Chromium needs libre2.so.10 but it has been updated to libre2.so.11
Hello.
Apparently there is a compatibility problem between packages in my ARM installation of EOS on my Raspberry PI:
$ chromium
/usr/lib/chromium/chromium: error while loading shared libraries: libre2.so.10: cannot open shared object file: No such file or directory
$ ldd /usr/lib/chromium/chromium | grep re2
libre2.so.10 => not found
libpcre2-8.so.0 => /usr/lib/libpcre2-8.so.0 (0x0000007f96460000)
$ pacman -Ql re2 | grep libre2
re2 /usr/lib/libre2.so
re2 /usr/lib/libre2.so.11
re2 /usr/lib/libre2.so.11.0.0
Of course I updated everything with pacman -Syu, yesterday, today, 5 minutes ago.
Thank you in advance if anyone can help me.
I am not using arm EOS, but I had a similar issue while trying to resolve another issue with the latest chromium, which resulted in me trying to downgrade chromium
downgraded chromium (116.0.5845.96-1 -> 115.0.5790.170-1)
(Then I was getting the exact same error)
What is the version of chromium on your system?
If it is 115.X then I think that’s your problem
I believe libre2.so.11 is intended to target chromium 116.X
Chromium seems to be on 115.X on:
https://archlinuxarm.org/packages
You could try downgrading re2 from your pacman cache. In my case (x86_64) this was:
sudo pacman -U /var/cache/pacman/pkg/re2-1:20230301-1-x86_64.pkg.tar.zst
it is simply chromium package will need a rebuild…
https://archlinuxarm.org/packages/aarch64/chromium
Build Date: Thu Aug 3 13:03:32 2023 UTC
https://archlinuxarm.org/packages/aarch64/re2
Build Date: Wed Aug 16 00:18:43 2023 UTC
Yes, you are right, my version of Chromium is 115.
Rather than manually downgrade re2, I prefer to wait for Chromium to be updated to version 116 and use GNOME Web (Epiphany) instead in the meantime. I assume and hope that Chromium will be updated in the next few days.
Yes, I hope it will be released in the repositories in the next few days
I checked up on this.
As @joekamprad pointed out, the PKGBUILD was updated 4 days ago.
However. the new package is not in the Archlinux Arm aarch64 repository yet.
So I created the following thread over at the Arch Linux ARM forum.
https://archlinuxarm.org/forum/viewtopic.php?f=15&t=16573
Hopefully, this can get resolved in the near future.
Pudge
Thank you very much :slightly_smiling_face:
haha @joekamprad
yea got me… just checked pudges post and wanted to write confirm…
And if you really need it… flatpak to the rescue :wink:
Yeah, because that will work with widevine… not.
hey welome to the forum. :enos:. you mean the flatpak does not have widivine support?
(was not testing that far)
no response and no change on the package…
last change yesterday without … already multiple commits to 116 version but not possible to build …
I know it is not a nice job to maintain Browser packages, always a lot of patches and changes and build fails en masse…
Archlinux ARM has resolved this issue. chromium-117.0.5938.48-1 has been released in the aarch64 extra repository.
After updating, chromium now boots OK.
Pudge
Thank you.
