Budgie monitor settings bugging out
Hey guys!
I am having an issue where I can’t seem to get budgie to change any monitor settings. If I try to change any settings, it sets all my monitors to the wrong order, forces 60hz and turns off one monitor.
If I change the settings via nvidia-settings or ArandR the monitors are fine till I reboot or press apply to different monitor settings in budgie-control-centre even if I save the xorg.conf (which contains the correct settings.)
And I know xorg is handling things correctly as the window managers login page is fine, its when I login and the monitor settings from budgie are applied.
Is there a budgie config reset that can be done or what could be potentially causing this?
Another thing I noticed was when I changed the order in budgie-control-centre I get the below error
(budgie-control-center:4582): display-cc-panel-WARNING **: 16:40:31.275: Config not applicable: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: Logical monitors not adjacent
Have you tried setting all of this with lxrandr. You can set the resolution and refresh and also the monitor layout all in one tool.
turns out it was a bug, this is now resolved with the recent patches
