Cannot connect to wifi network after wpa_supplicant upgrade
Hello, Yesterday I noticed was wpa_supplicant upgrade and after some time my wifi stop working. I try that but still cannot connect to my wifi network. I use now Android hotspot to connect to that wifi. So wifi is working with android hotspot but cannot connect to my regular wifi network.
I try that from arch forum:
systemctl stop wpa_supplicant NetworkManager
systemctl disable wpa_supplicant
rm -rf /etc/wpa_supplicant/*
systemctl start NetworkManager
I attach eos-log. (ps. why I cannot upload logs and always have to change to another format?)
Regards.
eos-log-tool.logs.pdf (626.7 KB)
The log you uploaded is empty. Not sure why you are having trouble sending logs. The tool in the Welcome app should work. Or you can upload it with other methods.
Meybe it’s empty because I change prefix to pdf. Regular .logs file is forbidden to upload.
That is my boot log (I don’t know that command):
https://clbin.com/NKgEy
and hardware:
https://clbin.com/B5WSG
Regards.
Don’t you need to enable and start wpa_supplicant again?
You could perhaps also try connecting using wpa_cli to see if that works.
https://wiki.archlinux.org/title/Wpa_supplicant#Connecting_with_wpa_cli
And could you post the link to the Arch forum post?
Hi, I try to run wpa_cli but:
âžś wpa_cli
wpa_cli v2.10
Copyright (c) 2004-2022, Jouni Malinen <j@w1.fi> and contributors
This software may be distributed under the terms of the BSD license.
See README for more details.
Interactive mode
Could not connect to wpa_supplicant: (nil) - re-trying
Like from arch forum:
https://bbs.archlinux.org/viewtopic.php?id=271962
Regards.
Try restarting wpa_supplicant.service again and see if it works.
Check its status:
systemctl status wpa_supplicant
I think there’s some other problem because my wifi is working and now I’m connected with wifi to smartphone hotspot.
â—Ź wpa_supplicant.service - WPA supplicant
     Loaded: loaded (/usr/lib/systemd/system/wpa_supplicant.service; disabled; vendor preset: disabled)
     Active: active (running) since Wed 2022-01-26 08:29:10 CET; 1h 0min ago
   Main PID: 3759 (wpa_supplicant)
      Tasks: 1 (limit: 18660)
     Memory: 1.2M
        CPU: 84ms
     CGroup: /system.slice/wpa_supplicant.service
             └─3759 /usr/bin/wpa_supplicant -u -s -O /run/wpa_supplicant
sty 26 09:15:51 marian-dell wpa_supplicant[3759]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
sty 26 09:15:52 marian-dell wpa_supplicant[3759]: wlan0: SME: Trying to authenticate with 46:74:4b:d9:3c:c7 (SSID='OnePlus9' freq=2412 MHz)
sty 26 09:15:52 marian-dell wpa_supplicant[3759]: wlan0: Trying to associate with 46:44:2b:f9:4c:c7 (SSID='OnePlus9' freq=2412 MHz)
sty 26 09:15:52 marian-dell wpa_supplicant[3759]: wlan0: Associated with 47:44:17:f3:6c:c7
sty 26 09:15:52 marian-dell wpa_supplicant[3759]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
sty 26 09:15:52 marian-dell wpa_supplicant[3759]: wlan0: WPA: Key negotiation completed with 46:54:2b:f9:5c:c9 [PTK=CCMP GTK=CCMP]
sty 26 09:15:52 marian-dell wpa_supplicant[3759]: wlan0: CTRL-EVENT-CONNECTED - Connection to 46:54:2b:f9:5c:c7 completed [id=0 id_str=]
sty 26 09:15:52 marian-dell wpa_supplicant[3759]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-26 noise=9999 txrate=1000
sty 26 09:18:53 marian-dell wpa_supplicant[3759]: wlan0: CTRL-EVENT-BEACON-LOSS
So the issue is that you cannot connect to your router?
Hmmm… not sure why then. :confused:
Hopefully other forummates can have some idea.
Yes, strange situation. Yesterday after some time after that feral wpa upgrade there was some conection issue with wifi because all devices lose wifi in my work and only my laptop have problem with wifi today. All other devices have normal wifi connection working.
Regards.
Sounds strange.
Have you tried to remove that connection from your WiFi settings and tried to connect to it again?
If you have then ignore this post.
Yes, I try that. :slight_smile:
Meybe linux devs make some changes like in windows with wifi security because one laptop with W10 always show that our work network is insecure. I see in Settings that:
Restarting the router usually helps in such cases.
This should normally be enabled.
systemctl enable --now wpa_supplicant
Check your journal log and post errors
journalctl -b -p3 --no-pager --no-hostname
I enable wpa_supplicant service:
sudo systemctl enable --now wpa_supplicant
Created symlink /etc/systemd/system/dbus-fi.w1.wpa_supplicant1.service → /usr/lib/systemd/system/wpa_supplicant.service.
Created symlink /etc/systemd/system/multi-user.target.wants/wpa_supplicant.service → /usr/lib/systemd/system/wpa_supplicant.service.
and
sudo journalctl -b -p3 --no-pager --no-hostname
sty 26 09:52:34 kernel: x86/cpu: SGX disabled by BIOS.
sty 26 09:52:35 kernel: ioremap error for 0x688f2000-0x688f3000, requested 0x2, got 0x0
sty 26 09:52:36 kernel: Bluetooth: hci0: Failed to read codec capabilities (-56)
sty 26 09:52:39 systemd[1]: Failed to mount /mnt/Seagate.
sty 26 09:52:39 kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  495.46  Wed Oct 27 16:31:33 UTC 2021
sty 26 09:52:42 gnome-session-binary[741]: GLib-GIO-CRITICAL: g_bus_get_sync: assertion 'error == NULL || *error == NULL' failed
sty 26 09:52:44 kernel: Bluetooth: hci0: Failed to read codec capabilities (-56)
sty 26 09:52:53 gdm-password][981]: gkr-pam: unable to locate daemon control file
sty 26 09:53:00 systemd[990]: Failed to start Application launched by gnome-session-binary.
sty 26 09:53:09 gdm-launch-environment][704]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
sty 26 09:55:36 systemd[990]: Failed to start EOS update notifier service.
sty 26 10:13:37 systemd-coredump[5294]: [🡕] Process 5162 (gnome-documents) of user 1000 dumped core.
                                        Module linux-vdso.so.1 with build-id f9fada32e91353254b262e357cb155d189cc0523
                                        Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
                                        Module libkrb5support.so.0 with build-id adf65240a4d2aba772d7a0772b4d015469934113
                                        Module libcom_err.so.2 with build-id be99503e12b86d78d6ede2f0d1ffb66408a37576
                                        Module libk5crypto.so.3 with build-id eb8220b8f36675aac769450be4cb6bb7f97ec38a
                                        Module libkrb5.so.3 with build-id 72d26767c5cb1097db75a5f5bff88860233c902b
                                        Module libidn2.so.0 with build-id 1ce2b50ad9f9821c2c629b521cf5a3c99593d332
                                        Module libunistring.so.2 with build-id 015ac6d6bcb60b7d8bea31a80d1941b06e8636ab
                                        Module libgssapi_krb5.so.2 with build-id e6e098ad51ce7bdd3dbe902d7b0f69a90f8a9e08
                                        Module libpsl.so.5 with build-id 0229a201aaf5652186c9fdc192ebe52baf19d7f1
                                        Module libuuid.so.1 with build-id 1366ec3008cfdbe45a226330754baeea46a2d7e6
                                        Module libsoup-2.4.so.1 with build-id 678dafa54638a6d0ab73f810643f9a23d988db00
                                        Module libtracker-data.so with build-id d63759d15e716837194266d7310f09100d2fd82f
                                        Module libtracker-sparql-2.0.so.0 with build-id 7b38a315ff6db81d1ed5b7109646e0920d04e184
                                        Module libdconfsettings.so with build-id 7a4ba7af122c4d11168004a9ea6def330f02089f
                                        Module libsynctex.so.2 with build-id 15d595e1f7ef62199c8bc7fd7a525b597d2bf365
                                        Module libevdocument3.so.4 with build-id 74e8c8fad8ab9cdd8b83014520a1bc443889802c
                                        Module libogg.so.0 with build-id ca0cae30a809f10db1f16e54a23b4e5ff7b2c54c
                                        Module libvorbis.so.0 with build-id ad0a6c1af8f219b4e314090b6e8847223d424cbe
                                        Module libltdl.so.7 with build-id 64bc54a40a0b6e4209a2c712364b4ae653c3f5b2
                                        Module libtdb.so.1 with build-id bec061530310665480ee91395b4eb0a937750a03
                                        Module libvorbisfile.so.3 with build-id 0010b21da05e318b42e718d90738febf58028141
                                        Module libcanberra.so.0 with build-id 379ed64f9d1408a83806cd5d94dc5bb903765615
                                        Module libcanberra-gtk3.so.0 with build-id 133409dc3e744fe0edc6a4d078714dce82dacf98
                                        Module libcanberra-gtk-module.so with build-id 72bd14fd5ba4fb0eda082b3daeccc80b796a5586
                                        Module libxkbfile.so.1 with build-id de5e415879c20263a8dd42f8cf2dd88107c2bfb2
                                        Module libxklavier.so.16 with build-id cefd678b3d270e389f50a9686ad2db83a8c67494
                                        Module libgnomekbd.so.8 with build-id 794a46e6fb5c4ca09e07a74b1199fb1d480d0843
                                        Module libgnomekbdui.so.8 with build-id 0f2fd1658447a0f5bf23a5eff2ec69bc9c306142
                                        Module libxapp.so.1 with build-id 2d6867c3b087052ef8acd12a1a6c82b3c62b8f36
                                        Module libxapp-gtk3-module.so with build-id 12b94957cbe0eb705d8e900c9006d5333846d4db
                                        Module libseccomp.so.2 with build-id 54179323d84e1b713b7547ba0b3f8310e65eec93
                                        Module libudev.so.1 with build-id e7bd18780bd5753c14f8561be78e4e78ae0266ee
                                        Module libxkbregistry.so.0 with build-id fd1a0bf7d7dd5625c98422781d2b0240c9677d90
                                        Module libgnome-desktop-3.so.19 with build-id 1e1070e9acfb96ee171cb8de0996b4eba36bbb72
                                        Module libgpg-error.so.0 with build-id 3801187d42c4955bd93c605451430cdf1b164e63
                                        Module libgcrypt.so.20 with build-id db45f5d5e0f7af1e77324fea1885f974619ad268
                                        Module libcap.so.2 with build-id f56c6cd6ad4d35053340d7ff2f8f954498796739
                                        Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
                                        Module libicudata.so.70 with build-id e1dcc2a88cfaafed882d09c90c668af0eed4efed
                                        Module libsystemd.so.0 with build-id 6a2a26aa5fff87c1eb61137339bc55a53956c9ac
                                        Module liblzma.so.5 with build-id 8b615460aa230708c5183f16bede67aa0437d95e
                                        Module libzstd.so.1 with build-id ea8f70c7c6816cee97c9890081a80259ca44d397
                                        Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
                                        Module libxml2.so.2 with build-id b710b880b0d4e9c93554fa632129db44c20632cd
                                        Module libjson-glib-1.0.so.0 with build-id 5865be5fcc01b48a0a113e0145ec45529bff89a6
                                        Module libsqlite3.so.0 with build-id 5f711261aabe285f02a673ded77a37b413afbfa2
                                        Module libicui18n.so.70 with build-id 95af755fca990df26753a7d720b8e3ae24270e42
                                        Module libicuuc.so.70 with build-id 2e245c2bf12f95fd8ab79b3a4be99524677cbd70
                                        Module libstemmer.so.0 with build-id aa44a40dfb223020ed8e49cd2d28fc3887128463
                                        Module libatspi.so.0 with build-id de251156cf6f2f447c5e2b8721bd913d79995d4f
                                        Module libdbus-1.so.3 with build-id 74f2ab9c60512f3a93c932c3f627564d42e0b11e
                                        Module libtiff.so.5 with build-id e8d89a0fb0847641ddb75c5f03fa89d68155a75d
                                        Module libjpeg.so.8 with build-id 879ca18a2f58c25d77ba881db3a44a5676ef6c7d
                                        Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
                                        Module libXinerama.so.1 with build-id dbb6adece34ea2766d3efcd628af8f9757344dd6
                                        Module libXrandr.so.2 with build-id d4e869b5c72541e1de8f96b456248987ea52d51b
                                        Module libXcomposite.so.1 with build-id f1bb5ffb6203ab2907ac044a204ce3902a79f1c1
                                        Module libXdamage.so.1 with build-id a1d867e093c16944b2c0083be98050ef35c9e5c2
                                        Module libXcursor.so.1 with build-id eb6315bcd7526aaf51b0a1307efdc587cea0a152
                                        Module libwayland-egl.so.1 with build-id 791e39283cdcc5a08cfd091b8cd4c59869a11278
                                        Module libwayland-cursor.so.0 with build-id 79d7e67af210407c2afe92ba8c189c8648a6474c
                                        Module libwayland-client.so.0 with build-id 0a237f2fd096bada4ca381eec5d64474c4078be4
                                        Module libxkbcommon.so.0 with build-id 1f1bc7527e57c886c3df5803068122e1971d4724
                                        Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
                                        Module libtracker-sparql-3.0.so.0 with build-id b0eee5a9b660fed5221ea15139e9608282320503
                                        Module libcloudproviders.so.0 with build-id ed1d9c9e60be4e858ad148484767249be1edf95f
                                        Module libatk-bridge-2.0.so.0 with build-id 1161ebbcc5aa791075dfa026671875e5417287bd
                                        Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
                                        Module libepoxy.so.0 with build-id b6357fc6b748c512f90339433d74502b9d0621dc
                                        Module libatk-1.0.so.0 with build-id aacaa40363d304858b654728a893bc212a4ca119
                                        Module libgdk_pixbuf-2.0.so.0 with build-id ca4beb15a30de8d8767f7bca8222038c61b58b36
                                        Module libfribidi.so.0 with build-id 79124bad061c2aab4ec89f25d067363d5b781114
                                        Module libpangoft2-1.0.so.0 with build-id ef74c3ce7ee52a746fb5f2840d80a84e314edb92
                                        Module libpango-1.0.so.0 with build-id 730a8183a36afae82dd6a5564c0e490fed239a40
                                        Module libpangocairo-1.0.so.0 with build-id 10d2af38056eee9a6b3458d8aac24095c4dfab72
                                        Module libgdk-3.so.0 with build-id 6f77a9486fc38cb4e374d862662cb5e39ca3988a
                                        Module libgtk-3.so.0 with build-id e17042e459bfe2a5cd401828a90435a81a82b70d
                                        Module libgvfscommon.so with build-id 90d1858292300e4e1ee3fbe84ab06079af840ec6
                                        Module libgvfsdbus.so with build-id dcb9d652f2e5c65154517fe6934215ec6bd1c29c
                                        Module libbrotlicommon.so.1 with build-id a4ba3f4b4571c8272343b621da812a6e24a202a7
                                        Module libgraphite2.so.3 with build-id 47761dc11e553f519cde97ed9ee985be12ccdae2
                                        Module libXdmcp.so.6 with build-id 8ca0792d23c8b8b4c0864297512349292bea5955
                                        Module libXau.so.6 with build-id 1c67764663e07bec24d8951e5fd93f4d165979ff
                                        Module libbrotlidec.so.1 with build-id 45defc036e918e0140a72f1fbce6e7692d38241d
                                        Module libharfbuzz.so.0 with build-id 1d9dee49dd99162c3f83eb3259c3c88c6b4cd7fe
                                        Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
                                        Module libexpat.so.1 with build-id 64e977cfebfe7539f428dec3b388f5d0498b3108
                                        Module libblkid.so.1 with build-id 023f6fa066e46c87041fac2d66df1069c901b015
                                        Module libpixman-1.so.0 with build-id 341f793dcada3a48a306a793d265a517e3f2e7d6
                                        Module libxcb-shm.so.0 with build-id fb797f299a446f559a95afcc168227482cc800d1
                                        Module libxcb-render.so.0 with build-id a37bdb37744b508be9dd29fd9ccb9bb0170d43e5
                                        Module libxcb.so.1 with build-id 0d1ef11740a5daad2ee331e812a51aa6574af222
                                        Module libXrender.so.1 with build-id 97e0b9ab6ba96ebc86527cc2b3c3078aad8616b3
                                        Module libXext.so.6 with build-id d70f24beb4fad748d6becffdcc13e51be0a2ebfa
                                        Module libfreetype.so.6 with build-id 26c5f833068ff72660d1975cbc2074c3eb47fad8
                                        Module libfontconfig.so.1 with build-id 1103a641395c7d3b42e49b793d3a9ea927c77bf6
                                        Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
                                        Module libncursesw.so.6 with build-id 859adb8b03a5655151b4da104bc4b326a0d4bc8c
                                        Module libdl.so.2 with build-id 5abc547e7b0949f89f3c0e21ab0c8331a7440a8a
                                        Module ld-linux-x86-64.so.2 with build-id 040cc3dd10461562f177df39e3be2f3704258c3c
                                        Module libm.so.6 with build-id 2b8fd1f869ecab4e0b55e92f2f151897f6818acf
                                        Module libresolv.so.2 with build-id c915c72668282861a813f7ea3c0780f37b681dc0
                                        Module libmount.so.1 with build-id 00dfc43d6bddd183a4d8fa8508106cfd87159c62
                                        Module libz.so.1 with build-id 0c1459c56513efd5d53eb3868290e9afee6a6a26
                                        Module libgmodule-2.0.so.0 with build-id 5da4523e8d6b5c244a0193e27093d1e61f6ac9e4
                                        Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
                                        Module libpthread.so.0 with build-id 07c8f95b4f3251d08550217ad8a1f31066229996
                                        Module librt.so.1 with build-id 75484da2d6f1515189eefa076e0a40328834cd16
                                        Module libX11.so.6 with build-id 5ba5798d193c0065014b8c6252a0678671c8d478
                                        Module libcairo-gobject.so.2 with build-id abbf5a8a182ea1b8b7d68540df5c2e25c0bdae0c
                                        Module libcairo.so.2 with build-id 06820af9cf79c2deb207d9533a61caf04e67a8ad
                                        Module libreadline.so.8 with build-id 50c2746af3cf9fa7373e6ba6d9b2bc0a2ef7735a
                                        Module libmozjs-78.so with build-id c1888cc29615fc9295acb31413905b90d8a24897
                                        Module libffi.so.8 with build-id f90d8b734f6de9b25faedb8cbfab7054dafc0a42
                                        Module libgirepository-1.0.so.1 with build-id f851c06abfa29780d13693655d4ef65bc23eeb04
                                        Module libc.so.6 with build-id 4b406737057708c0e4c642345a703c47a61c73dc
                                        Module libgcc_s.so.1 with build-id 7f8508bb914546ada778809b64b99d234337d835
                                        Module libstdc++.so.6 with build-id 9b5eeeb149bf3c4efe787fb398b44f00507aec87
                                        Module libgio-2.0.so.0 with build-id bce5a3881708e1e885fa1c9c32e2769a6447c411
                                        Module libgobject-2.0.so.0 with build-id e67b3a29cecdd98c3d8bd6eb7524a812331b20a2
                                        Module libglib-2.0.so.0 with build-id 220436a4e27f39372710df014d2517c0387eefa4
                                        Module libgjs.so.0 with build-id 7abe93923dfb2ebba735e723e70ed9feb73cdeb4
                                        Module gjs-console with build-id e53056a863b787a2eaf80a2e09d9f31e8f151165
                                        Stack trace of thread 5162:
                                        #0  0x00007f2f29b37c2e n/a (libtracker-sparql-2.0.so.0 + 0x14c2e)
                                        #1  0x00007f2f29b386a0 tracker_sparql_connection_get (libtracker-sparql-2.0.so.0 + 0x156a0)
                                        #2  0x00007f2f463fdd4a n/a (libffi.so.8 + 0x6d4a)
                                        #3  0x00007f2f463fd267 n/a (libffi.so.8 + 0x6267)
                                        #4  0x00007f2f46bc6dc6 n/a (libgjs.so.0 + 0x3fdc6)
                                        #5  0x00007f2f46bc7368 n/a (libgjs.so.0 + 0x40368)
                                        #6  0x00007f2f44ce0fc9 n/a (libmozjs-78.so + 0x4defc9)
                                        #7  0x00007f2f44cbf8dc n/a (libmozjs-78.so + 0x4bd8dc)
                                        #8  0x00007f2f45101806 _Z15JS_CallFunctionP9JSContextN2JS6HandleIP8JSObjectEENS2_IP10JSFunctionEERKNS1_16HandleValueArrayENS1_13MutableHandleINS1_5ValueEEE (libmozjs-78.so + 0x8ff806)
                                        #9  0x00007f2f46bc4dc9 n/a (libgjs.so.0 + 0x3ddc9)
                                        #10 0x00007f2f46bcb1ac n/a (libgjs.so.0 + 0x441ac)
                                        #11 0x00007f2f46bcc2c1 n/a (libgjs.so.0 + 0x452c1)
                                        #12 0x00007f2f463fdb62 n/a (libffi.so.8 + 0x6b62)
                                        #13 0x00007f2f463fdee0 n/a (libffi.so.8 + 0x6ee0)
                                        #14 0x00007f2f46a20c96 g_signal_emit_valist (libgobject-2.0.so.0 + 0x30c96)
                                        #15 0x00007f2f46a20e04 g_signal_emit (libgobject-2.0.so.0 + 0x30e04)
                                        #16 0x00007f2f468f5db6 g_application_register (libgio-2.0.so.0 + 0xcfdb6)
                                        #17 0x00007f2f468f6540 n/a (libgio-2.0.so.0 + 0xd0540)
                                        #18 0x00007f2f4690167a g_application_run (libgio-2.0.so.0 + 0xdb67a)
                                        #19 0x00007f2f463fdd4a n/a (libffi.so.8 + 0x6d4a)
                                        #20 0x00007f2f463fd267 n/a (libffi.so.8 + 0x6267)
                                        #21 0x00007f2f46bc6dc6 n/a (libgjs.so.0 + 0x3fdc6)
                                        #22 0x00007f2f46bc7368 n/a (libgjs.so.0 + 0x40368)
                                        #23 0x00007f2f44ce0fc9 n/a (libmozjs-78.so + 0x4defc9)
                                        #24 0x00007f2f44f5c9d7 n/a (libmozjs-78.so + 0x75a9d7)
                                        #25 0x00007f2f44f62891 n/a (libmozjs-78.so + 0x760891)
                                        #26 0x00007f2f45154136 n/a (libmozjs-78.so + 0x952136)
                                        #27 0x00007f2f451542c4 _ZN2JS8EvaluateEP9JSContextNS_6HandleINS_13StackGCVectorIP8JSObjectN2js15TempAllocPolicyEEEEERKNS_22ReadOnlyCompileOptionsERNS_10SourceTextIDsEENS_13MutableHandleINS_5ValueEEE (libmozjs-78.so + 0x9522c4)
                                        #28 0x00007f2f46c00b0b n/a (libgjs.so.0 + 0x79b0b)
                                        #29 0x00007f2f46c030e7 gjs_context_eval (libgjs.so.0 + 0x7c0e7)
                                        #30 0x0000563662fdbb33 n/a (gjs-console + 0x2b33)
                                        #31 0x00007f2f4644eb25 __libc_start_main (libc.so.6 + 0x27b25)
                                        #32 0x0000563662fdbf0e n/a (gjs-console + 0x2f0e)
                                        Stack trace of thread 5189:
                                        #0  0x00007f2f4651ab2f __poll (libc.so.6 + 0xf3b2f)
                                        #1  0x00007f2f46af5fd6 n/a (libglib-2.0.so.0 + 0xaafd6)
                                        #2  0x00007f2f46a9d545 g_main_context_iteration (libglib-2.0.so.0 + 0x52545)
                                        #3  0x00007f2f46a9d592 n/a (libglib-2.0.so.0 + 0x52592)
                                        #4  0x00007f2f46acf905 n/a (libglib-2.0.so.0 + 0x84905)
                                        #5  0x00007f2f4451a259 start_thread (libpthread.so.0 + 0x9259)
                                        #6  0x00007f2f465255e3 __clone (libc.so.6 + 0xfe5e3)
                                        Stack trace of thread 5191:
                                        #2  0x00007f2f46a9f523 g_main_loop_run (libglib-2.0.so.0 + 0x54523)
                                        #3  0x00007f2f4692e0fc n/a (libgio-2.0.so.0 + 0x1080fc)
                                        Stack trace of thread 5201:
                                        #0  0x00007f2f445268ca __futex_abstimed_wait_common64 (libpthread.so.0 + 0x158ca)
                                        #1  0x00007f2f44520270 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf270)
                                        #2  0x00007f2f44f7b3e0 _ZN7mozilla6detail21ConditionVariableImpl8wait_forERNS0_9MutexImplERKNS_16BaseTimeDurationINS_27TimeDurationValueCalculatorEEE (libmozjs-78.so + 0x7793e0)
                                        #3  0x00007f2f44f7aee1 n/a (libmozjs-78.so + 0x778ee1)
                                        #4  0x00007f2f4516dbdf n/a (libmozjs-78.so + 0x96bbdf)
                                        Stack trace of thread 5202:
                                        Stack trace of thread 5203:
                                        Stack trace of thread 5204:
                                        Stack trace of thread 5287:
                                        #3  0x00007f2f4000debe n/a (libdconfsettings.so + 0x5ebe)
                                        ELF object binary architecture: AMD x86-64
sty 26 11:00:06 systemd-resolved[409]: Failed to send hostname reply: Transport endpoint is not connected
sty 26 11:00:10 systemd-resolved[409]: Failed to send hostname reply: Transport endpoint is not connected
sty 26 11:00:15 systemd-resolved[409]: Failed to send hostname reply: Transport endpoint is not connected
sty 26 11:00:23 systemd-resolved[409]: Failed to send hostname reply: Transport endpoint is not connected
Check
systemctl status systemd-resolved
resolvectl
âžś sudo systemctl status systemd-resolved
[sudo] hasło użytkownika mariank:
â—Ź systemd-resolved.service - Network Name Resolution
     Loaded: loaded (/usr/lib/systemd/system/systemd-resolved.service; enabled; vendor preset: enabled)
     Active: active (running) since Wed 2022-01-26 09:52:38 CET; 2h 1min ago
       Docs: man:systemd-resolved.service(8)
             man:org.freedesktop.resolve1(5)
             https://www.freedesktop.org/wiki/Software/systemd/writing-network-configuration-managers
             https://www.freedesktop.org/wiki/Software/systemd/writing-resolver-clients
   Main PID: 409 (systemd-resolve)
     Status: "Processing requests..."
     Memory: 8.1M
        CPU: 1.317s
     CGroup: /system.slice/systemd-resolved.service
             └─409 /usr/lib/systemd/systemd-resolved
sty 26 11:31:07 marian-dell systemd-resolved[409]: wlan0: Bus client set DNS server list to: 192.168.75.234
sty 26 11:31:07 marian-dell systemd-resolved[409]: Using degraded feature set UDP instead of UDP+EDNS0 for DNS server 192.168.75.234.
sty 26 11:39:30 marian-dell systemd-resolved[409]: wlan0: Bus client set default route setting: no
sty 26 11:39:30 marian-dell systemd-resolved[409]: wlan0: Bus client reset DNS server list.
sty 26 11:39:30 marian-dell systemd-resolved[409]: Switching to fallback DNS server 1.1.1.1#cloudflare-dns.com.
sty 26 11:39:31 marian-dell systemd-resolved[409]: wlan0: Bus client set default route setting: yes
sty 26 11:39:31 marian-dell systemd-resolved[409]: wlan0: Bus client set DNS server list to: 192.168.75.234
sty 26 11:39:31 marian-dell systemd-resolved[409]: Using degraded feature set UDP instead of UDP+EDNS0 for DNS server 192.168.75.234.
There is an existing bug at systemd related to systemd-resolved, maybe it is the reason. (a fix is on-the-way)
You may try changing your DNS servers to another set (Google’s 8.8.8.8, 8.8.4.4 IIRC).
You might also just reboot and check again.
As I said, restart the router if/when possible.
Edit: Try other kernels, like linux-lts.
I try to change kernel-lts and change to google DNS but nothing works. I cannot restart router because it’s in closed room.
Regards.
Does downgrading wpa_supplicant restore network connectivity?
If so start looking upstream for similar issues with the new version.
EDIT :
Downgrade and wait for fix is probably best bet.
Thank You very much :smiley: that’s it. I downgrade to ver. 2.9.
Regards.
