Hi all, I’m new to endeavouros, though I’m not new to Linux at all
I want to create a sync/backup folder on a hard drive that is connected to my router. I have FTP access to the drive, and I have unison setup to sync the files. The problem is that unison fails because I cannot change the names of the files on the hard drive.
For what it worth, after each attempt I did to change this line (adding/removing umask=002, adding/remove ‘ipv4’) I didn’t restart the machine. Only umounted and then mounted the drive using sudo mount -a.
I would appreciate any help, either with an alternative solution or with fixing mounting the device.
The arch wiki was my starting point, but since I cannot change the name of the file even if I mount as the same user as the one that I used to mount the file system, I am stuck there. Using NFS is an option, but I’m not sure how to sync my machine’s clock with the router’s one. I do have a workaround though. I have a raspberry pi that is serving as a minecraft server for my kids and as a web server for me to play around with flask. I can actually connect the drive directly to it and mount it via sshfs.
This raises a new question. How do I make sure that the network based file systems are mounted only after wifi connection is established?
As I said I ended up connecting the drive to my raspberry pi and I mount it now with sshfs. I used gnome extension (guess you know which DE I’m using) called executer to execute a python script that verifies that I’m connected and that the drive is not mounted and then mount the drive using sshfs.
