency ‘blas64’ required by lapack64
I tried to follow https://archlinux.org/news/openblas-0323-2-update-requires-manual-intervention/, but it doesn’t solve the problem for my system. It also seems that I cannot uninstall and reinstall openblas because lots of other packages depend on it.
Before this I used paru to install/update packages and never had any problems.
Did you do exactly what the post tells you to do? Did you run:
sudo pacman -Syu blas-openblas
paru is just a wrapper for pacman that includes AUR helper functionality, it doesn’t have any magical properties. You would ahve the same problem using paru.
Yes. This is the full output:
❯ sudo pacman -Syu blas-openblas
[sudo] password for emmy:
:: Synchronizing package databases…
endeavouros is up to date
core is up to date
extra is up to date
community is up to date
multilib is up to date
warning: blas-openblas-0.3.23-3 is up to date – reinstalling
:: Starting full system upgrade…
resolving dependencies…
looking for conflicting packages…
How about:
sudo pacman -Syu blas-openblas blas64-openblas
This works! Thank you!
