I’ve used Garuda for a bit, and want to go back to EndeavourOS since it runs my games better,
the minimalism, and also of course the lovely forum ;). (in particular, Roblox thru grapejuice)
What I do like is that Garuda takes snapshots pre and post upgrade and install of packages thru snapper. AFAIK BTRFS is an option in the installer.
How do I do this?
Is it a “just works thing”? (I highly doubt that).
Also: for some reason if I copy paste the instructions at aur.chaotic.cx (to add the chaotic-aur before i even start setting up) pacman-key goes awry.
Thanks for the help. About to nuke my “trial” endeavourOS install (i call it a trial install to test if roblox was stuttering on endeavourOS and Garuda dr460nized.
It keeps bugging me about my EFI partition not being big enough when I do manual partitioning (to use btrfs) but not when I use the replace a partition (which uses ext4)
Is the WBM (Windwoes boot manager) partition big enough, considering it works in replace mode?
obviously the 60 GiB is for endeavourOS lol
also the wbm partition will be mounted to /boot/efi
edit 2: I’ll say go with it, I have almost nothing to lose.
EDIT 3: It IS enough. Check here, readers from the future!
Edit 4: I still don’t get an option to restore snapshots from GRUB. Is that possible or Yet Another Garuda Hack? lol
Edit 5: When I installed and ran update-grub it seems that it detected snapshots. I’ll see when I reboot.
Of course they do. Snapper comes from opensuse in the first place.
That being said, their implementation is very different. They use the default subvolume feature of btrfs to actually change what the root is pointing at.
EOS uses a flat layout with the default subvolume being left at the root of the filesystem. The root subvol is named @ and the home subvol is named @home. This is partially because timeshift requires all four of those things to function.
How you setup snapshots and restores is entirely left to the end-user.
