When i try to connect my wifi with
nmcli device wifi connect SSID password PASSWORD
i get
Error: Connection activation failed: Secrets were required, but not provided.
I know the password is correct
http://ix.io/4J4Z
Hi, have you tried the following from the arch wiki? https://wiki.archlinux.org/title/NetworkManager#Secrets_were_required,_but_not_provided
ive tried
You can try deleting the connection profile and creating a new one:
$ nmcli connection delete SSID $ nmcli device wifi connect SSID password password
and
You can also try disabling MAC address randomization:
/etc/NetworkManager/conf.d/wifi_rand_mac.conf
[device]
wifi.scan-rand-mac-address=no
and it does not help
I solved it using nmtui
