I found this of no help
https://wiki.archlinux.org/index.php/Creating_packages
I need to build “windscribe-cli” with pacman, any suggestions?
Thanks.
Thanks.
yay -S windscribe-cli
Because you don’t need to create a package. What you need is in the AUR. You need to build a package from the AUR which pacman can’t do by itself. However, yay
can.
See also:
https://wiki.archlinux.org/index.php/Arch_User_Repository#Installing_and_upgrading_packages
That was easy, and it worked! Thanks!
After you install windscribe you can start the service on boot with the following command “sudo systemctl enable windscribe”
