Command systemd-id-machineid-setup finished with exit code 127
I downloaded the ISO yesterday and im unable to install endeavour os for some reason.
Welcome to the forum! :smile:
Maybe mirrors are not working properly?
Please try fixing mirrors with command reflector-simple before install.
What does machineid have to do with mirrors?
BTW, I face the same issue on installation.
Logs do not include any sign of this error, it is only a popup message and calamares closes, with terminal staying open and stalled during downloading packages.
Edit: my case was from a multiboot USB (manual boot from grub cmdline, actually).
Using a normally written USB installer my installation was successful, without this error.
Now, I have to learn BSPWM navigation… :grimacing:
I am having the same error and I cannot figure out why.
My USB is formatted fine. I only get this error when I try to install with KDE online. If I go offline, it will finish, but the OS will not update at all. Fails every time.
I will try once more from a fresh USB.
I had the same issue with the online installer, had to use the offline installer for it to work. Last time I had used the offline installer, on the august ISO, it gave me a broken system. I hope this issue gets patched.
Please feel free to use the latest ISO. EndeavourOS is a rolling release distribution.
I used the latest ISO. I was just mentioning my bad experience with offline install at an earlier time. I don’t really trust the offline installer because of it.
What was broken?
I can’t remember. All I know was that it was bad enough for a reinstall. My apps probably weren’t working. Anyway, that was a long time ago and I have never had issues with offline installs since. The only thing I am annoyed about is the online installer not working because of this error.
Can you return:
inxi -Fxxxza --no-host
  Kernel: 5.16.3-xanmod1-linux-xanmod-edge x86_64 bits: 64 compiler: gcc
    v: 11.1.0 parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod-edge
    root=UUID=666d0e81-dbc3-4298-b5d4-6f0dbe3a3aec rw rootflags=subvol=@
    loglevel=3 nowatchdog mitigations=off amdgpu.ppfeaturemask=0xffffffff
    cpufreq.default_governor=performance pcie_aspm=off pci=pcie_bus_perf
    pcie_ports=native pti=off tsc=nowatchdog threadirqs io_delay=none
    ecrc=off workqueue.power_efficient=0 libahci.ignore_sss=1
    scsi_mod.use_blk_mq=1 cryptomgr.notests elevator=bfq noreplace-smp
    rcupdate.rcu_expedited=1 psi=0 clearcpuid=514 psi=0 clearcpuid=514
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
    vt: 7 dm: LightDM 1.30.0 Distro: EndeavourOS base: Arch Linux
  Mobo: ASUSTeK model: TUF GAMING X570-PRO (WI-FI) v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 4021
    date: 08/10/2021
  Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+
    family: 0x17 (23) model-id: 8 stepping: 2 microcode: 0x800820D
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB
    L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 3999 high: 4000 min/max: N/A cores: 1: 4000 2: 4000
    3: 4000 4: 4000 5: 4000 6: 4000 7: 4000 8: 3988 9: 4000 10: 4000 11: 4000
    12: 4000 13: 4000 14: 4000 15: 4000 16: 4000 bogomips: 127998
  Vulnerabilities:
  Type: spec_store_bypass status: Vulnerable
  Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
    usercopy barriers only; no swapgs barriers
  Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled
  Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
    vendor: Tul driver: amdgpu v: kernel bus-ID: 0a:00.0 chip-ID: 1002:731f
    class-ID: 0300
  Display: x11 server: X.Org 1.21.1.3 compositor: xfwm4 v: 4.16.1 driver:
    loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
    s-diag: 1055mm (41.5")
  Monitor-1: DisplayPort-0 res: 1920x1080 dpi: 90
    size: 544x303mm (21.4x11.9") diag: 623mm (24.5")
  Monitor-2: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 93
    size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
  OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.44.0
    5.16.3-xanmod1-linux-xanmod-edge LLVM 13.0.0)
    v: 4.6 Mesa 21.3.5 direct render: Yes
  Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
    bus-ID: 0a:00.1 chip-ID: 1002:ab38 class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel bus-ID: 0c:00.3 chip-ID: 1022:1457 class-ID: 0403
  Device-3: Samson Q2U handheld mic with XLR type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-2:2 chip-ID: 17a0:0304
    class-ID: 0300
  Sound Server-1: ALSA v: k5.16.3-xanmod1-linux-xanmod-edge running: yes
  Sound Server-2: sndio v: N/A running: no
  Sound Server-3: PulseAudio v: 15.0 running: no
  Sound Server-4: PipeWire v: 0.3.44 running: yes
  Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
    port: N/A bus-ID: 04:00.0 chip-ID: 8086:15f3 class-ID: 0200
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 2.52 TiB used: 299.43 GiB (11.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B
    speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 004C
    temp: 37.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Micron model: 1100 MTFDDAV256TBN
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: A020 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate
    model: ST2000LM003 HN-M201RAD size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
    rev: 0001 scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
    used: 299.42 GiB (62.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
    used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
  ID-4: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
  System Temperatures: cpu: 39.2 C mobo: N/A gpu: amdgpu temp: 54.0 C
    mem: 50.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 1287
  Processes: 426 Uptime: 24m wakeups: 0 Memory: 15.54 GiB
  used: 2.74 GiB (17.6%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 2417 lib: 567 flatpak: 0
  Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.12
I’m receiving the same error. Fairly new to Linux and chose to erase and replace windows. I’ve only tried the online installation because I want to use vanilla and gnome. Is it fairly simple to install these after doing an offline installation with xfce? Here’s my log
https://termbin.com/82cl
Thanks
sound something on your disk space, on which disk you want to install ?
