Hey all! Running base Arch at the moment, and after some help by someone from the community I managed to install reFind and ditch Grub.
The next rather minor hurdle, is installing a theme that’s prettier than reFinds rather lacklustre one, and thankfully they exist in abundance.
Technically, installing a theme should be easy, as per the instructions you create a /themes folder at your /boot/efi/refind folder, copy the folder for the theme there and then add to your refind.conf:
include themes/folder-name-for-the-theme/theme.conf
And that should be it…
Except after trying with 4 different themes it never seems to work, with no changes happening.
I was wondering if perhaps the online guides are missing something, or maybe the fact that my HDD is formated as BTRFS changes something?
Thank you!
