Is there any app similar to Caffeine-ng that will stop my computer screen from taking me into the sign-in mode that it jumps into after a few minutes of inactivity? I’m using it in Cinnamon and it works great and prevents my system from going into standby mode when it’s inactive for a period of time. It’s a nuisance having to sign in when I’m away for short periods.
Thanks. . . .my bad. . . .never thought to look under power saving Options. . . .use to think this option was mostly for laptops with lousy short life batteries.
I have Caffeine-ng installed and don’t know what the difference is between Caffeine and Caffeine-ng. The Icon is in the menu but doesn’t activate or do anything. In Cinnamon it puts a desktop icon in the menu-bar which you can enable or disable.
