Here it goes:
**journalctl --user -u pipewire
set 03 12:40:25 endvos pipewire[911]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 12:40:25 endvos pipewire[911]: default: failed to create context: Invalid argument
set 03 12:40:25 endvos systemd[658]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 12:40:25 endvos systemd[658]: pipewire.service: Failed with result 'exit-code'.
set 03 12:40:25 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 2.
set 03 12:40:25 endvos systemd[658]: Stopped PipeWire Multimedia Service.
set 03 12:40:25 endvos systemd[658]: Started PipeWire Multimedia Service.
set 03 12:40:26 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 3.
set 03 12:40:26 endvos systemd[658]: Stopped PipeWire Multimedia Service.
set 03 12:40:26 endvos systemd[658]: Started PipeWire Multimedia Service.
set 03 12:40:26 endvos pipewire[964]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 12:40:26 endvos pipewire[964]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 12:40:26 endvos pipewire[964]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 12:40:26 endvos pipewire[964]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 12:40:26 endvos pipewire[964]: mod.adapter: 0x556cc7e78d50: can't get format: Invalid argument
set 03 12:40:26 endvos pipewire[964]: mod.adapter: usage: node.name=<string>
set 03 12:40:26 endvos pipewire[964]: pw.resource: usage: node.name=<string>
set 03 12:40:26 endvos pipewire[964]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 12:40:26 endvos pipewire[964]: default: failed to create context: Invalid argument
set 03 12:40:26 endvos systemd[658]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 12:40:26 endvos systemd[658]: pipewire.service: Failed with result 'exit-code'.
set 03 12:40:26 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 4.
set 03 12:40:26 endvos systemd[658]: pipewire.service: Start request repeated too quickly.
set 03 12:40:26 endvos systemd[658]: Failed to start PipeWire Multimedia Service.
set 03 12:43:17 endvos systemd[658]: Started PipeWire Multimedia Service.
set 03 12:43:17 endvos systemd[658]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 12:43:17 endvos systemd[658]: pipewire.service: Failed with result 'exit-code'.
set 03 12:43:18 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 1.
set 03 12:43:18 endvos systemd[658]: Stopped PipeWire Multimedia Service.
set 03 12:43:18 endvos systemd[658]: Started PipeWire Multimedia Service.
set 03 12:43:18 endvos pipewire[6647]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 12:43:18 endvos pipewire[6647]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 12:43:18 endvos pipewire[6647]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 12:43:18 endvos pipewire[6647]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 12:43:18 endvos pipewire[6647]: mod.adapter: 0x55a9666d4d50: can't get format: Invalid argument
set 03 12:43:18 endvos pipewire[6647]: mod.adapter: usage: node.name=<string>
set 03 12:43:18 endvos pipewire[6647]: pw.resource: usage: node.name=<string>
set 03 12:43:18 endvos pipewire[6647]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 12:43:18 endvos pipewire[6647]: default: failed to create context: Invalid argument
set 03 12:43:18 endvos systemd[658]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 12:43:18 endvos systemd[658]: pipewire.service: Failed with result 'exit-code'.
set 03 12:43:18 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 2.
set 03 12:43:18 endvos pipewire[6654]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 12:43:18 endvos pipewire[6654]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 12:43:18 endvos pipewire[6654]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 12:43:18 endvos pipewire[6654]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 12:43:18 endvos pipewire[6654]: mod.adapter: 0x55c822fb7d50: can't get format: Invalid argument
set 03 12:43:18 endvos pipewire[6654]: mod.adapter: usage: node.name=<string>
set 03 12:43:18 endvos pipewire[6654]: pw.resource: usage: node.name=<string>
set 03 12:43:18 endvos pipewire[6654]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 12:43:18 endvos pipewire[6654]: default: failed to create context: Invalid argument
set 03 12:43:18 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 3.
set 03 12:43:18 endvos pipewire[6678]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 12:43:18 endvos pipewire[6678]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 12:43:18 endvos pipewire[6678]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 12:43:18 endvos pipewire[6678]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 12:43:18 endvos pipewire[6678]: mod.adapter: 0x560332470d50: can't get format: Invalid argument
set 03 12:43:18 endvos pipewire[6678]: mod.adapter: usage: node.name=<string>
set 03 12:43:18 endvos pipewire[6678]: pw.resource: usage: node.name=<string>
set 03 12:43:18 endvos pipewire[6678]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 12:43:18 endvos pipewire[6678]: default: failed to create context: Invalid argument
set 03 12:43:18 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 4.
set 03 12:43:18 endvos pipewire[6685]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 12:43:18 endvos pipewire[6685]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 12:43:18 endvos pipewire[6685]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 12:43:18 endvos pipewire[6685]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 12:43:18 endvos pipewire[6685]: mod.adapter: 0x55ea535fdd50: can't get format: Invalid argument
set 03 12:43:18 endvos pipewire[6685]: mod.adapter: usage: node.name=<string>
set 03 12:43:18 endvos pipewire[6685]: pw.resource: usage: node.name=<string>
set 03 12:43:18 endvos pipewire[6685]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 12:43:18 endvos pipewire[6685]: default: failed to create context: Invalid argument
set 03 12:43:19 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 5.
set 03 12:43:19 endvos systemd[658]: Stopped PipeWire Multimedia Service.
set 03 12:43:19 endvos systemd[658]: pipewire.service: Start request repeated too quickly.
set 03 12:43:19 endvos systemd[658]: pipewire.service: Failed with result 'exit-code'.
set 03 12:43:19 endvos systemd[658]: Failed to start PipeWire Multimedia Service.
set 03 12:46:38 endvos systemd[658]: Started PipeWire Multimedia Service.
set 03 12:46:38 endvos pipewire[11965]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 12:46:38 endvos pipewire[11965]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 12:46:38 endvos pipewire[11965]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 12:46:38 endvos pipewire[11965]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 12:46:38 endvos pipewire[11965]: mod.adapter: 0x56509ac75d50: can't get format: Invalid argument
set 03 12:46:38 endvos pipewire[11965]: mod.adapter: usage: node.name=<string>
set 03 12:46:38 endvos pipewire[11965]: pw.resource: usage: node.name=<string>
set 03 12:46:38 endvos pipewire[11965]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 12:46:38 endvos pipewire[11965]: default: failed to create context: Invalid argument
set 03 12:46:38 endvos systemd[658]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 12:46:38 endvos systemd[658]: pipewire.service: Failed with result 'exit-code'.
set 03 12:46:39 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 1.
set 03 12:46:39 endvos systemd[658]: Stopped PipeWire Multimedia Service.
set 03 12:46:39 endvos systemd[658]: Started PipeWire Multimedia Service.
set 03 12:46:39 endvos pipewire[11976]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 12:46:39 endvos pipewire[11976]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 12:46:39 endvos pipewire[11976]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 12:46:39 endvos pipewire[11976]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 12:46:39 endvos pipewire[11976]: mod.adapter: 0x55bfd734dd50: can't get format: Invalid argument
set 03 12:46:39 endvos pipewire[11976]: mod.adapter: usage: node.name=<string>
set 03 12:46:39 endvos pipewire[11976]: pw.resource: usage: node.name=<string>
set 03 12:46:39 endvos pipewire[11976]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 12:46:39 endvos pipewire[11976]: default: failed to create context: Invalid argument
set 03 12:46:39 endvos systemd[658]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 12:46:39 endvos systemd[658]: pipewire.service: Failed with result 'exit-code'.
set 03 12:46:39 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 2.
set 03 12:46:39 endvos pipewire[11982]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 12:46:39 endvos pipewire[11982]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 12:46:39 endvos pipewire[11982]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 12:46:39 endvos pipewire[11982]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 12:46:39 endvos pipewire[11982]: mod.adapter: 0x55f515798d50: can't get format: Invalid argument
set 03 12:46:39 endvos pipewire[11982]: mod.adapter: usage: node.name=<string>
set 03 12:46:39 endvos pipewire[11982]: pw.resource: usage: node.name=<string>
set 03 12:46:39 endvos pipewire[11982]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 12:46:39 endvos pipewire[11982]: default: failed to create context: Invalid argument
set 03 12:46:39 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 3.
set 03 12:46:39 endvos pipewire[12002]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 12:46:39 endvos pipewire[12002]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 12:46:39 endvos pipewire[12002]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 12:46:39 endvos pipewire[12002]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 12:46:39 endvos pipewire[12002]: mod.adapter: 0x5633f9833d50: can't get format: Invalid argument
set 03 12:46:39 endvos pipewire[12002]: mod.adapter: usage: node.name=<string>
set 03 12:46:39 endvos pipewire[12002]: pw.resource: usage: node.name=<string>
set 03 12:46:39 endvos pipewire[12002]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 12:46:39 endvos pipewire[12002]: default: failed to create context: Invalid argument
set 03 12:46:39 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 4.
set 03 12:46:40 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 5.
set 03 12:46:40 endvos systemd[658]: Stopped PipeWire Multimedia Service.
set 03 12:46:40 endvos systemd[658]: pipewire.service: Start request repeated too quickly.
set 03 12:46:40 endvos systemd[658]: pipewire.service: Failed with result 'exit-code'.
set 03 12:46:40 endvos systemd[658]: Failed to start PipeWire Multimedia Service.
set 03 12:48:35 endvos systemd[658]: Started PipeWire Multimedia Service.
set 03 12:48:35 endvos pipewire[14934]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 12:48:35 endvos pipewire[14934]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 12:48:35 endvos pipewire[14934]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 12:48:35 endvos pipewire[14934]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 12:48:35 endvos pipewire[14934]: mod.adapter: 0x5642af636d50: can't get format: Invalid argument
set 03 12:48:35 endvos pipewire[14934]: mod.adapter: usage: node.name=<string>
set 03 12:48:35 endvos pipewire[14934]: pw.resource: usage: node.name=<string>
set 03 12:48:35 endvos pipewire[14934]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 12:48:35 endvos pipewire[14934]: default: failed to create context: Invalid argument
set 03 12:48:35 endvos systemd[658]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 12:48:35 endvos systemd[658]: pipewire.service: Failed with result 'exit-code'.
set 03 12:48:36 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 1.
set 03 12:48:36 endvos systemd[658]: Stopped PipeWire Multimedia Service.
set 03 12:48:36 endvos systemd[658]: Started PipeWire Multimedia Service.
set 03 12:48:36 endvos pipewire[14943]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 12:48:36 endvos pipewire[14943]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 12:48:36 endvos pipewire[14943]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 12:48:36 endvos pipewire[14943]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 12:48:36 endvos pipewire[14943]: mod.adapter: 0x561759320d50: can't get format: Invalid argument
set 03 12:48:36 endvos pipewire[14943]: mod.adapter: usage: node.name=<string>
set 03 12:48:36 endvos pipewire[14943]: pw.resource: usage: node.name=<string>
set 03 12:48:36 endvos pipewire[14943]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 12:48:36 endvos pipewire[14943]: default: failed to create context: Invalid argument
set 03 12:48:36 endvos systemd[658]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 12:48:36 endvos systemd[658]: pipewire.service: Failed with result 'exit-code'.
set 03 12:48:36 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 2.
set 03 12:48:36 endvos pipewire[14967]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 12:48:36 endvos pipewire[14967]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 12:48:36 endvos pipewire[14967]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 12:48:36 endvos pipewire[14967]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 12:48:36 endvos pipewire[14967]: mod.adapter: 0x559bc788ed50: can't get format: Invalid argument
set 03 12:48:36 endvos pipewire[14967]: mod.adapter: usage: node.name=<string>
set 03 12:48:36 endvos pipewire[14967]: pw.resource: usage: node.name=<string>
set 03 12:48:36 endvos pipewire[14967]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 12:48:36 endvos pipewire[14967]: default: failed to create context: Invalid argument
set 03 12:48:36 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 3.
set 03 12:48:36 endvos pipewire[14973]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 12:48:36 endvos pipewire[14973]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 12:48:36 endvos pipewire[14973]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 12:48:36 endvos pipewire[14973]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 12:48:36 endvos pipewire[14973]: mod.adapter: 0x5631725e0d50: can't get format: Invalid argument
set 03 12:48:36 endvos pipewire[14973]: mod.adapter: usage: node.name=<string>
set 03 12:48:36 endvos pipewire[14973]: pw.resource: usage: node.name=<string>
set 03 12:48:36 endvos pipewire[14973]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 12:48:36 endvos pipewire[14973]: default: failed to create context: Invalid argument
set 03 12:48:37 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 4.
set 03 12:48:37 endvos systemd[658]: Stopped PipeWire Multimedia Service.
set 03 12:48:37 endvos systemd[658]: Started PipeWire Multimedia Service.
set 03 12:48:37 endvos pipewire[14979]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 12:48:37 endvos pipewire[14979]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 12:48:37 endvos pipewire[14979]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 12:48:37 endvos pipewire[14979]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 12:48:37 endvos pipewire[14979]: mod.adapter: 0x55e3d6cf1d50: can't get format: Invalid argument
set 03 12:48:37 endvos pipewire[14979]: mod.adapter: usage: node.name=<string>
set 03 12:48:37 endvos pipewire[14979]: pw.resource: usage: node.name=<string>
set 03 12:48:37 endvos pipewire[14979]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 12:48:37 endvos pipewire[14979]: default: failed to create context: Invalid argument
set 03 12:48:37 endvos systemd[658]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 12:48:37 endvos systemd[658]: pipewire.service: Failed with result 'exit-code'.
set 03 12:48:37 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 5.
set 03 12:48:37 endvos systemd[658]: pipewire.service: Start request repeated too quickly.
set 03 12:48:37 endvos systemd[658]: Failed to start PipeWire Multimedia Service.
set 03 13:05:50 endvos systemd[658]: Started PipeWire Multimedia Service.
set 03 13:05:50 endvos systemd[658]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 13:05:50 endvos systemd[658]: pipewire.service: Failed with result 'exit-code'.
set 03 13:05:50 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 1.
set 03 13:05:50 endvos systemd[658]: Stopped PipeWire Multimedia Service.
set 03 13:05:50 endvos pipewire[38058]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:05:50 endvos pipewire[38058]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:05:50 endvos pipewire[38058]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:05:50 endvos pipewire[38058]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:05:50 endvos pipewire[38058]: mod.adapter: 0x5557f8aecd50: can't get format: Invalid argument
set 03 13:05:50 endvos pipewire[38058]: mod.adapter: usage: node.name=<string>
set 03 13:05:50 endvos pipewire[38058]: pw.resource: usage: node.name=<string>
set 03 13:05:50 endvos pipewire[38058]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:05:50 endvos pipewire[38058]: default: failed to create context: Invalid argument
set 03 13:05:50 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 2.
set 03 13:05:50 endvos pipewire[38064]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:05:50 endvos pipewire[38064]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:05:50 endvos pipewire[38064]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:05:50 endvos pipewire[38064]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:05:50 endvos pipewire[38064]: mod.adapter: 0x5562e0f42d50: can't get format: Invalid argument
set 03 13:05:50 endvos pipewire[38064]: mod.adapter: usage: node.name=<string>
set 03 13:05:50 endvos pipewire[38064]: pw.resource: usage: node.name=<string>
set 03 13:05:50 endvos pipewire[38064]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:05:50 endvos pipewire[38064]: default: failed to create context: Invalid argument
set 03 13:05:51 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 3.
set 03 13:05:51 endvos systemd[658]: Stopped PipeWire Multimedia Service.
set 03 13:05:51 endvos systemd[658]: Started PipeWire Multimedia Service.
set 03 13:05:51 endvos pipewire[38073]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:05:51 endvos pipewire[38073]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:05:51 endvos pipewire[38073]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:05:51 endvos pipewire[38073]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:05:51 endvos pipewire[38073]: mod.adapter: 0x56107d334d50: can't get format: Invalid argument
set 03 13:05:51 endvos pipewire[38073]: mod.adapter: usage: node.name=<string>
set 03 13:05:51 endvos pipewire[38073]: pw.resource: usage: node.name=<string>
set 03 13:05:51 endvos pipewire[38073]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:05:51 endvos pipewire[38073]: default: failed to create context: Invalid argument
set 03 13:05:51 endvos systemd[658]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 13:05:51 endvos systemd[658]: pipewire.service: Failed with result 'exit-code'.
set 03 13:05:51 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 4.
set 03 13:05:51 endvos pipewire[38085]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:05:51 endvos pipewire[38085]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:05:51 endvos pipewire[38085]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:05:51 endvos pipewire[38085]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:05:51 endvos pipewire[38085]: mod.adapter: 0x55dbaa5aed50: can't get format: Invalid argument
set 03 13:05:51 endvos pipewire[38085]: mod.adapter: usage: node.name=<string>
set 03 13:05:51 endvos pipewire[38085]: pw.resource: usage: node.name=<string>
set 03 13:05:51 endvos pipewire[38085]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:05:51 endvos pipewire[38085]: default: failed to create context: Invalid argument
set 03 13:05:51 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 5.
set 03 13:05:51 endvos systemd[658]: pipewire.service: Start request repeated too quickly.
set 03 13:05:51 endvos systemd[658]: Failed to start PipeWire Multimedia Service.
set 03 13:07:07 endvos systemd[658]: Started PipeWire Multimedia Service.
set 03 13:07:07 endvos pipewire[40056]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:07:07 endvos pipewire[40056]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:07:07 endvos pipewire[40056]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:07:07 endvos pipewire[40056]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:07:07 endvos pipewire[40056]: mod.adapter: 0x5582e14f7d50: can't get format: Invalid argument
set 03 13:07:07 endvos pipewire[40056]: mod.adapter: usage: node.name=<string>
set 03 13:07:07 endvos pipewire[40056]: pw.resource: usage: node.name=<string>
set 03 13:07:07 endvos pipewire[40056]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:07:07 endvos pipewire[40056]: default: failed to create context: Invalid argument
set 03 13:07:07 endvos systemd[658]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 13:07:07 endvos systemd[658]: pipewire.service: Failed with result 'exit-code'.
set 03 13:07:08 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 1.
set 03 13:07:08 endvos systemd[658]: Stopped PipeWire Multimedia Service.
set 03 13:07:08 endvos systemd[658]: Started PipeWire Multimedia Service.
set 03 13:07:08 endvos pipewire[40066]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:07:08 endvos pipewire[40066]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:07:08 endvos pipewire[40066]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:07:08 endvos pipewire[40066]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:07:08 endvos pipewire[40066]: mod.adapter: 0x55e23bcdcd50: can't get format: Invalid argument
set 03 13:07:08 endvos pipewire[40066]: mod.adapter: usage: node.name=<string>
set 03 13:07:08 endvos pipewire[40066]: pw.resource: usage: node.name=<string>
set 03 13:07:08 endvos pipewire[40066]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:07:08 endvos pipewire[40066]: default: failed to create context: Invalid argument
set 03 13:07:08 endvos systemd[658]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 13:07:08 endvos systemd[658]: pipewire.service: Failed with result 'exit-code'.
set 03 13:07:08 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 2.
set 03 13:07:08 endvos pipewire[40072]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:07:08 endvos pipewire[40072]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:07:08 endvos pipewire[40072]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:07:08 endvos pipewire[40072]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:07:08 endvos pipewire[40072]: mod.adapter: 0x55663e0d3d50: can't get format: Invalid argument
set 03 13:07:08 endvos pipewire[40072]: mod.adapter: usage: node.name=<string>
set 03 13:07:08 endvos pipewire[40072]: pw.resource: usage: node.name=<string>
set 03 13:07:08 endvos pipewire[40072]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:07:08 endvos pipewire[40072]: default: failed to create context: Invalid argument
set 03 13:07:08 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 3.
set 03 13:07:08 endvos pipewire[40097]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:07:08 endvos pipewire[40097]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:07:08 endvos pipewire[40097]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:07:08 endvos pipewire[40097]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:07:08 endvos pipewire[40097]: mod.adapter: 0x55d535491d50: can't get format: Invalid argument
set 03 13:07:08 endvos pipewire[40097]: mod.adapter: usage: node.name=<string>
set 03 13:07:08 endvos pipewire[40097]: pw.resource: usage: node.name=<string>
set 03 13:07:08 endvos pipewire[40097]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:07:08 endvos pipewire[40097]: default: failed to create context: Invalid argument
set 03 13:07:08 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 4.
set 03 13:07:08 endvos pipewire[40103]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:07:08 endvos pipewire[40103]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:07:08 endvos pipewire[40103]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:07:08 endvos pipewire[40103]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:07:08 endvos pipewire[40103]: mod.adapter: 0x5572e4383d50: can't get format: Invalid argument
set 03 13:07:08 endvos pipewire[40103]: mod.adapter: usage: node.name=<string>
set 03 13:07:08 endvos pipewire[40103]: pw.resource: usage: node.name=<string>
set 03 13:07:08 endvos pipewire[40103]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:07:08 endvos pipewire[40103]: default: failed to create context: Invalid argument
set 03 13:07:09 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 5.
set 03 13:07:09 endvos systemd[658]: Stopped PipeWire Multimedia Service.
set 03 13:07:09 endvos systemd[658]: pipewire.service: Start request repeated too quickly.
set 03 13:07:09 endvos systemd[658]: pipewire.service: Failed with result 'exit-code'.
set 03 13:07:09 endvos systemd[658]: Failed to start PipeWire Multimedia Service.
set 03 13:07:14 endvos systemd[658]: pipewire.service: Start request repeated too quickly.
set 03 13:07:14 endvos systemd[658]: pipewire.service: Failed with result 'exit-code'.
set 03 13:07:14 endvos systemd[658]: Failed to start PipeWire Multimedia Service.
set 03 13:07:52 endvos systemd[658]: Started PipeWire Multimedia Service.
set 03 13:07:52 endvos pipewire[41206]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:07:52 endvos pipewire[41206]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:07:52 endvos pipewire[41206]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:07:52 endvos pipewire[41206]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:07:52 endvos pipewire[41206]: mod.adapter: 0x55b31295cd50: can't get format: Invalid argument
set 03 13:07:52 endvos pipewire[41206]: mod.adapter: usage: node.name=<string>
set 03 13:07:52 endvos pipewire[41206]: pw.resource: usage: node.name=<string>
set 03 13:07:52 endvos pipewire[41206]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:07:52 endvos pipewire[41206]: default: failed to create context: Invalid argument
set 03 13:07:52 endvos systemd[658]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 13:07:52 endvos systemd[658]: pipewire.service: Failed with result 'exit-code'.
set 03 13:07:53 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 1.
set 03 13:07:53 endvos systemd[658]: Stopped PipeWire Multimedia Service.
set 03 13:07:53 endvos systemd[658]: Started PipeWire Multimedia Service.
set 03 13:07:53 endvos pipewire[41215]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:07:53 endvos pipewire[41215]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:07:53 endvos pipewire[41215]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:07:53 endvos pipewire[41215]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:07:53 endvos pipewire[41215]: mod.adapter: 0x55faa0b5dd50: can't get format: Invalid argument
set 03 13:07:53 endvos pipewire[41215]: mod.adapter: usage: node.name=<string>
set 03 13:07:53 endvos pipewire[41215]: pw.resource: usage: node.name=<string>
set 03 13:07:53 endvos pipewire[41215]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:07:53 endvos pipewire[41215]: default: failed to create context: Invalid argument
set 03 13:07:53 endvos systemd[658]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 13:07:53 endvos systemd[658]: pipewire.service: Failed with result 'exit-code'.
set 03 13:07:53 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 2.
set 03 13:07:53 endvos pipewire[41222]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:07:53 endvos pipewire[41222]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:07:53 endvos pipewire[41222]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:07:53 endvos pipewire[41222]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:07:53 endvos pipewire[41222]: mod.adapter: 0x55f09ec69d50: can't get format: Invalid argument
set 03 13:07:53 endvos pipewire[41222]: mod.adapter: usage: node.name=<string>
set 03 13:07:53 endvos pipewire[41222]: pw.resource: usage: node.name=<string>
set 03 13:07:53 endvos pipewire[41222]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:07:53 endvos pipewire[41222]: default: failed to create context: Invalid argument
set 03 13:07:53 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 3.
set 03 13:07:53 endvos pipewire[41242]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:07:53 endvos pipewire[41242]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:07:53 endvos pipewire[41242]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:07:53 endvos pipewire[41242]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:07:53 endvos pipewire[41242]: mod.adapter: 0x5582315dad50: can't get format: Invalid argument
set 03 13:07:53 endvos pipewire[41242]: mod.adapter: usage: node.name=<string>
set 03 13:07:53 endvos pipewire[41242]: pw.resource: usage: node.name=<string>
set 03 13:07:53 endvos pipewire[41242]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:07:53 endvos pipewire[41242]: default: failed to create context: Invalid argument
set 03 13:07:53 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 4.
set 03 13:07:53 endvos pipewire[41248]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:07:53 endvos pipewire[41248]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:07:53 endvos pipewire[41248]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:07:53 endvos pipewire[41248]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:07:53 endvos pipewire[41248]: mod.adapter: 0x55b213ec5d50: can't get format: Invalid argument
set 03 13:07:53 endvos pipewire[41248]: mod.adapter: usage: node.name=<string>
set 03 13:07:53 endvos pipewire[41248]: pw.resource: usage: node.name=<string>
set 03 13:07:53 endvos pipewire[41248]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:07:53 endvos pipewire[41248]: default: failed to create context: Invalid argument
set 03 13:07:54 endvos systemd[658]: pipewire.service: Scheduled restart job, restart counter is at 5.
set 03 13:07:54 endvos systemd[658]: Stopped PipeWire Multimedia Service.
set 03 13:07:54 endvos systemd[658]: pipewire.service: Start request repeated too quickly.
set 03 13:07:54 endvos systemd[658]: pipewire.service: Failed with result 'exit-code'.
set 03 13:07:54 endvos systemd[658]: Failed to start PipeWire Multimedia Service.
-- Boot 4325d0822421486fa0776e3eeccfcd93 --
set 03 13:21:41 endvos systemd[651]: Started PipeWire Multimedia Service.
set 03 13:21:41 endvos pipewire[893]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:21:41 endvos pipewire[893]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:21:41 endvos pipewire[893]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:21:41 endvos pipewire[893]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:21:41 endvos pipewire[893]: mod.adapter: 0x55a0afba8d50: can't get format: Invalid argument
set 03 13:21:41 endvos pipewire[893]: mod.adapter: usage: node.name=<string>
set 03 13:21:41 endvos pipewire[893]: pw.resource: usage: node.name=<string>
set 03 13:21:41 endvos pipewire[893]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:21:41 endvos pipewire[893]: default: failed to create context: Invalid argument
set 03 13:21:41 endvos systemd[651]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 13:21:41 endvos systemd[651]: pipewire.service: Failed with result 'exit-code'.
set 03 13:21:42 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 1.
set 03 13:21:42 endvos systemd[651]: Stopped PipeWire Multimedia Service.
set 03 13:21:42 endvos systemd[651]: Started PipeWire Multimedia Service.
set 03 13:21:42 endvos pipewire[1006]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:21:42 endvos pipewire[1006]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:21:42 endvos pipewire[1006]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:21:42 endvos pipewire[1006]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:21:42 endvos pipewire[1006]: mod.adapter: 0x56360c3abd50: can't get format: Invalid argument
set 03 13:21:42 endvos pipewire[1006]: mod.adapter: usage: node.name=<string>
set 03 13:21:42 endvos pipewire[1006]: pw.resource: usage: node.name=<string>
set 03 13:21:42 endvos pipewire[1006]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:21:42 endvos pipewire[1006]: default: failed to create context: Invalid argument
set 03 13:21:42 endvos systemd[651]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 13:21:42 endvos systemd[651]: pipewire.service: Failed with result 'exit-code'.
set 03 13:21:42 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 2.
set 03 13:21:42 endvos pipewire[1103]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:21:42 endvos pipewire[1103]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:21:42 endvos pipewire[1103]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:21:42 endvos pipewire[1103]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:21:42 endvos pipewire[1103]: mod.adapter: 0x55e92aff1d50: can't get format: Invalid argument
set 03 13:21:42 endvos pipewire[1103]: mod.adapter: usage: node.name=<string>
set 03 13:21:42 endvos pipewire[1103]: pw.resource: usage: node.name=<string>
set 03 13:21:42 endvos pipewire[1103]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:21:42 endvos pipewire[1103]: default: failed to create context: Invalid argument
set 03 13:21:42 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 3.
set 03 13:21:42 endvos pipewire[1109]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:21:42 endvos pipewire[1109]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:21:42 endvos pipewire[1109]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:21:42 endvos pipewire[1109]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:21:42 endvos pipewire[1109]: mod.adapter: 0x55806b3aad50: can't get format: Invalid argument
set 03 13:21:42 endvos pipewire[1109]: mod.adapter: usage: node.name=<string>
set 03 13:21:42 endvos pipewire[1109]: pw.resource: usage: node.name=<string>
set 03 13:21:42 endvos pipewire[1109]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:21:42 endvos pipewire[1109]: default: failed to create context: Invalid argument
set 03 13:21:42 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 4.
set 03 13:21:42 endvos pipewire[1120]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:21:42 endvos pipewire[1120]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:21:42 endvos pipewire[1120]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:21:42 endvos pipewire[1120]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:21:42 endvos pipewire[1120]: mod.adapter: 0x55acbe8f6d50: can't get format: Invalid argument
set 03 13:21:42 endvos pipewire[1120]: mod.adapter: usage: node.name=<string>
set 03 13:21:42 endvos pipewire[1120]: pw.resource: usage: node.name=<string>
set 03 13:21:42 endvos pipewire[1120]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:21:42 endvos pipewire[1120]: default: failed to create context: Invalid argument
set 03 13:21:43 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 5.
set 03 13:21:43 endvos systemd[651]: Stopped PipeWire Multimedia Service.
set 03 13:21:43 endvos systemd[651]: pipewire.service: Start request repeated too quickly.
set 03 13:21:43 endvos systemd[651]: pipewire.service: Failed with result 'exit-code'.
set 03 13:21:43 endvos systemd[651]: Failed to start PipeWire Multimedia Service.
set 03 13:22:40 endvos systemd[651]: Started PipeWire Multimedia Service.
set 03 13:22:40 endvos pipewire[3696]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:22:40 endvos pipewire[3696]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:22:40 endvos pipewire[3696]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:22:40 endvos pipewire[3696]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:22:40 endvos pipewire[3696]: mod.adapter: 0x556e444d0d50: can't get format: Invalid argument
set 03 13:22:40 endvos pipewire[3696]: mod.adapter: usage: node.name=<string>
set 03 13:22:40 endvos pipewire[3696]: pw.resource: usage: node.name=<string>
set 03 13:22:40 endvos pipewire[3696]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:22:40 endvos pipewire[3696]: default: failed to create context: Invalid argument
set 03 13:22:40 endvos systemd[651]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 13:22:40 endvos systemd[651]: pipewire.service: Failed with result 'exit-code'.
set 03 13:22:40 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 1.
set 03 13:22:40 endvos systemd[651]: Stopped PipeWire Multimedia Service.
set 03 13:22:40 endvos pipewire[3708]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:22:40 endvos pipewire[3708]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:22:40 endvos pipewire[3708]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:22:40 endvos pipewire[3708]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:22:40 endvos pipewire[3708]: mod.adapter: 0x559f48bedd50: can't get format: Invalid argument
set 03 13:22:40 endvos pipewire[3708]: mod.adapter: usage: node.name=<string>
set 03 13:22:40 endvos pipewire[3708]: pw.resource: usage: node.name=<string>
set 03 13:22:40 endvos pipewire[3708]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:22:40 endvos pipewire[3708]: default: failed to create context: Invalid argument
set 03 13:22:40 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 2.
set 03 13:22:40 endvos pipewire[3732]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:22:40 endvos pipewire[3732]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:22:40 endvos pipewire[3732]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:22:40 endvos pipewire[3732]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:22:40 endvos pipewire[3732]: mod.adapter: 0x55ed24977d50: can't get format: Invalid argument
set 03 13:22:40 endvos pipewire[3732]: mod.adapter: usage: node.name=<string>
set 03 13:22:40 endvos pipewire[3732]: pw.resource: usage: node.name=<string>
set 03 13:22:40 endvos pipewire[3732]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:22:40 endvos pipewire[3732]: default: failed to create context: Invalid argument
set 03 13:22:41 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 3.
set 03 13:22:41 endvos systemd[651]: Stopped PipeWire Multimedia Service.
set 03 13:22:41 endvos systemd[651]: Started PipeWire Multimedia Service.
set 03 13:22:41 endvos pipewire[3738]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:22:41 endvos pipewire[3738]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:22:41 endvos pipewire[3738]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:22:41 endvos pipewire[3738]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:22:41 endvos pipewire[3738]: mod.adapter: 0x561177466d50: can't get format: Invalid argument
set 03 13:22:41 endvos pipewire[3738]: mod.adapter: usage: node.name=<string>
set 03 13:22:41 endvos pipewire[3738]: pw.resource: usage: node.name=<string>
set 03 13:22:41 endvos pipewire[3738]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:22:41 endvos pipewire[3738]: default: failed to create context: Invalid argument
set 03 13:22:41 endvos systemd[651]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 13:22:41 endvos systemd[651]: pipewire.service: Failed with result 'exit-code'.
set 03 13:22:41 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 4.
set 03 13:22:41 endvos pipewire[3744]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 13:22:41 endvos pipewire[3744]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 13:22:41 endvos pipewire[3744]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 13:22:41 endvos pipewire[3744]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 13:22:41 endvos pipewire[3744]: mod.adapter: 0x560e06532d50: can't get format: Invalid argument
set 03 13:22:41 endvos pipewire[3744]: mod.adapter: usage: node.name=<string>
set 03 13:22:41 endvos pipewire[3744]: pw.resource: usage: node.name=<string>
set 03 13:22:41 endvos pipewire[3744]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 13:22:41 endvos pipewire[3744]: default: failed to create context: Invalid argument
set 03 13:22:41 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 5.
set 03 13:22:41 endvos systemd[651]: pipewire.service: Start request repeated too quickly.
set 03 13:22:41 endvos systemd[651]: Failed to start PipeWire Multimedia Service.
set 03 16:17:37 endvos systemd[651]: Started PipeWire Multimedia Service.
set 03 16:17:37 endvos pipewire[230951]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 16:17:37 endvos pipewire[230951]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 16:17:37 endvos pipewire[230951]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 16:17:37 endvos pipewire[230951]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 16:17:37 endvos pipewire[230951]: mod.adapter: 0x55d413637d50: can't get format: Invalid argument
set 03 16:17:37 endvos pipewire[230951]: mod.adapter: usage: node.name=<string>
set 03 16:17:37 endvos pipewire[230951]: pw.resource: usage: node.name=<string>
set 03 16:17:37 endvos pipewire[230951]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 16:17:37 endvos pipewire[230951]: default: failed to create context: Invalid argument
set 03 16:17:37 endvos systemd[651]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 16:17:37 endvos systemd[651]: pipewire.service: Failed with result 'exit-code'.
set 03 16:17:37 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 1.
set 03 16:17:37 endvos systemd[651]: Stopped PipeWire Multimedia Service.
set 03 16:17:37 endvos pipewire[230960]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 16:17:37 endvos pipewire[230960]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 16:17:37 endvos pipewire[230960]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 16:17:37 endvos pipewire[230960]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 16:17:37 endvos pipewire[230960]: mod.adapter: 0x561ff8895d50: can't get format: Invalid argument
set 03 16:17:37 endvos pipewire[230960]: mod.adapter: usage: node.name=<string>
set 03 16:17:37 endvos pipewire[230960]: pw.resource: usage: node.name=<string>
set 03 16:17:37 endvos pipewire[230960]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 16:17:37 endvos pipewire[230960]: default: failed to create context: Invalid argument
set 03 16:17:37 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 2.
set 03 16:17:37 endvos pipewire[230966]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 16:17:37 endvos pipewire[230966]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 16:17:37 endvos pipewire[230966]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 16:17:37 endvos pipewire[230966]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 16:17:37 endvos pipewire[230966]: mod.adapter: 0x559cb37b6d50: can't get format: Invalid argument
set 03 16:17:37 endvos pipewire[230966]: mod.adapter: usage: node.name=<string>
set 03 16:17:37 endvos pipewire[230966]: pw.resource: usage: node.name=<string>
set 03 16:17:37 endvos pipewire[230966]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 16:17:37 endvos pipewire[230966]: default: failed to create context: Invalid argument
set 03 16:17:37 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 3.
set 03 16:17:37 endvos pipewire[230990]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 16:17:37 endvos pipewire[230990]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 16:17:37 endvos pipewire[230990]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 16:17:37 endvos pipewire[230990]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 16:17:37 endvos pipewire[230990]: mod.adapter: 0x555b6e0c7d50: can't get format: Invalid argument
set 03 16:17:37 endvos pipewire[230990]: mod.adapter: usage: node.name=<string>
set 03 16:17:37 endvos pipewire[230990]: pw.resource: usage: node.name=<string>
set 03 16:17:37 endvos pipewire[230990]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 16:17:37 endvos pipewire[230990]: default: failed to create context: Invalid argument
set 03 16:17:38 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 4.
set 03 16:17:38 endvos systemd[651]: Stopped PipeWire Multimedia Service.
se t 03 16:17:38 endvos systemd[651]: Started PipeWire Multimedia Service.
set 03 16:17:38 endvos pipewire[230996]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 16:17:38 endvos pipewire[230996]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 16:17:38 endvos pipewire[230996]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 16:17:38 endvos pipewire[230996]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 16:17:38 endvos pipewire[230996]: mod.adapter: 0x55a273df0d50: can't get format: Invalid argument
set 03 16:17:38 endvos pipewire[230996]: mod.adapter: usage: node.name=<string>
set 03 16:17:38 endvos pipewire[230996]: pw.resource: usage: node.name=<string>
set 03 16:17:38 endvos pipewire[230996]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 16:17:38 endvos pipewire[230996]: default: failed to create context: Invalid argument
set 03 16:17:38 endvos systemd[651]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 16:17:38 endvos systemd[651]: pipewire.service: Failed with result 'exit-code'.
set 03 16:17:38 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 5.
set 03 16:17:38 endvos systemd[651]: pipewire.service: Start request repeated too quickly.
set 03 16:17:38 endvos systemd[651]: Failed to start PipeWire Multimedia Service.
set 03 16:19:02 endvos systemd[651]: Started PipeWire Multimedia Service.
set 03 16:19:02 endvos pipewire[232841]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 16:19:02 endvos pipewire[232841]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 16:19:02 endvos pipewire[232841]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 16:19:02 endvos pipewire[232841]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 16:19:02 endvos pipewire[232841]: mod.adapter: 0x5597c7a45d50: can't get format: Invalid argument
set 03 16:19:02 endvos pipewire[232841]: mod.adapter: usage: node.name=<string>
set 03 16:19:02 endvos pipewire[232841]: pw.resource: usage: node.name=<string>
set 03 16:19:02 endvos pipewire[232841]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 16:19:02 endvos pipewire[232841]: default: failed to create context: Invalid argument
set 03 16:19:02 endvos systemd[651]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 16:19:02 endvos systemd[651]: pipewire.service: Failed with result 'exit-code'.
set 03 16:19:03 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 1.
set 03 16:19:03 endvos systemd[651]: Stopped PipeWire Multimedia Service.
set 03 16:19:03 endvos systemd[651]: Started PipeWire Multimedia Service.
set 03 16:19:03 endvos pipewire[232852]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 16:19:03 endvos pipewire[232852]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 16:19:03 endvos pipewire[232852]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 16:19:03 endvos pipewire[232852]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 16:19:03 endvos pipewire[232852]: mod.adapter: 0x55eac3478d50: can't get format: Invalid argument
set 03 16:19:03 endvos pipewire[232852]: mod.adapter: usage: node.name=<string>
set 03 16:19:03 endvos pipewire[232852]: pw.resource: usage: node.name=<string>
set 03 16:19:03 endvos pipewire[232852]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 16:19:03 endvos pipewire[232852]: default: failed to create context: Invalid argument
set 03 16:19:03 endvos systemd[651]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 16:19:03 endvos systemd[651]: pipewire.service: Failed with result 'exit-code'.
set 03 16:19:03 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 2.
set 03 16:19:03 endvos pipewire[232858]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 16:19:03 endvos pipewire[232858]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 16:19:03 endvos pipewire[232858]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 16:19:03 endvos pipewire[232858]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 16:19:03 endvos pipewire[232858]: mod.adapter: 0x564c2897dd50: can't get format: Invalid argument
set 03 16:19:03 endvos pipewire[232858]: mod.adapter: usage: node.name=<string>
set 03 16:19:03 endvos pipewire[232858]: pw.resource: usage: node.name=<string>
set 03 16:19:03 endvos pipewire[232858]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 16:19:03 endvos pipewire[232858]: default: failed to create context: Invalid argument
set 03 16:19:03 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 3.
set 03 16:19:03 endvos pipewire[232864]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 16:19:03 endvos pipewire[232864]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 16:19:03 endvos pipewire[232864]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 16:19:03 endvos pipewire[232864]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 16:19:03 endvos pipewire[232864]: mod.adapter: 0x556c7b17bd50: can't get format: Invalid argument
set 03 16:19:03 endvos pipewire[232864]: mod.adapter: usage: node.name=<string>
set 03 16:19:03 endvos pipewire[232864]: pw.resource: usage: node.name=<string>
set 03 16:19:03 endvos pipewire[232864]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 16:19:03 endvos pipewire[232864]: default: failed to create context: Invalid argument
set 03 16:19:03 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 4.
set 03 16:19:03 endvos pipewire[232888]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 16:19:03 endvos pipewire[232888]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 16:19:03 endvos pipewire[232888]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 16:19:03 endvos pipewire[232888]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 16:19:03 endvos pipewire[232888]: mod.adapter: 0x55fb0bf40d50: can't get format: Invalid argument
set 03 16:19:03 endvos pipewire[232888]: mod.adapter: usage: node.name=<string>
set 03 16:19:03 endvos pipewire[232888]: pw.resource: usage: node.name=<string>
set 03 16:19:03 endvos pipewire[232888]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 16:19:03 endvos pipewire[232888]: default: failed to create context: Invalid argument
set 03 16:19:04 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 5.
set 03 16:19:04 endvos systemd[651]: Stopped PipeWire Multimedia Service.
set 03 16:19:04 endvos systemd[651]: pipewire.service: Start request repeated too quickly.
set 03 16:19:04 endvos systemd[651]: pipewire.service: Failed with result 'exit-code'.
set 03 16:19:04 endvos systemd[651]: Failed to start PipeWire Multimedia Service.
set 03 16:19:56 endvos systemd[651]: Started PipeWire Multimedia Service.
set 03 16:19:56 endvos pipewire[234041]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 16:19:56 endvos pipewire[234041]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 16:19:56 endvos pipewire[234041]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 16:19:56 endvos pipewire[234041]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 16:19:56 endvos pipewire[234041]: mod.adapter: 0x55bc0580cd50: can't get format: Invalid argument
set 03 16:19:56 endvos pipewire[234041]: mod.adapter: usage: node.name=<string>
set 03 16:19:56 endvos pipewire[234041]: pw.resource: usage: node.name=<string>
set 03 16:19:56 endvos pipewire[234041]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 16:19:56 endvos pipewire[234041]: default: failed to create context: Invalid argument
set 03 16:19:56 endvos systemd[651]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 16:19:56 endvos systemd[651]: pipewire.service: Failed with result 'exit-code'.
set 03 16:19:56 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 1.
set 03 16:19:56 endvos systemd[651]: Stopped PipeWire Multimedia Service.
set 03 16:19:56 endvos pipewire[234050]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 16:19:56 endvos pipewire[234050]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 16:19:56 endvos pipewire[234050]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 16:19:56 endvos pipewire[234050]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 16:19:56 endvos pipewire[234050]: mod.adapter: 0x55ff5b521d50: can't get format: Invalid argument
set 03 16:19:56 endvos pipewire[234050]: mod.adapter: usage: node.name=<string>
set 03 16:19:56 endvos pipewire[234050]: pw.resource: usage: node.name=<string>
set 03 16:19:56 endvos pipewire[234050]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 16:19:56 endvos pipewire[234050]: default: failed to create context: Invalid argument
set 03 16:19:57 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 2.
set 03 16:19:57 endvos systemd[651]: Stopped PipeWire Multimedia Service.
set 03 16:19:57 endvos systemd[651]: Started PipeWire Multimedia Service.
set 03 16:19:57 endvos pipewire[234058]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 16:19:57 endvos pipewire[234058]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 16:19:57 endvos pipewire[234058]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 16:19:57 endvos pipewire[234058]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 16:19:57 endvos pipewire[234058]: mod.adapter: 0x55cc0510fd50: can't get format: Invalid argument
set 03 16:19:57 endvos pipewire[234058]: mod.adapter: usage: node.name=<string>
set 03 16:19:57 endvos pipewire[234058]: pw.resource: usage: node.name=<string>
set 03 16:19:57 endvos pipewire[234058]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 16:19:57 endvos pipewire[234058]: default: failed to create context: Invalid argument
set 03 16:19:57 endvos systemd[651]: pipewire.service: Main process exited, code=exited, status=234/n/a
set 03 16:19:57 endvos systemd[651]: pipewire.service: Failed with result 'exit-code'.
set 03 16:19:57 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 3.
set 03 16:19:57 endvos pipewire[234064]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 16:19:57 endvos pipewire[234064]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 16:19:57 endvos pipewire[234064]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 16:19:57 endvos pipewire[234064]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 16:19:57 endvos pipewire[234064]: mod.adapter: 0x559618763d50: can't get format: Invalid argument
set 03 16:19:57 endvos pipewire[234064]: mod.adapter: usage: node.name=<string>
set 03 16:19:57 endvos pipewire[234064]: pw.resource: usage: node.name=<string>
set 03 16:19:57 endvos pipewire[234064]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 16:19:57 endvos pipewire[234064]: default: failed to create context: Invalid argument
set 03 16:19:57 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 4.
set 03 16:19:57 endvos pipewire[234070]: ALSA lib conf.c:5545:(parse_args) Parameter DEV must be an integer
set 03 16:19:57 endvos pipewire[234070]: ALSA lib conf.c:5687:(snd_config_expand) Parse arguments error: Invalid argument
set 03 16:19:57 endvos pipewire[234070]: ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM hw:card_number,device_number
set 03 16:19:57 endvos pipewire[234070]: spa.alsa: 'hw:card_number,device_number': capture open failed: Invalid argument
set 03 16:19:57 endvos pipewire[234070]: mod.adapter: 0x55fa7f30fd50: can't get format: Invalid argument
set 03 16:19:57 endvos pipewire[234070]: mod.adapter: usage: node.name=<string>
set 03 16:19:57 endvos pipewire[234070]: pw.resource: usage: node.name=<string>
set 03 16:19:57 endvos pipewire[234070]: pw.conf: can't create object from factory adapter: Invalid argument
set 03 16:19:57 endvos pipewire[234070]: default: failed to create context: Invalid argument
set 03 16:19:57 endvos systemd[651]: pipewire.service: Scheduled restart job, restart counter is at 5.
set 03 16:19:57 endvos systemd[651]: pipewire.service: Start request repeated too quickly.
set 03 16:19:57 endvos systemd[651]: Failed to start PipeWire Multimedia Service.
/usr/bin/pipewire
[E][17182.394542] spa.alsa | [ alsa-pcm.c: 516 spa_alsa_open()] 'hw:card_number,device_number': capture open failed: Invalid argument
[W][17182.394577] mod.adapter | [ adapter.c: 232 find_format()] 0x562095108e80: can't get format: Invalid argument
[E][17182.394609] mod.adapter | [module-adapter.c: 283 create_object()] usage: node.name=<string>
[E][17182.394652] pw.resource | [ resource.c: 265 pw_resource_errorf_id()] usage: node.name=<string>
[E][17182.394730] pw.conf | [ conf.c: 658 create_object()] can't create object from factory adapter: Invalid argument
[E][17182.395085] default | [ pipewire.c: 125 main()] failed to create context: Invalid argument
