Hey there, I recently installed EndeavourOS on my desktop again. After a period of using Windows, I felt compelled to hop back on Linux.
However I’m having issues using wifi. It seems to me that the issue is that my wifi driver is not in use.
$ lspci -nnk
04:00.0 Network controller [0280]: Intel Corporation Wireless-AC 9260 [8086:2526] (rev 29)
Subsystem: Intel Corporation Wireless-AC 9260 [8086:0014]
Kernel modules: iwlwifi
05:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 26)
Subsystem: ASUSTeK Computer Inc. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [1043:87c3]
Kernel driver in use: r8169
Kernel modules: r8169
I would imagine my wireless network card should also have a row of text saying “Kernel driver in use: iwlwifi”. And looking in my firmware folder, I already have the file corresponding to my Wireless-AC 9260.
/lib/firmware/iwlwifi-9260-th-b0-jf-b0-34.ucode.zst.
(Can also be downloaded from here https://www.intel.com/content/www/us/en/support/articles/000005511/wireless.html)
I feel a bit lost to be honest and don’t know how to resolve this. If somebody knows what to do I’d be really happy, since running an ethernet cable through multiple rooms isn’t something my roommate would like.
I’ll provide some other outputs from the terminal that might be of help in troubleshooting.
$ rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
$ nmcli device status
DEVICE TYPE STATE CONNECTION
enp5s0 ethernet connected Wired connection 1
lo loopback connected (externally) lo
sudo dmesg | grep iwl
[ 7.022563] iwlwifi: probe of 0000:04:00.0 failed with error -110
$ inxi -Na
Device-1: Intel Wireless-AC 9260 driver: N/A modules: iwlwifi pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2526 class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Thank you in advance to anyone caring to read this.
