Cinnamon 6.8.x: Shift zoom modifier suppresses all mouse input on X11
After upgrading from Cinnamon 6.6.9 / Muffin 6.6.3 to Cinnamon 6.8.0 / Muffin 6.8.1 around November 8, shift-click selection stopped working in Nemo.
Further testing showed this is not Nemo-specific: while <Shift> is held, all mouse input appears to stop, including pointer movement and clicks. In xorg-xev, no pointer events are reported while Shift is down.
The issue is per-user: a fresh user profile does not reproduce it.
Comparing settings identified desktop zoom configured with <Shift> as its mouse-wheel modifier (mouse-button-zoom-modifier='<Shift>').
Changing the modifier to <Alt> (the default) restores mouse input.
I also tested from an LMDE 7 live ISO running Cinnamon 6.4.x.
Setting the zoom modifier to <Shift> there did not cause the issue.
This suggests a regression between Cinnamon/Muffin 6.4.x and 6.8.x.
The affected system currently has Cinnamon 6.8.2 / Muffin 6.8.4.
Can anyone confirm or point to a relevant change?
Thanks, Michael.
In this case, it’s best to speak with the Linux Mint team more directly to find out what changed and/or to report bugs.
Their GitHub issue/bug tracker: https://github.com/linuxmint/cinnamon/issues
Sadly, the Linux Mint team doesn’t provide a comprehensive changelog on their GitHub, and they haven’t done a blog update (that addresses any related change) between this update and the previous one (yet).
Their blog: https://blog.linuxmint.com/
So, you’d have to check their GitHub for several updates between the last version and this one (August-November), and that is just too much to go through for most people.
Excerpt from the changelog provided so far from their GitHub:
cinnamon_6.8.3_amd64.changes
Date: Thu, 19 Nov 2026 10:05:18 +0000
Source: cinnamon
Architecture: source all amd64
Version: 6.8.3
   [ Clement Lefebvre ]
   * favorite-apps: Switch from gnome-calendar to Clockenstein
   [ Michael Webster ]
   * screensaver: Fix activation with no monitors connected
   * cs_backgrounds.py: Resolve symlinks when matching collection pictures
   * screenShield.js: Add button tooltips, make error label more visible
   * unlockDialog.js: Re-conceal the password entry each time
   * unlockDialog.js: Don't make the user avatar reactive.
You can also check the changes like this: https://github.com/linuxmint/cinnamon/compare/master.mint22...master.mint27
PS: Don’t hold your breath for them providing a comprehensive update unless it’s about visual or app-related changes, which they would provide through their blog.
