Any chromium based application, including all electron applications are unusably slow. I can alleviate the problem somewhat by turning off hardware acceleration, but not all electron apps have that options, and I cannot use webgl with hardware acceleration off.
Here is some info about my system:
uname -r
5.18.5-arch1-g14-1
inxi -CG
Info: 8-core model: AMD Ryzen 9 5900HS with Radeon Graphics bits: 64
type: MT MCP cache: L2: 4 MiB
Speed (MHz): avg: 3566 min/max: 400/4680 cores: 1: 3440 2: 3516 3: 3515
4: 3570 5: 3572 6: 3510 7: 2993 8: 3545 9: 3569 10: 3268 11: 3157 12: 3563
13: 4351 14: 4452 15: 3487 16: 3559
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] driver: nvidia
v: 515.57
Device-2: AMD Cezanne driver: amdgpu v: kernel
Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: amdgpu,nvidia
unloaded: fbdev,modesetting,vesa gpu: amdgpu,nvidia,nvidia-nvswitch
resolution: 1: 5120x2160~60Hz 2: 5120x2160~60Hz 3: 5120x2160~30Hz
4: 2560x1440~165Hz
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.46 5.18.5-arch1-g14-1)
v: 4.6 Mesa 22.1.3
upergfxctl -g
hybrid
glxinfo | grep OpenGL
OpenGL vendor string: AMD
OpenGL renderer string: AMD RENOIR (LLVM 14.0.6, DRM 3.46, 5.18.5-arch1-g14-1)
OpenGL core profile version string: 4.6 (Core Profile) Mesa 22.1.3
OpenGL core profile shading language version string: 4.60
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.6 (Compatibility Profile) Mesa 22.1.3
OpenGL shading language version string: 4.60
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 22.1.3
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
I am running I3WM
Just out of the curiosity, is this a custom kernel?
The current kernel from the repos is linux 5.18.9.arch1-1.
Yes, forgot to mention, I followed this article as well: https://asus-linux.org/wiki/arch-guide/
Just the “Custom kernel - drivers fixes, hardware support” section
Not sure if switching to the repo kernels would resolve your issue but personally I would try it.
sudo pacman -S linux-zen linux-zen-headers
Reboot and choose the zen kernel.
Also perhaps post a full inxi report:
inxi -Fxxxaz
and
journalctl -b -0 | eos-sendlog
and post the URL.
Hopefully this would give forum members some info to get troubleshooting going.
Yeah, that’s kinda obvious. Electron sucks.
I have a relatively powerful PC and Electron-based applications are unusably slow, too.
Zen does not seem to have helped.
inxi -Fxxxaz
Kernel: 5.18.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=2538f2e8-bac3-4ba8-aa8c-de55923d0c0e rw rootflags=subvol=@
quiet loglevel=3 nowatchdog
Desktop: i3 v: 4.20.1 info: i3bar vt: 7 dm: LightDM v: 1.30.0
Type: Laptop System: ASUSTeK product: ROG Zephyrus G15 GA503QM_GA503QM
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: GA503QM v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: GA503QM.412 date: 11/03/2021
Battery:
ID-1: BAT0 charge: 24.5 Wh (31.3%) condition: 78.2/90.0 Wh (86.9%)
volts: 15.9 min: 15.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: charging
Device-1: hidpp_battery_0 model: Logitech ERGO M575 Trackball
serial: <filter> charge: 80% rechargeable: yes status: discharging
Info: model: AMD Ryzen 9 5900HS with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
model-id: 0x50 (80) stepping: 0 microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3632 high: 4186 min/max: 1200/4679 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3503 2: 3516
3: 3524 4: 3509 5: 3490 6: 3481 7: 3494 8: 3489 9: 3493 10: 3473 11: 3677
12: 4186 13: 3486 14: 3489 15: 4137 16: 4170 bogomips: 105400
Vulnerabilities:
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl
Type: spectre_v1
STIBP: always-on, RSB filling
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 ports: active: none off: DP-1,DP-2 empty: none
bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-2: AMD Cezanne vendor: ASUSTeK driver: amdgpu v: kernel
arch: GCN 5.1 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: HDMI-A-1,eDP-1 empty: none bus-ID: 06:00.0 chip-ID: 1002:1638
class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 compositor: Picom v: git-7e568
driver: X: loaded: amdgpu,nvidia unloaded: fbdev,modesetting,vesa
alternate: nouveau,nv gpu: amdgpu,nvidia,nvidia-nvswitch display-ID: :0
screens: 1
Screen-1: 0 s-res: 15360x3600 s-dpi: 96
s-size: 4064x952mm (160.00x37.48") s-diag: 4174mm (164.33")
Monitor-1: DP-1 mapped: DP-1-0 note: disabled pos: primary,1-3
model: Dell U4021QW serial: <filter> built: 2021 res: 5120x2160 hz: 60
dpi: 140 gamma: 1.2 size: 930x390mm (36.61x15.35") diag: 1008mm (39.7")
modes: max: 2560x1080 min: 640x480
Monitor-2: DP-2 mapped: DP-1-2 note: disabled pos: 1-2
Monitor-3: HDMI-A-1 mapped: HDMI-A-0 pos: primary,1-1 model: Dell U4021QW
serial: <filter> built: 2021 res: 5120x2160 hz: 30 dpi: 140 gamma: 1.2
size: 929x392mm (36.57x15.43") diag: 1008mm (39.7") modes: max: 2560x1080
min: 720x400
Monitor-4: eDP-1 mapped: eDP pos: 2-4 model: ChiMei InnoLux 0x152a
built: 2020 res: 2560x1440 hz: 165 dpi: 189 gamma: 1.2
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.46 5.18.9-zen1-1-zen)
v: 4.6 Mesa 22.1.3 direct render: Yes
Device-1: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:228e class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_sof_amd_renoir
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h/19h HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.18.9-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.21 running: no
Sound Server-3: PulseAudio v: 16.1 running: yes
Sound Server-4: PipeWire v: 0.3.53 running: yes
vendor: ASUSTeK driver: N/A modules: r8169 pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:7961 class-ID: 0280
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 3-1.1.2:8 chip-ID: 0bda:8153 class-ID: 0000
serial: <filter>
IF: enp6s0f4u1u1u2 state: down mac: <filter>
Device-4: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 3-2.1.2:10 chip-ID: 0bda:8153 class-ID: 0000
serial: <filter>
IF: enp6s0f4u2u1u2 state: down mac: <filter>
IF-ID-1: cni0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: docker0 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: flannel.1 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-4: veth0cd5760 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-5: vethe6b5d707 state: up speed: 10000 Mbps duplex: full
mac: <filter>
Bluetooth:
Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 1-4:5 chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 2 state: up address: see --recommends
Local Storage: total: 1.82 TiB used: 395.37 GiB (21.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SWORDFISH
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: VC0S0302 temp: 64.8 C
scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 395.37 GiB (21.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
ID-4: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 63.0 C
Fan Speeds (RPM): cpu: 4400
Processes: 379 Uptime: 8m wakeups: 5 Memory: 38.59 GiB
used: 7.02 GiB (18.2%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 Packages: pacman: 1185 lib: 268
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.19
% Total % Received % Xferd Average Speed Time Time Time Current
100 417k 100 24 100 417k 32 571k --:--:-- --:--:-- --:--:-- 570k
https://clbin.com/tKOGP
Are you using integrated graphics?
If so a lot of forum answers for similar issues say Are you using integrated graphics? If so, starting electron apps with --disable-gpu might work.
This is the laptop I have: https://rog.asus.com/laptops/rog-zephyrus/2021-rog-zephyrus-g15-series/helpdesk
I am running three external displays, two out of the USB-C ports and one from the HDMI port. The HDMI port is connected to the integrated graphics and the USB-C ports are connected to the discrete graphics. So both gpus are running. Is there a way to force applications globally to use the discrete GPU?
Predictable. You can’t fix bad program design by installing a different kernel.
When it comes to Electron, the only thing that really helps is not to use these rubbish programs. Or, if you absolutely need them, endure the painful slowness. But in my experience, there are very few programs one absolutely needs, and none of them are Electron-based.
Yeah I don’t think there is any way to force the gpu to be the discrete one.
There is a bug that has been open for four years on the electron github page that basically is what you are probably experiencing (https://github.com/electron/electron/issues/9842)
Everyone there basically says what everyone here is saying, which is that it is impossible to fix this issue and the developers won’t fix it either. The electron apps will “choose” what GPU to use based on the chromium engine they are using. It sounds like it “chooses” wrong.
This one guy says he has a discrete and dedicated gpu and his fix was removing a variable that he had set for another issue: https://github.com/electron/electron/issues/9842#issuecomment-1120948216
On this github issue it looks like they still generate the gpu thread which means that you are still going to eat lots of battery if you ever go off power and wanted to even use the more efficient gpu… (https://github.com/electron/electron/issues/17180)
The generic way for Nvidia is
prime-run /usr/bin/application
