hello everyone, noob here.
does anyone use variety wallpaper changer? i liked it alot from the previous distros and DEs ive tried, but it seems to be giving me trouble using it for the first time in i3.
the images i have variety pool from are not all correct sizes most of them are just pictures taken from a phone in portrait mode. I’d like the portrait images to be displayed in full at the center of the screen with borders to fill the empty space. I was able to achieve this on other DEs by just toggling the setting for this behaviour in their respective wallpaper tools and variety would acknowledge these changes. everytime it generates a new photo
with i3 though, variety seems to atleast know that i’m using feh for my wallpaper tool, but even though ive ran feh --bg-max <path_to_image> to get it to do the same behavior, whenever variety changes the wallpaper it fills the entire screen zoomed in.
I see that variety creates a bash file in my home directory named “.fehbg” but in it, it is being defined that feh output the wallpaper with the --bg-fill arguement which zooms images in to fill the screen.
i’d like to find out what script is responsible for writing this .fehbg bash file so i can change its defaults, maybe? or is there another way i could go about this? any input would be greatly appreciated
No experience with either - but you should check if the file is being recreated each time, or is used if present. Try overwriting with YOUR choice of settings, and see what happens. If not enough, try your settings and changing permissions on the file to see if it survives and is used…
This is the ‘direct action’ method of getting what you want - and may or may not help!
I dont actually generate it. I give variety a directory of images, and it just cycles through each of the files in there. what gets generated every 5 minutes or so, is an image with a filter.
i still tried what you suggested changng chmod permisions on the .fehbg file but it seems to not care about that and when i click on next image from the variety app the .fehbg file just gets updated anyway.
So much for the backdoor fixes, I guess. Sorry! May even be driven to make a bug report on variety - after trying whatever else is searchable or configurable…
Good luck!
of course, you could script a pass through **convert** (imagemagick) before the image gets in the queue...
i dont know man did i do something wrong? nothing is changing. i am on zsh. perhaps i should put that line in the .zshrc file? coz i dont have a .zprofile one. i did create one to follow your instructions though. but nothing happened
tried putting that export line in the zshrc file no change
tried removing the .zprofile i created no change
im curious though why did you have me install nitrogen if we were gonna comment out its auto launch at start up line in the i3 config file? is it being used even? coz that .fehbg file is still being updated when i click on the Next buttton from the variety gui
i opened the nitrogen gui and there is an option at the bottom left that is toggled to zoom fill. changed it to automatic, then clicked Next image on variety. went back to nitrogen and it is back to zoom fill.
echo $XDG_CURRENT_SESSION is empty. nothing to show
# exec --no-startup-id ~/set_once.sh
# This file is a modified version based on default i3-config-wizard config
# source is available here:
# https://raw.githubusercontent.com/endeavouros-team/endeavouros-i3wm-setup/master/.config/i3/config
# Maintainer: joekamprad [joekamprad@endeavouros.com]
# https://endeavouros.com
# iconic font icon search: https://fontawesome.com/v4.7/cheatsheet/
# --> to update this run the following command (will backup existing setup file)
# wget --backups=1 https://raw.githubusercontent.com/endeavouros-team/endeavouros-i3wm-setup/main/.config/i3/config -P ~/.config/i3/
# Endeavouros-i3 config file
# Source for complete framework of our i3 config and theming here: https://github.com/endeavouros-team/endeavouros-i3wm-setup
# EndeavourOS wiki holds some Information also: https://discovery.endeavouros.com/window-tiling-managers/i3-wm/
# Please see http://i3wm.org/docs/userguide.html for the official i3 reference!
# config starts here: #
# Font for window titles. Will also be used by the bar unless a different font
# is used in the bar {} block below.
# This font is widely installed, provides lots of unicode glyphs, right-to-left
# text rendering and scalability on retina/hidpi displays (thanks to pango).
font pango: Noto Sans Regular 10
# set the mod key to the winkey:
set $mod Mod1
# workspace layout: #
# default i3 tiling mode:
workspace_layout default
# i3 stacking layout:
# Each window will be fullscreen and tabbed top to bottom.
#workspace_layout stacking
# i3 tabbed layout:
# Each new window will open fullscreen as a tab (left to right)
#workspace_layout tabbed
# extra options for windows: #
#border indicator on windows:
new_window pixel 1
# thin borders
# hide_edge_borders both
# Set inner/outer gaps
gaps inner 6
gaps outer 3
# show window title bars (not officially supported with i3gaps)
#default_border normal
# window title alignment
#title_align center
# Use Mouse+$mod to drag floating windows to their wanted position
floating_modifier $mod
# switch to workspace
bindsym $mod+1 workspace $ws1
bindsym $mod+2 workspace $ws2
bindsym $mod+3 workspace $ws3
bindsym $mod+4 workspace $ws4
bindsym $mod+5 workspace $ws5
bindsym $mod+6 workspace $ws6
bindsym $mod+7 workspace $ws7
bindsym $mod+8 workspace $ws8
bindsym $mod+9 workspace $ws9
bindsym $mod+0 workspace $ws10
# switch to workspace with numpad keys
bindcode $mod+87 workspace 1
bindcode $mod+88 workspace 2
bindcode $mod+89 workspace 3
bindcode $mod+83 workspace 4
bindcode $mod+84 workspace 5
bindcode $mod+85 workspace 6
bindcode $mod+79 workspace 7
bindcode $mod+80 workspace 8
bindcode $mod+81 workspace 9
bindcode $mod+90 workspace 10
# switch to workspace with numlock numpad keys
bindcode $mod+Mod2+87 workspace $ws1
bindcode $mod+Mod2+88 workspace $ws2
bindcode $mod+Mod2+89 workspace $ws3
bindcode $mod+Mod2+83 workspace $ws4
bindcode $mod+Mod2+84 workspace $ws5
bindcode $mod+Mod2+85 workspace $ws6
bindcode $mod+Mod2+79 workspace $ws7
bindcode $mod+Mod2+80 workspace $ws8
bindcode $mod+Mod2+81 workspace $ws9
bindcode $mod+Mod2+90 workspace $ws10
# move focused container to workspace
bindsym $mod+Shift+1 move container to workspace $ws1
bindsym $mod+Shift+2 move container to workspace $ws2
bindsym $mod+Shift+3 move container to workspace $ws3
bindsym $mod+Shift+4 move container to workspace $ws4
bindsym $mod+Shift+5 move container to workspace $ws5
bindsym $mod+Shift+6 move container to workspace $ws6
bindsym $mod+Shift+7 move container to workspace $ws7
bindsym $mod+Shift+8 move container to workspace $ws8
bindsym $mod+Shift+9 move container to workspace $ws9
bindsym $mod+Shift+0 move container to workspace $ws10
# move focused container to workspace with numpad keys
bindcode $mod+Shift+Mod2+87 move container to workspace $ws1
bindcode $mod+Shift+Mod2+88 move container to workspace $ws2
bindcode $mod+Shift+Mod2+89 move container to workspace $ws3
bindcode $mod+Shift+Mod2+83 move container to workspace $ws4
bindcode $mod+Shift+Mod2+84 move container to workspace $ws5
bindcode $mod+Shift+Mod2+85 move container to workspace $ws6
bindcode $mod+Shift+Mod2+79 move container to workspace $ws7
bindcode $mod+Shift+Mod2+80 move container to workspace $ws8
bindcode $mod+Shift+Mod2+81 move container to workspace $ws9
bindcode $mod+Shift+Mod2+90 move container to workspace $ws10
bindcode $mod+Shift+87 move container to workspace $ws1
bindcode $mod+Shift+88 move container to workspace $ws2
bindcode $mod+Shift+89 move container to workspace $ws3
bindcode $mod+Shift+83 move container to workspace $ws4
bindcode $mod+Shift+84 move container to workspace $ws5
bindcode $mod+Shift+85 move container to workspace $ws6
bindcode $mod+Shift+79 move container to workspace $ws7
bindcode $mod+Shift+80 move container to workspace $ws8
bindcode $mod+Shift+81 move container to workspace $ws9
bindcode $mod+Shift+90 move container to workspace $ws10
# resize window (you can also use the mouse for that):
mode "resize" {
# These bindings trigger as soon as you enter the resize mode
# Pressing left will shrink the window's width.
# Pressing right will grow the window's width.
# Pressing up will shrink the window's height.
# Pressing down will grow the window's height.
bindsym j resize shrink width 10 px or 10 ppt
bindsym k resize grow height 10 px or 10 ppt
bindsym l resize shrink height 10 px or 10 ppt
bindsym semicolon resize grow width 10 px or 10 ppt
# same bindings, but for the arrow keys
bindsym Left resize shrink width 10 px or 10 ppt
bindsym Down resize grow height 10 px or 10 ppt
bindsym Up resize shrink height 10 px or 10 ppt
bindsym Right resize grow width 10 px or 10 ppt
# back to normal: Enter or Escape
bindsym Return mode "default"
bindsym Escape mode "default"
bindsym $mod+r mode "resize"
# keybindings for different actions: #
# start a terminal
bindsym $mod+Return exec kitty
# kill focused window
bindsym $mod+Ctrl+q kill
# exit-menu
bindsym $mod+Shift+e exec ~/.config/i3/scripts/powermenu
# Lock the system
# lock with a picture:
#bindsym $mod+l exec i3lock -i ~/.config/i3/i3-lock-screen.png -p default|win -t
# lock by blurring the screen:
bindsym $mod+Ctrl+l exec ~/.config/i3/scripts/blur-lock
# reload the configuration file
bindsym $mod+Shift+c reload
# restart i3 inplace (preserves your layout/session, can be used to update i3)
bindsym $mod+Shift+r restart
# keybinding in fancy rofi (automated):
bindsym F1 exec ~/.config/i3/scripts/keyhint-2
# alternative
# keybinding list in editor:
# bindsym $mod+F1 exec xed ~/.config/i3/keybindings
# Backlight control
bindsym XF86MonBrightnessUp exec xbacklight +5 && notify-send "Brightness - ${$(xbacklight -get)%.*}%"
bindsym XF86MonBrightnessDown exec xbacklight -5 && notify-send "Brightness - ${$(xbacklight -get)%.*}%"
# change focus
bindsym $mod+j focus left
bindsym $mod+k focus down
bindsym $mod+l focus up
bindsym $mod+semicolon focus right
# alternatively, you can use the cursor keys:
bindsym $mod+Left focus left
bindsym $mod+Down focus down
bindsym $mod+Up focus up
bindsym $mod+Right focus right
# move focused window
bindsym $mod+Shift+j move left
bindsym $mod+Shift+k move down
bindsym $mod+Shift+l move up
bindsym $mod+Shift+semicolon move right
bindsym $mod+Shift+Left move left
bindsym $mod+Shift+Down move down
bindsym $mod+Shift+Up move up
bindsym $mod+Shift+Right move right
# split in horizontal orientation
bindsym $mod+h split h
# split in vertical orientation
bindsym $mod+v split v
# enter fullscreen mode for the focused container
bindsym $mod+f fullscreen toggle
# change container layout (stacked, tabbed, toggle split)
bindsym $mod+s layout stacking
bindsym $mod+g layout tabbed
bindsym $mod+e layout toggle split
# toggle tiling / floating
bindsym $mod+Shift+space floating toggle
# change focus between tiling / floating windows
bindsym $mod+space focus mode_toggle
# focus the parent container
bindsym $mod+a focus parent
# open new empty workspace
bindsym $mod+Shift+n exec ~/.config/i3/scripts/empty_workspace
# Multimedia Keys
# volume
bindsym XF86AudioRaiseVolume exec amixer -D pulse sset Master 5%+ && pkill -RTMIN+1 i3blocks
bindsym XF86AudioLowerVolume exec amixer -D pulse sset Master 5%- && pkill -RTMIN+1 i3blocks
# gradular volume control
bindsym $mod+XF86AudioRaiseVolume exec amixer -D pulse sset Master 1%+ && pkill -RTMIN+1 i3blocks
bindsym $mod+XF86AudioLowerVolume exec amixer -D pulse sset Master 1%- && pkill -RTMIN+1 i3blocks
# mute
bindsym XF86AudioMute exec amixer sset Master toggle && killall -USR1 i3blocks
# audio control
bindsym XF86AudioPlay exec playerctl play
bindsym XF86AudioPause exec playerctl pause
bindsym XF86AudioNext exec playerctl next
bindsym XF86AudioPrev exec playerctl previous
# Redirect sound to headphones
bindsym $mod+p exec /usr/local/bin/switch-audio-port
## App shortcuts
bindsym $mod+w exec /usr/bin/chromium --incognito
bindsym $mod+n exec /usr/bin/thunar
#bindsym Print exec scrot ~/%Y-%m-%d-%T-screenshot.png && notify-send "Screenshot saved to ~/Pictures/$(date +"%Y-%m-%d-%T")-screenshot.png"
bindsym Print exec xfce4-screenshooter -f
bindsym Ctrl+Shift+Print exec xfce4-screenshooter -r
bindsym Ctrl+Print exec xfce4-screenshooter -w
# Power Profiles menu switcher (rofi)
bindsym $mod+Shift+p exec ~/.config/i3/scripts/power-profiles
# configuration for workspace behaviour: #
# Define names for default workspaces for which we configure key bindings later on.
# We use variables to avoid repeating the names in multiple places.
set $ws1 "1"
set $ws2 "2"
set $ws3 "3"
set $ws4 "4"
set $ws5 "5"
set $ws6 "6"
set $ws7 "7"
set $ws8 "8"
set $ws9 "9"
set $ws10 "10"
# use workspaces on different displays:
# where you have to replace VGA-0/HDMI-0 with the names for your displays
# you can get from xrandr command
#workspace $ws1 output VGA-0
#workspace $ws2 output VGA-0
#workspace $ws3 output HDMI-0
#workspace $ws4 output HDMI-0
#workspace $ws5 output HDMI-0
# bind program to workspace and focus to them on startup:
assign [class="(?i)chromium"] $ws2
assign [class="(?i)qbittorrent"] $ws6
assign [class="(?i)discord"] $ws4
assign [class="(?i)WebApp-messenger1527"] $ws4
# automatic set focus new window if it opens on another workspace then the current:
for_window [class=(?i)chromium] focus
for_window [class=(?i)qbittorrent] focus
for_window [class=(?i)discord] focus
for_window [class=(?i)WebApp-messenger1527] focus
# compositor #
# transparency
# uncomment one of them to be used (picom package is installed per default)
# options could need changes, related to used GPU and drivers.
# to find the right setting consult the archwiki or ask at the forum.
# xcompmgr: https://wiki.archlinux.org/title/Xcompmgr
# manpage: https://man.archlinux.org/man/xcompmgr.1.en
#exec --no-startup-id xcompmgr -C -n &
# or an more specialized config like this:
#exec --no-startup-id xcompmgr -c -C -t-5 -l-5 -r4.2 -o.55 &
# or:
# picom: https://wiki.archlinux.org/title/Picom
# manpage: https://man.archlinux.org/man/picom.1.en
exec_always --no-startup-id picom -b
#exec_always --no-startup-id killall picom && picom -b
#exec_always --no-startup-id picom --config ~/.config/picom.conf
# autostart applications/services on login: #
#get auth work with polkit-gnome
exec --no-startup-id /usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1
# dex execute .desktop files
# keep in mind that it can cause issues
# when second to i3 a DE is installed or mixed usage of i3 + xfce4 or GNOME
# in this cases better disable dex and use manual starting apps using xdg/autostart
# if enabled you should comment welcome app.
#exec --no-startup-id dex -a -s /etc/xdg/autostart/:~/.config/autostart/
exec --no-startup-id dex --autostart --environment i3
# start welcome app
#exec --no-startup-id sh /usr/share/endeavouros/scripts/welcome --startdelay=3
# num lock activated
#exec --no-startup-id numlockx on
# configure multiple keyboard layouts and hotkey to switch (Alt+CAPSLOCK in this example)
#exec --no-startup-id setxkbmap -layout 'us,sk' -variant altgr-intl,qwerty -option 'grp:alt_caps_toggle'
# start conky:
#exec_always --no-startup-id conky
# start a script to setup displays
# uncomment the next line, use arandr to setup displays and save the file as monitor:
exec --no-startup-id ~/.screenlayout/monitor.sh
# set wallpaper
#exec --no-startup-id sleep 2 && nitrogen --restore
#exec --no-startup-id variety --profle ~/.config/variety
exec --no-startup-id variety --profile ~/.config/variety
#exec_always ~/.config/i3/variety_img.py
# set powersavings for display:
#exec --no-startup-id xset s 480 dpms 600 600 600
# disable power saving (for example if using xscreensaver)
#exec --no-startup-id xset -dpms
# xscreensaver
# https://www.jwz.org/xscreensaver
#exec --no-startup-id xscreensaver --no-splash
# Desktop notifications
exec --no-startup-id dbus-launch dunst --config ~/.config/dunst/dunstrc
# alternative if you installed aside with XFCE4:
# exec --no-startup-id /usr/lib/xfce4/notifyd/xfce4-notifyd &
# autotiling script
# https://github.com/nwg-piotr/autotiling
# `yay -S autotiling ;) (it is in AUR)
#exec_always --no-startup-id autotiling
# Autostart apps as you like
#exec --no-startup-id sleep 2 && xfce4-terminal
exec --no-startup-id sleep 7 && firefox https://github.com/endeavouros-team/endeavouros-i3wm-setup/blob/main/force-knowledge.md
#exec --no-startup-id sleep 3 && thunar
# system tray #
# if you do not use dex: exec --no-startup-id dex --autostart --environment i3
# you need to have tray apps started here:
# start blueberry app for managing bluetooth devices from tray:
#exec --no-startup-id blueberry-tray
# networkmanager-applet
#exec --no-startup-id nm-applet
# clipman-applet
#exec --no-startup-id xfce4-clipman
# floating rules #
# set floating (nontiling) for apps needing it
for_window [class="Yad" instance="yad"] floating enable
for_window [class="Galculator" instance="galculator"] floating enable
for_window [class="Blueberry.py" instance="blueberry.py"] floating enable
# set floating (nontiling) for special apps
for_window [class="Xsane" instance="xsane"] floating enable
for_window [class="Pavucontrol" instance="pavucontrol"] floating enable
for_window [class="qt5ct" instance="qt5ct"] floating enable
for_window [class="Bluetooth-sendto" instance="bluetooth-sendto"] floating enable
for_window [class="Pamac-manager"] floating enable
for_window [window_role="About"] floating enable
# set border of floating window
for_window [class="urxvt"] border pixel 1
# set size of floating window
#for_window [window_role="(?i)GtkFileChooserDialog"] resize set 640 480 #to set size of file choose dialog
#for_window [class=".*"] resize set 640 480 #to change size of all floating windows
# set position of floating window
for_window [class=".*"] move position center
# color settings for bar and windows #
# Define colors variables:
set $darkbluetrans #08052be6
set $darkblue #08052b
set $lightblue #5294e2
set $urgentred #e53935
set $white #ffffff
set $black #000000
set $purple #e345ff
set $darkgrey #383c4a
set $grey #b0b5bd
set $mediumgrey #8b8b8b
set $yellowbrown #e1b700
# define colors for windows:
#class border bground text indicator child_border
client.focused $lightblue $darkblue $white $purple $mediumgrey
client.unfocused $darkblue $darkblue $grey $purple $darkgrey
client.focused_inactive $darkblue $darkblue $grey $purple $black
client.urgent $urgentred $urgentred $white $purple $yellowbrown
# bar settings (input comes from i3blocks) #
# Start i3bar to display a workspace bar
# (plus the system information i3status finds out, if available)
bar {
status_command i3blocks -c ~/.config/i3/i3blocks.conf
position bottom
# i3bar_command i3bar --transparency
# it could be that you have no primary display set: set one (xrandr --output <output> --primary)
# reference: https://i3wm.org/docs/userguide.html#_tray_output
tray_output primary
tray_padding 0
# When strip_workspace_numbers is set to yes,
# any workspace that has a name of the form
# “[n][:][NAME]” will display only the name.
strip_workspace_numbers yes
##strip_workspace_name no
colors {
separator $purple
background $darkgrey
statusline $white
# border bg txt indicator
focused_workspace $mediumgrey $grey $darkgrey $purple
active_workspace $lightblue $mediumgrey $darkgrey $purple
inactive_workspace $darkgrey $darkgrey $grey $purple
urgent_workspace $urgentred $urgentred $white $purple
# you can add different bars for multidisplay setups on each display:
# set output HDMI-0 to the display you want the bar, --transparency can be set.
# Transparency needs rgba color codes to be used where the last two letters are the transparency factor see here:
# https://gist.github.com/lopspower/03fb1cc0ac9f32ef38f4
# #08052be6 --> e6=90%
# bar {
# font pango: Noto Sans Regular 10
# status_command i3blocks -c ~/.config/i3/i3blocks-2.conf
# output HDMI-0
# position bottom
#strip_workspace_numbers yes
# colors {
# separator $purple
# background $darkbluetrans
# statusline $white
# focused_workspace $lighterblue $lighterblue $darkblue $purple
# active_workspace $lightdblue $lightdblue $darkblue $purple
# inactive_workspace $darkblue $darkblue $lightdblue $purple
# urgent_workspace $urgentred $urgentred $white $purple
# Application menu handled by rofi: #
## rofi bindings fancy application menu ($mod+d /F9 optional disabled)
bindsym $mod+d exec rofi -modi drun -show drun \
-config ~/.config/rofi/rofidmenu.rasi
#bindsym F9 exec rofi -modi drun -show drun \
# -config ~/.config/rofi/rofidmenu.rasi
## rofi bindings for window menu ($mod+t /F10 optional disabled)
bindsym $mod+t exec rofi -show window \
#bindsym F10 exec rofi -show window \
## rofi bindings to manage clipboard (install rofi-greenclip from the AUR)
#exec --no-startup-id greenclip daemon>/dev/null
#bindsym $mod+c exec --no-startup-id rofi -modi "clipboard:greenclip print" -show clipboard \
