I have free time again and have done a new, clean installation of EOS with KDE.
I installed ClamTK from the terminal (yay -S clamtk), which supposedly I think you don’t need to install ClamAV (right?), but when I scan, for example, a directory, this message appears, but in reality it didn’t scan anything, since this message appears right when I press the button, and the scanned file count below is “0”.
What am I doing wrong? Does ClamTK supposedly install ClamAV as a dependency, automatically, or something?
Thanks friend, but I installed yay -S clamav and it still doesn’t work.
Thank you very much friend, it worked! So the “refresh” button in the graphical interface does not work?
By the way, is there any advantage in using the clamav (terminal) version vs clamtk (graphical interface)? (apart from the problem you just solved).
Thank you very much friend, it worked! Normally I just want to examine some windows .exe files that I download to run with wine, and I want to know if they have viruses.
If there is no advantage, perhaps it is faster to select the new downloaded folder through a graphical interface?
Even though I would say that the GUI (clamtk) should in principle work equally well, at this point of time it hasn’t seen an update in the Arch repos for almost a year. Something I find rather strange since it was also flagged out of date for less than a year ago.
The version in Arch’s repo is 6.14-1 while the latest release is 6.18.
