So I have been happily running a lvm2 system for some time. Recently I went from an Intel system to an amd system. Today I noticed I had both ucodes so I removed Intel-ucode, but, I forgot to reconfigure grub. Doh! Stupid mistake. No problem, I’ll run it in chroot. Or so I thought. I have ran arch-chroot in the past and never had a problem. Now I can mount my root which is a lvm2 member, but, when I go to mount /dev/sda1 /mnt/boot/efi I get mount: /mnt/boot/efi: unknown filesystem type lvm2 member. sda1 is a normal fat32 esp. As I said I’ve never had a problem before. I tried installing lvm2 and it did no good. That was on an arch iso. Now I’m on a eos and it keeps disconnecting from the internet every few seconds so if I have to do that again I’m screwed. I know it is an uncommon setup but help.
That is my old thread and had to do with a bad update not my current problem.
First reboot, when you get to login hold down Ctrl +Alt and hit F2 It will put you in TTY2. Log in with username and password, then enter “sudo grub-mkconfig -o /boot/grub/grub.cfg” without quotes. After that runs, Then enter “systemctl reboot” You can mask LVN2 with “sudo systemctl mask lvm2-monitor.service” if that first part does not work.
I don’t get to login.
I am trying to arch-chroot from a live USB.
You said you are “on a EOS and it keeps disconnecting from the internet every few seconds” Try to get to TTY2 from there. You do not need internet.
@woodrowwsmith You just need to start the computer. You don’t need to log in. As @beardedragon has said change to TTY by pressing Ctrl + Alt + F2 Then run the command:
Then run:
systemctl reboot
Press enter
And as I said I don’t get that far. If gives me a message about intel-ucode being missing hit any key then goes straight to my vendor logo and hangs there. I need to chroot into my system.
Eos iso can’t get past my vendor logo.
Can’t change to systemd boot without chrooting into my system dude.
hehmmm is it cause removin an intel-ucode…but you cant chroot in ?
thats painfull are you btw able to reach that partition, im curius if you can get somewhere intel-ucode.img to sneek the grub… but isnt, if you can see the grub, you can try to edit the command line , with e and look to the line where looks for intel-ucode.img ? thats basicly generating grub thing is, to setup the rub data automatically, ? like amd-ucode and intel-ucode should show in grub.cfg …
No it is because something changed with lvm.
Issue is with LVM Group you need to make this known to the kernel first, what needs to be done manually before chrooting .
vgchange --available y $volgroupname
okay. good deal thanks Joe. I actually got into my system by hitting e at grub and manually removing /boot/Intel-ucode.img from intrid, thanks to Ringo.
