I’ve the msi bravo 15 B7E that has the rx6550m dgpu. I’d like to do a single gpu pass through setup.
After enabling iommu grouping and running lspci -nn , I found out that my dgpu isnt a vga compatible controller but rather a display controller my igpu is a vga compatible controller though. Can i still passthrough my gpu?
Seems you are not getting a lot of answers here. I’m not sure what the difference between the two is, but i don’t think it should matter for your purposes.
All I know is that you have to jump through hoops to make an nvidia card work with pass-through, most likely you will need to have a monitor connected directly to it. The reason being that Nvidia’s drivers don’t allow the card to work without a physical output connection active, they restrict this kind of usage for their professional cards like Quadro which cost a fortune for mostly the same chips with a bit more memory and other bells and whistles. Not that the cards wouldn’t be able to handle it, it’s all in the drivers.
You have to jump through hoops to do any sort of vga passthrough unless you’re using a card specifically designed for it like nvidia grid. Also op has an AMD gpu, not an nvidia one so whether it’s hard to do on nvidia or not isn’t really relevant.
