i am unable to figure out how to do this. mount my external had drive again. i did it a while back with my old computer but can’t remeber how. if anyone could help i am lost… i know it worked once i mounted it. i just don’t know how…
[fj@whitewolf ~]$ sudo fdisk -l
Disk /dev/nvme0n1: 3.73 TiB, 4096805658624 bytes, 8001573552 sectors
Disk model: T-FORCE TM8FFE004T
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: F9024728-391E-408D-971D-133600DF2D7E
[details=“Summary”]
Device Start End Sectors Size Type
/dev/nvme0n1p1 4096 4198399 4194304 2G EFI System
/dev/nvme0n1p2 4198400 7858194072 7853995673 3.7T Linux filesystem
/dev/nvme0n1p3 7858194073 8001573485 143379413 68.4G Linux swap
Disk /dev/sda: 7.28 TiB, 8001562869760 bytes, 15628052480 sectors
Disk model: easystore 264D
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 8B78F5E9-E1D5-44EB-8128-0423E96C1D54
/dev/sda1 2048 15628050431 15628048384 7.3T Microsoft basic data
[fj@whitewolf ~]$
[fj@whitewolf ~]$ l[fj@whitewolf ~]$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 7.3T 0 disk
└─sda1 8:1 0 7.3T 0 part
nvme0n1 259:0 0 3.7T 0 disk
├─nvme0n1p1 259:1 0 2G 0 part /efi
│ /efi
├─nvme0n1p2 259:2 0 3.7T 0 part /
└─nvme0n1p3 259:3 0 68.4G 0 part [SWAP]
[fj@whitewolf ~]$
