Hi guys.
I’m trying to get the brightness keys to work, but I’m stuck.
i3 configuration:
# Sreen brightness controls
bindsym XF86MonBrightnessUp exec xbacklight -inc 20 # incr>
bindsym XF86MonBrightnessDown exec xbacklight -dec 20 # de>
If I execute those commands, I can change the brightness correctly. But if I press the brightness keys, they don’t work.
So, executing sudo journalctl -f
I can see this happening when I press the brightness up button:
ott 04 12:39:09 PCABS kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
ott 04 12:39:09 PCABS kernel: atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
ott 04 12:39:09 PCABS kernel: atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
In order to get the keycode for the event, I ran sudo evtest
Available devices:
/dev/input/event0: Lid Switch
/dev/input/event1: Power Button
/dev/input/event2: Power Button
/dev/input/event3: AT Translated Set 2 keyboard
/dev/input/event4: HP Wireless hotkeys
/dev/input/event5: ST LIS3LV02DL Accelerometer
/dev/input/event6: PC Speaker
/dev/input/event7: PS/2 Generic Mouse
/dev/input/event8: HDA NVidia HDMI/DP,pcm=3
/dev/input/event9: HDA NVidia HDMI/DP,pcm=7
/dev/input/event10: HDA NVidia HDMI/DP,pcm=8
/dev/input/event11: HDA NVidia HDMI/DP,pcm=9
/dev/input/event12: HDA NVidia HDMI/DP,pcm=10
/dev/input/event13: ELAN0710:01 04F3:30ED Mouse
/dev/input/event14: ELAN0710:01 04F3:30ED Touchpad
/dev/input/event15: Video Bus
/dev/input/event16: HP Wide Vision HD Camera: HP Wi
/dev/input/event17: Video Bus
/dev/input/event18: HDA Intel PCH Mic
/dev/input/event19: HDA Intel PCH Headphone
/dev/input/event20: HDA Intel PCH HDMI/DP,pcm=3
/dev/input/event21: HDA Intel PCH HDMI/DP,pcm=7
/dev/input/event22: HDA Intel PCH HDMI/DP,pcm=8
/dev/input/event23: HDA Intel PCH HDMI/DP,pcm=9
/dev/input/event24: HDA Intel PCH HDMI/DP,pcm=10
/dev/input/event25: HP WMI hotkeys
/dev/input/event26: Logitech G903
The event25
is the one I chose, getting this:
Input driver version is 1.0.1
Input device ID: bus 0x19 vendor 0x0 product 0x0 version 0x0
Input device name: "HP WMI hotkeys"
Supported events:
Event type 0 (EV_SYN)
Event type 1 (EV_KEY)
Event code 138 (KEY_HELP)
Event code 141 (KEY_SETUP)
Event code 148 (KEY_PROG1)
Event code 153 (KEY_DIRECTION)
Event code 224 (KEY_BRIGHTNESSDOWN)
Event code 225 (KEY_BRIGHTNESSUP)
Event code 226 (KEY_MEDIA)
Event code 240 (KEY_UNKNOWN)
Event code 358 (KEY_INFO)
Event type 4 (EV_MSC)
Event code 4 (MSC_SCAN)
Event type 5 (EV_SW)
So we have the codes for brightness up and down, 244 and 245. So now I can run sudo setkeycodes e02b 224
and the brightness down key starts to work. But, if I press the brightness up key, it does not increase the brightness, but it decreases it, because the two physical buttons share the same scancode.
Pressing brightness down before setkeycodes
ott 04 12:46:50 PCABS kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
ott 04 12:46:50 PCABS kernel: atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
ott 04 12:46:50 PCABS kernel: atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
Pressing brightness up before setkeycodes
ott 04 12:48:03 PCABS kernel: atkbd serio0: Unknown key pressed (translated set 2, code 0xab on isa0060/serio0).
ott 04 12:48:03 PCABS kernel: atkbd serio0: Use 'setkeycodes e02b <keycode>' to make it known.
ott 04 12:48:03 PCABS kernel: atkbd serio0: Unknown key released (translated set 2, code 0xab on isa0060/serio0).
As you can see, the scancode (e02b
) it’s the same for both the keys.
Is there any way to remap the keys or to solve this issue? Thanks!
