Cant load system after update
i get this screen after system update
IMG_20220607_203025
i tried usual:
  1. run live usb and use arch-chroot
  2. pacman -Syu
  3. mkinitcpio -P
  4. grub update
didt help(
any suggestions?
Also try the LTS kernel.
Check which packages were updated and do some guessing… :person_shrugging:
:enos: has a tool called pahis for this. Try it out @iwedmak
Right. One should always have the LTS kernel installed as a fallback.
iwedmak, after arch-chroot you should execute (perhaps / is just full):
# paccache -r -k 1
# pacman -S linux-lts linux
