❯ LANG=C sudo pacman -Syu
endeavouros is up to date
core is up to date
extra is up to date
multilib is up to date
resolving dependencies...
warning: cannot resolve "libopenshot-audio.so=10-64", a dependency of "libopenshot"
:: The following package cannot be upgraded due to unresolvable dependencies:
libopenshot
:: Do you want to skip the above package for this upgrade? [y/N] y
:: installing protobuf (29.2-1) breaks dependency 'libprotobuf.so=28.3.0-64' required by libopenshot
It’s good to have ‘Kdenlive’ working. . . . . I also had ‘Openshot’ on my system. Software redundancy helps if something doesn’t work and you have another program to fall back on. Kdenlive is pretty good all by itself. People say it’s just added bloat but with all of the storage space available programs that do the same to lesser degrees shouldn’t be an issue if you’ve got a lot of space not being used.
