Since version 3.2.22, Calamares has been updated to not stuck the progress bar at 24/27%, the slideshow and Wiki still says it does.
EndeavourOS uses 3.2.20, which means it missed that update in the May ISO by a short bit.
This means, the next release will likely contain the fixed version, which makes the slideshow and the Wiki both outdated.
Just a heads up.
Here are the Git commits, it has been tested on KaOS and working there, Adriaan has send me these commits in relation to the bespoken improvements.
I don’t know why, but this forum breaks the link in the preview, so I quote it:
Its those commits from 6th April, the unpackfs related.
P.S: In order to do so for this bug report, I could not check which version of Calamares is used, since it is not in the repos. I found that quite unusual, since I am used to like reinstall the Installer in live mode to test purposed and stuff.
In case it is not any extra effort in terms of packaging, do you think it does sound sane to add it?
It also felt a little bit of, to have a software in my installation, that I cant find a package for, in general.
