Changing lockscreen wallpaper
I’ve had a half success with this: When I boot up, the desired wallpaper is displayed, however, once I’ve done my initial login, if I lock the screen, it’s back to the default.
Here’s my /etc/lightdm/slick-greeter.conf
[Greeter]
background=/usr/share/pixmaps/cat.jpg
draw-user-backgrounds=false
draw-grid=true
theme-name=Arc-Dark
icon-theme-name=Qogir
cursor-theme-name=Qogir
cursor-theme-size=16
show-a11y=false
show-power=false
background-color=#000000
I installed lightdm-settings as another answer suggested, but it has no option that distinguishes lockscreen wallpaper from the login wallpaper and didn’t change a thing, so I removed it
Thanks
Unfortunately not
these are two different things.
DM and locker…
https://wiki.archlinux.org/title/Xfce#Lock_the_screen
How do I remedy this? sorry.
There are many files, I’ll post them all here.
/etc/lightdm/lightdm.conf.d/:
[LightDM]
logind-check-graphical=true
[Seat:*]
greeter-session=lightdm-slick-greeter
allow-user-switching=true
/etc/lightdm/keys.conf
[keyring]
#a=0x0123456789ABCD
#b=secret
/etc/lightdm/users.conf
# User accounts configuration
# NOTE: If you have AccountsService installed on your system, then LightDM will
# use this instead and these settings will be ignored
# minimum-uid = Minimum UID required to be shown in greeter
# hidden-users = Users that are not shown to the user
# hidden-shells = Shells that indicate a user cannot login
[UserList]
minimum-uid=1000
hidden-users=nobody nobody4 noaccess
hidden-shells=/bin/false /usr/bin/nologin /bin/nologin /sbin/nologin
[Seat:*]
# General configuration
# start-default-seat = True to always start one seat if none are defined in the configuration
# greeter-user = User to run greeter as
# minimum-display-number = Minimum display number to use for X servers
# minimum-vt = First VT to run displays on
# lock-memory = True to prevent memory from being paged to disk
# user-authority-in-system-dir = True if session authority should be in the system location
# guest-account-script = Script to be run to setup guest account
# logind-check-graphical = True to on start seats that are marked as graphical by logind
# log-directory = Directory to log information to
# run-directory = Directory to put running state in
# cache-directory = Directory to cache to
# sessions-directory = Directory to find sessions
# remote-sessions-directory = Directory to find remote sessions
# greeters-directory = Directory to find greeters
# backup-logs = True to move add a .old suffix to old log files when opening new ones
# dbus-service = True if LightDM provides a D-Bus service to control it
[LightDM]
#start-default-seat=true
#greeter-user=lightdm
#minimum-display-number=0
#minimum-vt=7 # Setting this to a value < 7 implies security issues, see FS#46799
#lock-memory=true
#user-authority-in-system-dir=false
#guest-account-script=guest-account
#logind-check-graphical=true
#log-directory=/var/log/lightdm
run-directory=/run/lightdm
#cache-directory=/var/cache/lightdm
#sessions-directory=/usr/share/lightdm/sessions:/usr/share/xsessions:/usr/share/wayland-sessions
#remote-sessions-directory=/usr/share/lightdm/remote-sessions
#greeters-directory=$XDG_DATA_DIRS/lightdm/greeters:$XDG_DATA_DIRS/xgreeters
#backup-logs=true
#dbus-service=true
# Seat configuration
# Seat configuration is matched against the seat name glob in the section, for example:
# [Seat:*] matches all seats and is applied first.
# [Seat:seat0] matches the seat named "seat0".
# [Seat:seat-thin-client*] matches all seats that have names that start with "seat-thin-client".
# type = Seat type (local, xremote)
# pam-service = PAM service to use for login
# pam-autologin-service = PAM service to use for autologin
# pam-greeter-service = PAM service to use for greeters
# xserver-command = X server command to run (can also contain arguments e.g. X -special-option)
# xmir-command = Xmir server command to run (can also contain arguments e.g. Xmir -special-option)
# xserver-config = Config file to pass to X server
# xserver-layout = Layout to pass to X server
# xserver-allow-tcp = True if TCP/IP connections are allowed to this X server
# xserver-share = True if the X server is shared for both greeter and session
# xserver-hostname = Hostname of X server (only for type=xremote)
# xserver-display-number = Display number of X server (only for type=xremote)
# xdmcp-manager = XDMCP manager to connect to (implies xserver-allow-tcp=true)
# xdmcp-port = XDMCP UDP/IP port to communicate on
# xdmcp-key = Authentication key to use for XDM-AUTHENTICATION-1 (stored in keys.conf)
# greeter-session = Session to load for greeter
# greeter-hide-users = True to hide the user list
# greeter-allow-guest = True if the greeter should show a guest login option
# greeter-show-manual-login = True if the greeter should offer a manual login option
# greeter-show-remote-login = True if the greeter should offer a remote login option
# user-session = Session to load for users
# allow-user-switching = True if allowed to switch users
# allow-guest = True if guest login is allowed
# guest-session = Session to load for guests (overrides user-session)
# session-wrapper = Wrapper script to run session with
# greeter-wrapper = Wrapper script to run greeter with
# guest-wrapper = Wrapper script to run guest sessions with
# display-setup-script = Script to run when starting a greeter session (runs as root)
# display-stopped-script = Script to run after stopping the display server (runs as root)
# greeter-setup-script = Script to run when starting a greeter (runs as root)
# session-setup-script = Script to run when starting a user session (runs as root)
# session-cleanup-script = Script to run when quitting a user session (runs as root)
# autologin-guest = True to log in as guest by default
# autologin-user = User to log in with by default (overrides autologin-guest)
# autologin-user-timeout = Number of seconds to wait before loading default user
# autologin-session = Session to load for automatic login (overrides user-session)
# autologin-in-background = True if autologin session should not be immediately activated
# exit-on-failure = True if the daemon should exit if this seat fails
[Seat:*]
#type=local
#pam-service=lightdm
#pam-autologin-service=lightdm-autologin
#pam-greeter-service=lightdm-greeter
#xserver-command=X
#xmir-command=Xmir
#xserver-config=
#xserver-layout=
#xserver-allow-tcp=false
#xserver-share=true
#xserver-hostname=
#xserver-display-number=
#xdmcp-manager=
#xdmcp-port=177
#xdmcp-key=
#greeter-hide-users=false
#greeter-allow-guest=true
#greeter-show-manual-login=false
#greeter-show-remote-login=true
user-session=xfce
#allow-user-switching=true
#allow-guest=true
#guest-session=
session-wrapper=/etc/lightdm/Xsession
#greeter-wrapper=
#guest-wrapper=
#display-setup-script=
#display-stopped-script=
#greeter-setup-script=
#session-setup-script=
#session-cleanup-script=
#autologin-guest=false
#autologin-user=
#autologin-user-timeout=0
#autologin-in-background=false
#autologin-session=
#exit-on-failure=false
# XDMCP Server configuration
# enabled = True if XDMCP connections should be allowed
# port = UDP/IP port to listen for connections on
# listen-address = Host/address to listen for XDMCP connections (use all addresses if not present)
# key = Authentication key to use for XDM-AUTHENTICATION-1 or blank to not use authentication (stored in keys.conf)
# hostname = Hostname to report to XDMCP clients (defaults to system hostname if unset)
# The authentication key is a 56 bit DES key specified in hex as 0xnnnnnnnnnnnnnn.  Alternatively
# it can be a word and the first 7 characters are used as the key.
[XDMCPServer]
#enabled=false
#port=177
#listen-address=
#key=
#hostname=
# VNC Server configuration
# enabled = True if VNC connections should be allowed
# command = Command to run Xvnc server with
# port = TCP/IP port to listen for connections on
# listen-address = Host/address to listen for VNC connections (use all addresses if not present)
# width = Width of display to use
# height = Height of display to use
# depth = Color depth of display to use
[VNCServer]
#enabled=false
#command=Xvnc
#port=5900
#listen-address=
#width=1024
#height=768
#depth=8
/etc/lightdm/lightdm-gtk-greeter.conf (i believe this is a residual file from trying to fix this issue)
[greeter]
background = /usr/share/pixmaps/cat.jpg
#!/bin/sh
# LightDM wrapper to run around X sessions.
echo "Running X session wrapper"
# Load profile
for file in "/etc/profile" "$HOME/.profile" "/etc/xprofile" "$HOME/.xprofile"; do
    if [ -f "$file" ]; then
        echo "Loading profile from $file";
        . "$file"
    fi
done
# Load resources
for file in "/etc/X11/Xresources" "$HOME/.Xresources"; do
        echo "Loading resource: $file"
        xrdb -merge "$file"
    fi
done
# Load keymaps
for file in "/etc/X11/Xkbmap" "$HOME/.Xkbmap"; do
        echo "Loading keymap: $file"
        setxkbmap `cat "$file"`
        XKB_IN_USE=yes
    fi
done
# Load xmodmap if not using XKB
if [ -z "$XKB_IN_USE" ]; then
    for file in "/etc/X11/Xmodmap" "$HOME/.Xmodmap"; do
           echo "Loading modmap: $file"
           xmodmap "$file"
        fi
    done
fi
unset XKB_IN_USE
# Run all system xinitrc shell scripts
xinitdir="/etc/X11/xinit/xinitrc.d"
if [ -d "$xinitdir" ]; then
    for script in $xinitdir/*; do
        echo "Loading xinit script $script"
        if [ -x "$script" -a ! -d "$script" ]; then
            . "$script"
        fi
    done
fi
# Run user xsession shell script
script="$HOME/.xsession"
    echo "Loading xsession script $script"
    . "$script"
fi
echo "X session wrapper complete, running session $@"
exec $@
xfce4 is not using lightdm to lock the screen.
you could chnage to use lightlocker and install light-locker-settings to set background.
I should not have tried to help without a working Xfce to look at; just going off the 3 years of recent experience. Probably would be best to delete my previous posts to prevent further confusion.
the background for the xflock is the same as users wallpaper.
https://archlinux.org/packages/extra/x86_64/xfce4-screensaver/
is the default used.
xflock4 is the reference Bash script which is used to lock an Xfce session.
It tries to lock the screen with either xfce4-screensaver (also part of xfce4-goodies), xscreensaver or light-locker. It consecutively looks for the corresponding binary or exits with return code 1 if it fails to find any of these.
source:
so as you can see you can change it to use light-locker (also not light-dm) set this as the default and install https://aur.archlinux.org/packages/light-locker-settings from AUR to setup timings…
And it will use the same look and feel you use for the lightdm screen.
