Computer running slow after fresh install
i had to resintall because i crashed my system somehow. anyway since the reinstall everthing is loading really slow. journalctl -p3 -xb produces:
Summary
[fj@whitewolf ~]$ journalctl -p3 -xb
May 30 03:38:56 whitewolf kernel: ACPI BIOS Error (bug): Could not resolve symbol [_SB.PCI0.LPC0.EC0], AE_NOT_FOU>
May 30 03:38:56 whitewolf kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20221020/psobject-220)
May 30 03:39:00 whitewolf kernel: usb usb1-port2: unable to enumerate USB device
May 30 03:39:03 whitewolf kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
May 30 03:39:04 whitewolf kernel: amdgpu 0000:03:00.0: amdgpu: Secure display: Generic Failure.
May 30 03:39:04 whitewolf kernel: amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0>
May 30 03:39:07 whitewolf lightdm[767]: gkr-pam: unable to locate daemon control file
May 30 03:40:39 whitewolf systemd[791]: Failed to start Portal service.
β–‘β–‘ Subject: A start job for unit UNIT has failed
β–‘β–‘ Defined-By: systemd
β–‘β–‘ Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
β–‘β–‘
β–‘β–‘ A start job for unit UNIT has finished with a failure.
β–‘β–‘
β–‘β–‘ The job identifier is 148 and the job result is failed.
May 30 03:42:39 whitewolf systemd[791]: Failed to start Portal service.
β–‘β–‘
β–‘β–‘
β–‘β–‘ The job identifier is 557 and the job result is failed.
May 30 03:46:20 whitewolf systemd[791]: Failed to start Portal service.
lines 1-24…skipping…
May 30 03:38:56 whitewolf kernel: ACPI BIOS Error (bug): Could not resolve symbol [_SB.PCI0.LPC0.EC0], AE_NOT_FOUND (20221020/dswload2-162)
May 30 03:39:04 whitewolf kernel: amdgpu 0000:03:00.0: amdgpu: SECUREDISPLAY: query securedisplay TA failed. ret 0x0
β–‘β–‘
β–‘β–‘
β–‘β–‘
β–‘β–‘
β–‘β–‘
β–‘β–‘
β–‘β–‘ The job identifier is 665 and the job result is failed.
May 30 03:48:36 whitewolf systemd[791]: Failed to start Portal service.
β–‘β–‘
β–‘β–‘
β–‘β–‘ The job identifier is 709 and the job result is failed.
May 30 03:51:14 whitewolf systemd[791]: Failed to start Portal service.
β–‘β–‘
β–‘β–‘
β–‘β–‘ The job identifier is 753 and the job result is failed.
May 30 03:55:07 whitewolf systemd[791]: Failed to start Portal service.
β–‘β–‘
lines 1-53
i don’t really understand the results. if anyone could point me in the right direction that would be much appreciated. kind of blows… everything lagging so hard. running htop showed nothing that struck me as being a problem, oddly enough. i ran bashtop and it says i am not using a lot of cpu. conky also reports relativity low CPU speeds despite my apps loading incredibly slow. at most it hits like IDK 19% but most CPU’s are running around 5%.
PS: another thing i noticed was gnome and xfce desktop environments where reality fast. this seems to be primary unfortunately effecting pantheon de. idk though i am so tired my brain hurts bad, NIGHT GUYS… sweet dreams
Check:
pacman -Qs xdg-desktop
If you have xdg-desktop-portal-gnome installed on a non GNOME desktop environment, this might be the cause of sluggishness you are experiencing.
If this is the case, you could simply uninstall xdg-desktop-portal-gnome.
OMG I honestly didn’t believe it would work but I was wrong. Everything is running normal now it appears. Almost instantly it fixed the problem. OMG! THANK YOU!!!
why is xdg-desktop-portal-gnome installed on a non-gnome desktop? Is that normal?
Just a heads up, this bug has been submitted:
This also includes an alternate solution:
I know what you mean.
I have xfce only and also have this installed. :thinking:
Do you have the package flatpak installed?
Perhaps that is what pulls in xdg-desktop-portal-gnome as a dependency of xdg-desktop-portal ? :thinking:
Nope, no flatpak here.
If you want to dig further: pactree -r xdg-desktop-portal-gnome to get a reverse dependency tree for this package. Perhaps you have something else installed that has this package as dependency.
Only Lutris shows up, so this may be the one.
That must be it: https://archlinux.org/packages/extra/any/lutris/
The question is why it won’t just pull in xdg-desktop-portal-gtk instead on non GNOME DE:s :thinking:
Hmm, it seems like I have both installed, xdg-desktop-portal-gtk and xdg-desktop-portal-gnome…
