Can't access my system
What did you do once you chrooted into the system? Did you, for example, run another package update?
Did you edit your post to remove the fact this is a dual booting Windows system? Did you receive a windows update prior to your system entering this state?
Didnt use windows since I installed endeavour for the first time, which was 4 days ago
You did not answer my question.
Did this, no effect too
I’m in tty now
http://dpaste.com//3VF3Y6EVS
Did you mean to reply to me? That’s not an Xorg log output, looks more like dmesg or system journal… ?
Yes i did, how do I get the Xorg log if that helps?
Ah, OK, so did you read and follow any of the steps I outlined? What was the result?
Update didnt do anything
Startx: http://dpaste.com//H6TTASVKW
dkms thing didnt do anything either
Also I already reinstalled the kernel and header, nvidia, made a new kernel image and a new grub cfg
Sorry for having you wait
@jonathon
I removed anything optimus related, now i just boot into
Failed to start light display manager
Failed to start wait for network to be configured
No black screens, just that lightdm still doesnt work
what is the return of
sudo systemctl status lightdm.service
@Stephane @jonathon
Failed to start lightdm
Also startx now says no screens found
also
Xorg log ? ( log0 )
@jonathon @stephane
http://dpaste.com//FXGMXBS6E
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=330023b4-c9fa-43f8-9d9d-72715bf554a1 rw quiet loglevel=3 nowatchdog nvidia-drm.modeset=1
may be put i915= instead of nvidia-drm ?
I removed that in grub. Still failed to start lightdm
@Stephane
Startx still doesnt work, fatal server error, no screens found
and what about
sudo journalctl -b0 -p4
