I have EOS installed with the Mate desktop. The issue is that when using Caja, it will not preview any sound files even though the file has the arrow when the mouse is hovered over the file. My speakers work on my laptop and I can play audio and video and sounds are present. I have searched but can not find a way to correct this. Any help would be greatly appreciated, thanks!
Host: EndeavourOS Kernel: 5.15.48-1-lts arch: x86_64 bits: 64 compiler: gcc
v: 12.1.0 Desktop: MATE v: 1.26.0 info: mate-panel wm: marco v: 1.26.0
vt: 7 dm: LightDM v: 1.30.0 Distro: EndeavourOS base: Arch Linux
Type: Laptop System: LENOVO product: 11433FU v: ThinkPad E520
Mobo: LENOVO model: 11433FU serial: <superuser required>
UEFI-[Legacy]: LENOVO v: 8HET30WW(1.12) date: 05/19/2011
Battery:
ID-1: BAT0 charge: 57.2 Wh (100.0%) condition: 57.2/71.3 Wh (80.2%)
volts: 12.5 min: 10.8 model: SANYO LNV-42T4763 type: Li-ion serial: 1
status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M187
serial: 4019-03-e8-c0-b4 charge: 55% (should be ignored) rechargeable: yes
status: discharging
Info: dual core model: Intel Core i5-2410M bits: 64 type: MT MCP
smt: enabled arch: Sandy Bridge rev: 7 cache: L1: 128 KiB L2: 512 KiB
L3: 3 MiB
Speed (MHz): avg: 810 high: 848 min/max: 800/2900 cores: 1: 848 2: 798
3: 798 4: 798 bogomips: 18356
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Lenovo driver: i915 v: kernel arch: Gen6 ports: active: LVDS-1
empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0116
class-ID: 0300
Device-2: Acer Lenovo Integrated Webcam type: USB driver: uvcvideo
bus-ID: 1-1.5:3 chip-ID: 5986:03b3 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2
compositor: marco v: 1.26.0 driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 mapped: LVDS1 model: LG Display 0x02e3 res: 1366x768
hz: 60 dpi: 102 size: 340x190mm (13.39x7.48") diag: 395mm (15.5")
modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 3000 (SNB GT2)
v: 3.3 Mesa 22.1.2 direct render: Yes
Device-1: Intel 6 Series/C200 Series Family High Definition Audio
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Sound Server-1: ALSA v: k5.15.48-1-lts running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.52 running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0 state: down mac: f0:de:f1:68:55:3b
Device-2: Intel Centrino Wireless-N 1000 [Condor Peak] driver: iwlwifi
v: kernel pcie: speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 8086:0084
class-ID: 0280
IF: wlan0 state: up mac: 8c:a9:82:be:b9:5e
Bluetooth:
Device-1: Broadcom BCM2045B (BDC-2.1) type: USB driver: btusb v: 0.8
bus-ID: 2-1.4:5 chip-ID: 0a5c:217f class-ID: fe01 serial: CC52AF82CF87
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: disabled
Local Storage: total: 465.76 GiB used: 8.94 GiB (1.9%)
ID-1: /dev/sda vendor: Seagate model: ST500LM021-1KJ152 size: 465.76 GiB
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: W62D0BQ8 rev: SDM1 scheme: MBR
ID-1: / size: 45.41 GiB used: 8.94 GiB (19.7%) fs: ext4 dev: /dev/sda9
System Temperatures: cpu: 39.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 168 Uptime: 1h 2m wakeups: 10 Memory: 7.68 GiB
used: 1.34 GiB (17.4%) Init: systemd v: 251 default: graphical Compilers:
gcc: 12.1.0 Packages: pacman: 978 Shell: Bash v: 5.1.16
running-in: lxterminal inxi: 3.3.18
