Calamares failing with pacman error code 1
Hi,
My install from USB stick used before with ISO downloaded today on a PC is failing with this code
I have a good wired internet connection
I am selecting XFCE desktop and replacing a 500 GB empty partition alongside existing Win 11 installation
I just copied the log
https://termbin.com/5yys
1st in many many times that EOS hasnt installed for me :frowning:
Any ideas, please?
EDIT: something to do with this?
https://docs.xfce.org/panel-plugins/xfce4-datetime-plugin/start
2026-04-15 - 16:05:45 [6]: [PYTHON JOB]: “Enter a selection (default=all): error: target not found: xfce4-datetime-plugin”
is this latest ISO? this is actually already hotfixed but seems not getting applied on your ISO..
you can unselect the package on packages screen too:
DOH!
I downloaded the ISO, then had to start a meeting, and forgot to actually flash it to the USB stick, so I am using the older ISO :flushed_face:
I am actually trying again right now without xfce4-datetime-plugin
Is it better to flash the new ISO and reinstall if this works, or will an update get me to the same point anyway?
Sorry for being a Dunce!
EDIT: It worked :smile: Now, being lazy, can I just update rather than burning new ISO and reinstalling?
yes its online install anyway, if install works all is set properly
It’s a rolling release distro. So yeah if you update your on the latest version of endeavour.
Thanks All,
All done
