I am trying to download and compile the linux kernel according to the arch wiki. But at the step where I want to build a package
makepkg -s
I get the following error about package signature
==> Making package: linux6-custom 6.0.arch1-1 (Sat 08 Oct 2022 04:30:41 PM MDT)
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
==> Retrieving sources...
-> Updating archlinux-linux git repo...
-> Found config
==> Validating source files with sha256sums...
archlinux-linux ... Skipped
config ... Passed
==> Verifying source file signatures with gpg...
archlinux-linux git repo ... FAILED (unknown public key 3B94A80E50A477C7)
==> ERROR: One or more PGP signatures could not be verified!
I think this is also relevant if I want to download a package from the AUR and build it.
Question: Do I need to import that keyring via gpg --recv-key 3B94A80E50A477C7 , is that safe? doing a gpg --search-keys 3B94A80E50A477C7 indicates that its from Jan Alexander Steffens (heftig).
Explanation of error message: I found this on the manjaro forum that seems to explain it in better words than I could
Your user starts with an empty keyring. That is, you trust no one’s keys. When you run makepkg you run it as your normal user, so if the PKGBUILD file contains a PGP key validation will fail because you don’t trust the key - you have to import the key into your keyring first.
$ gpg --recv-keys 3B94A80E50A477C7
gpg: key 19802F8B0D70FC30: rejected by import screener
gpg: Total number processed: 1
adding that other key does not solve the problem. I don’t understand where the PKGBUILD is trying to get that key, it’s not in the list from what I can tell
PKGBUILD
# Maintainer: Jan Alexander Steffens (heftig) <heftig@archlinux.org>
pkgbase=linux6-custom
pkgver=6.0.arch1
pkgrel=1
pkgdesc='Linux'
_srctag=v${pkgver%.*}-${pkgver##*.}
url="https://github.com/archlinux/linux/commits/$_srctag"
arch=(x86_64)
license=(GPL2)
makedepends=(
bc libelf pahole cpio perl tar xz
xmlto python-sphinx python-sphinx_rtd_theme graphviz imagemagick texlive-latexextra
git
options=('!strip')
_srcname=archlinux-linux
source=(
"$_srcname::git+https://github.com/archlinux/linux?signed#tag=$_srctag"
config # the main kernel config file
validpgpkeys=(
'ABAF11C65A2970B130ABE3C479BE3E4300411886' # Linus Torvalds
'647F28654894E3BD457199BE38DBBDC86092693E' # Greg Kroah-Hartman
'A2FF3A36AAA56654109064AB19802F8B0D70FC30' # Jan Alexander Steffens (heftig)
'C7E7849466FE2358343588377258734B41C31549' # David Runge <dvzrv@archlinux.org>
sha256sums=('SKIP'
'85f7327e262056043514a24eb6c8d46e3ac6a10a6caff09d664dec8827829144')
export KBUILD_BUILD_HOST=archlinux
export KBUILD_BUILD_USER=$pkgbase
export KBUILD_BUILD_TIMESTAMP="$(date -Ru${SOURCE_DATE_EPOCH:+d @$SOURCE_DATE_EPOCH})"
prepare() {
cd $_srcname
echo "Setting version..."
scripts/setlocalversion --save-scmversion
echo "-$pkgrel" > localversion.10-pkgrel
echo "${pkgbase#linux}" > localversion.20-pkgname
local src
for src in "${source[@]}"; do
src="${src%%::*}"
src="${src##*/}"
[[ $src = *.patch ]] || continue
echo "Applying patch $src..."
patch -Np1 < "../$src"
done
echo "Setting config..."
cp ../config .config
make olddefconfig
diff -u ../config .config || :
make -s kernelrelease > version
echo "Prepared $pkgbase version $(<version)"
build() {
cd $_srcname
make htmldocs
_package() {
pkgdesc="The $pkgdesc kernel and modules"
depends=(coreutils kmod initramfs)
optdepends=('wireless-regdb: to set the correct wireless channels of your country'
'linux-firmware: firmware images needed for some devices')
provides=(VIRTUALBOX-GUEST-MODULES WIREGUARD-MODULE KSMBD-MODULE)
replaces=(virtualbox-guest-modules-arch wireguard-arch)
cd $_srcname
local kernver="$(<version)"
local modulesdir="$pkgdir/usr/lib/modules/$kernver"
echo "Installing boot image..."
# systemd expects to find the kernel here to allow hibernation
# https://github.com/systemd/systemd/commit/edda44605f06a41fb86b7ab8128dcf99161d2344
install -Dm644 "$(make -s image_name)" "$modulesdir/vmlinuz"
# Used by mkinitcpio to name the kernel
echo "$pkgbase" | install -Dm644 /dev/stdin "$modulesdir/pkgbase"
echo "Installing modules..."
make INSTALL_MOD_PATH="$pkgdir/usr" INSTALL_MOD_STRIP=1 \
DEPMOD=/doesnt/exist modules_install # Suppress depmod
# remove build and source links
rm "$modulesdir"/{source,build}
_package-headers() {
pkgdesc="Headers and scripts for building modules for the $pkgdesc kernel"
depends=(pahole)
cd $_srcname
local builddir="$pkgdir/usr/lib/modules/$(<version)/build"
echo "Installing build files..."
install -Dt "$builddir" -m644 .config Makefile Module.symvers System.map \
localversion.* version vmlinux
install -Dt "$builddir/kernel" -m644 kernel/Makefile
install -Dt "$builddir/arch/x86" -m644 arch/x86/Makefile
cp -t "$builddir" -a scripts
# required when STACK_VALIDATION is enabled
install -Dt "$builddir/tools/objtool" tools/objtool/objtool
# required when DEBUG_INFO_BTF_MODULES is enabled
install -Dt "$builddir/tools/bpf/resolve_btfids" tools/bpf/resolve_btfids/resolve_btfids
echo "Installing headers..."
cp -t "$builddir" -a include
cp -t "$builddir/arch/x86" -a arch/x86/include
install -Dt "$builddir/arch/x86/kernel" -m644 arch/x86/kernel/asm-offsets.s
install -Dt "$builddir/drivers/md" -m644 drivers/md/*.h
install -Dt "$builddir/net/mac80211" -m644 net/mac80211/*.h
# https://bugs.archlinux.org/task/13146
install -Dt "$builddir/drivers/media/i2c" -m644 drivers/media/i2c/msp3400-driver.h
# https://bugs.archlinux.org/task/20402
install -Dt "$builddir/drivers/media/usb/dvb-usb" -m644 drivers/media/usb/dvb-usb/*.h
install -Dt "$builddir/drivers/media/dvb-frontends" -m644 drivers/media/dvb-frontends/*.h
install -Dt "$builddir/drivers/media/tuners" -m644 drivers/media/tuners/*.h
# https://bugs.archlinux.org/task/71392
install -Dt "$builddir/drivers/iio/common/hid-sensors" -m644 drivers/iio/common/hid-sensors/*.h
echo "Installing KConfig files..."
find . -name 'Kconfig*' -exec install -Dm644 {} "$builddir/{}" \;
echo "Removing unneeded architectures..."
local arch
for arch in "$builddir"/arch/*/; do
[[ $arch = */x86/ ]] && continue
echo "Removing $(basename "$arch")"
rm -r "$arch"
done
echo "Removing documentation..."
rm -r "$builddir/Documentation"
echo "Removing broken symlinks..."
find -L "$builddir" -type l -printf 'Removing %P\n' -delete
echo "Removing loose objects..."
find "$builddir" -type f -name '*.o' -printf 'Removing %P\n' -delete
echo "Stripping build tools..."
local file
while read -rd '' file; do
case "$(file -bi "$file")" in
application/x-sharedlib\;*) # Libraries (.so)
strip -v $STRIP_SHARED "$file" ;;
application/x-archive\;*) # Libraries (.a)
strip -v $STRIP_STATIC "$file" ;;
application/x-executable\;*) # Binaries
strip -v $STRIP_BINARIES "$file" ;;
application/x-pie-executable\;*) # Relocatable binaries
esac
done < <(find "$builddir" -type f -perm -u+x ! -name vmlinux -print0)
echo "Stripping vmlinux..."
strip -v $STRIP_STATIC "$builddir/vmlinux"
echo "Adding symlink..."
mkdir -p "$pkgdir/usr/src"
ln -sr "$builddir" "$pkgdir/usr/src/$pkgbase"
_package-docs() {
pkgdesc="Documentation for the $pkgdesc kernel"
cd $_srcname
echo "Installing documentation..."
local src dst
while read -rd '' src; do
dst="${src#Documentation/}"
dst="$builddir/Documentation/${dst#output/}"
install -Dm644 "$src" "$dst"
done < <(find Documentation -name '.*' -prune -o ! -type d -print0)
mkdir -p "$pkgdir/usr/share/doc"
ln -sr "$builddir/Documentation" "$pkgdir/usr/share/doc/$pkgbase"
pkgname=("$pkgbase" "$pkgbase-headers")
for _p in "${pkgname[@]}"; do
eval "package_$_p() {
$(declare -f "_package${_p#$pkgbase}")
done
# vim:set ts=8 sts=2 sw=2 et:
