Brightness control problem after suspend/sleep
Hello everyone.
I installed EndeavourOS today and everything works out of the box, but my only issue (so far) is keyboard brightness control. It works until I put system to sleep. After waking it up I have no problem with brightness up, but every time I try to lower it, screen switches off instantly. To turn it back on I have to use brightness up keyboard shortcut. I know that brightness actually lowers because after switching screen back on (with brightness up key) screen is dimmed by one step (5%).
I’ve been distro hopping in last few days so I know this exact same problem also exist in other distros - Linux Mint 20.1 (5.12.9 kernel), MX 19.4 and openSUSE tumbleweed.
some system info:
inxi -Fxz
  Kernel: 5.12.9-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
  Desktop: KDE Plasma 5.22.0 Distro: EndeavourOS base: Arch Linux
  Type: Laptop System: LENOVO product: 81YQ v: IdeaPad 5 15ARE05
  serial: <filter>
  Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <filter> UEFI: LENOVO
  v: E7CN40WW date: 01/29/2021
Battery:
  ID-1: BAT0 charge: 38.4 Wh (60.3%) condition: 63.7/70.0 Wh (90.9%) volts: 15.8
  min: 15.2 model: Celxpert L19C4PF1 status: Unknown
  Info: 8-Core model: AMD Ryzen 7 4800U with Radeon Graphics bits: 64
  type: MT MCP arch: Zen 2 rev: 1 cache: L2: 4 MiB
  flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 57518
  Speed: 1397 MHz min/max: 1400/1800 MHz boost: enabled Core speeds (MHz):
  1: 1397 2: 1572 3: 1397 4: 1396 5: 1397 6: 1397 7: 1479 8: 1397 9: 1397
  10: 1397 11: 1397 12: 1649 13: 1464 14: 1698 15: 1397 16: 1397
  Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 03:00.0
  Device-2: Syntek Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:3
  Display: x11 server: X.org 1.20.11 driver: loaded: amdgpu,ati
  unloaded: fbdev,modesetting,vesa resolution: <missing: xdpyinfo>
  Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 03:00.1
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
  driver: N/A bus-ID: 03:00.5
  Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
  v: kernel bus-ID: 03:00.6
  Sound Server-1: ALSA v: k5.12.9-arch1-1 running: yes
  Sound Server-2: JACK v: 0.125.0 running: no
  Sound Server-3: PulseAudio v: 14.2 running: yes
  Sound Server-4: PipeWire v: 0.3.30 running: no
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 01:00.0
Bluetooth:
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-3:2
  Report: This feature requires one of these tools: hciconfig/bt-adapter
  Local Storage: total: 476.94 GiB used: 6.98 GiB (1.5%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L2 size: 476.94 GiB
  ID-1: / size: 210.15 GiB used: 6.89 GiB (3.3%) fs: ext4 dev: /dev/nvme0n1p6
  ID-2: /boot/efi size: 96 MiB used: 94.1 MiB (98.0%) fs: vfat
  dev: /dev/nvme0n1p1
  ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%)
  dev: /dev/nvme0n1p7
  System Temperatures: cpu: 72.1 C mobo: N/A gpu: amdgpu temp: 44.0 C
  Fan Speeds (RPM): N/A
  Processes: 323 Uptime: 1h 40m Memory: 15.06 GiB used: 2.94 GiB (19.5%)
  Init: systemd Compilers: gcc: 11.1.0 Packages: 936 Shell: Bash v: 5.1.8
  inxi: 3.3.03
and journalctl after sleep, wake up and adjusting brightness:
journalctl --since "3 minutes ago"
-- Journal begins at Wed 2021-06-09 19:36:13 BST, ends at Thu 2021-06-10 00:41:22 BST. --
Jun 10 00:38:46 eldresso-eos plasmashell[1107]: libkcups: Create-Printer-Subscriptions last error: 1282 BƂędny deskryptor pliku
Jun 10 00:38:46 eldresso-eos plasmashell[1107]: libkcups: Request failed 1282 -1
Jun 10 00:38:53 eldresso-eos kwin_x11[1024]: kwin_core: XCB error: 152 (BadDamage), sequence: 27154, resource id: 14711793, major code: 143 (DAMAGE), minor code: 2 (Destroy)
Jun 10 00:39:48 eldresso-eos systemd-logind[527]: Lid closed.
Jun 10 00:39:48 eldresso-eos NetworkManager[512]: <info>  [1623281988.8285] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Jun 10 00:39:48 eldresso-eos kded5[1020]: bluedevil: About to suspend
Jun 10 00:39:48 eldresso-eos NetworkManager[512]: <info>  [1623281988.8287] device (p2p-dev-wlan0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Jun 10 00:39:48 eldresso-eos NetworkManager[512]: <info>  [1623281988.8292] manager: NetworkManager state is now ASLEEP
Jun 10 00:39:48 eldresso-eos NetworkManager[512]: <info>  [1623281988.8293] device (wlan0): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Jun 10 00:39:48 eldresso-eos kded5[1020]: plasma-nm: Unhandled active connection state change:  3
Jun 10 00:39:48 eldresso-eos dbus-daemon[509]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=512 comm="/usr/bin/NetworkMan>
Jun 10 00:39:48 eldresso-eos systemd[1]: Starting Network Manager Script Dispatcher Service...
Jun 10 00:39:48 eldresso-eos dbus-daemon[509]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 00:39:48 eldresso-eos systemd[1]: Started Network Manager Script Dispatcher Service.
Jun 10 00:39:48 eldresso-eos audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 10 00:39:48 eldresso-eos kernel: audit: type=1130 audit(1623281988.838:99): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? r>
Jun 10 00:39:48 eldresso-eos kernel: wlan0: deauthenticating from 18:35:d1:a2:8e:e1 by local choice (Reason: 3=DEAUTH_LEAVING)
Jun 10 00:39:48 eldresso-eos wpa_supplicant[887]: wlan0: CTRL-EVENT-DISCONNECTED bssid=18:35:d1:a2:8e:e1 reason=3 locally_generated=1
Jun 10 00:39:48 eldresso-eos NetworkManager[512]: <info>  [1623281988.9758] device (wlan0): supplicant interface state: completed -> disconnected
Jun 10 00:39:48 eldresso-eos NetworkManager[512]: <info>  [1623281988.9759] device (wlan0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Jun 10 00:39:48 eldresso-eos avahi-daemon[508]: Withdrawing address record for fe80::a3b4:18d3:dc25:d891 on wlan0.
Jun 10 00:39:48 eldresso-eos avahi-daemon[508]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::a3b4:18d3:dc25:d891.
Jun 10 00:39:48 eldresso-eos avahi-daemon[508]: Interface wlan0.IPv6 no longer relevant for mDNS.
Jun 10 00:39:48 eldresso-eos NetworkManager[512]: <info>  [1623281988.9912] dhcp4 (wlan0): canceled DHCP transaction
Jun 10 00:39:48 eldresso-eos NetworkManager[512]: <info>  [1623281988.9912] dhcp4 (wlan0): state changed bound -> terminated
Jun 10 00:39:48 eldresso-eos avahi-daemon[508]: Interface wlan0.IPv4 no longer relevant for mDNS.
Jun 10 00:39:48 eldresso-eos avahi-daemon[508]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.0.16.
Jun 10 00:39:48 eldresso-eos avahi-daemon[508]: Withdrawing address record for 192.168.0.16 on wlan0.
Jun 10 00:39:48 eldresso-eos NetworkManager[512]: <info>  [1623281988.9938] device (wlan0): set-hw-addr: set MAC address to 3A:83:BD:8E:3A:9B (scanning)
Jun 10 00:39:48 eldresso-eos avahi-daemon[508]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.0.16.
Jun 10 00:39:48 eldresso-eos avahi-daemon[508]: New relevant interface wlan0.IPv4 for mDNS.
Jun 10 00:39:48 eldresso-eos avahi-daemon[508]: Registering new address record for 192.168.0.16 on wlan0.IPv4.
Jun 10 00:39:49 eldresso-eos NetworkManager[512]: <info>  [1623281989.0020] device (wlan0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Jun 10 00:39:49 eldresso-eos NetworkManager[512]: <info>  [1623281989.0039] device (wlan0): set-hw-addr: reset MAC address to A8:7E:EA:00:5C:DF (unmanage)
Jun 10 00:39:49 eldresso-eos systemd[1]: Reached target Sleep.
Jun 10 00:39:49 eldresso-eos systemd[1]: Starting Suspend...
Jun 10 00:39:49 eldresso-eos kded5[1020]: plasma-nm: Not emitting connection deactivated notification as we're about to suspend
Jun 10 00:39:49 eldresso-eos kded5[1020]: plasma-nm: Network connectivity limited, scheduling notification
Jun 10 00:39:49 eldresso-eos wpa_supplicant[887]: nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0
Jun 10 00:39:49 eldresso-eos wpa_supplicant[887]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Jun 10 00:39:49 eldresso-eos systemd-sleep[105086]: Suspending system...
Jun 10 00:39:49 eldresso-eos kernel: PM: suspend entry (deep)
Jun 10 00:39:49 eldresso-eos PackageKit[1225]: get-updates transaction /19_aecbccdd from uid 1000 finished with success after 184ms
Jun 10 00:40:15 eldresso-eos kernel: Filesystems sync: 0.008 seconds
Jun 10 00:40:15 eldresso-eos kernel: Freezing user space processes ... (elapsed 0.002 seconds) done.
Jun 10 00:40:15 eldresso-eos kernel: OOM killer disabled.
Jun 10 00:40:15 eldresso-eos kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
There are currently a number of issues with kernel 5.12. Try linux-lts (5.10) and see if that helps.
Just tried it. Unfortunately it haven’t fixed my problem
Hello, @eldresso! I had symilar problem on my laptop.
Check output of this command in terminal:
systemctl --failed
If you get something like
● systemd-backlight@backlight:acpi_video0.service loaded failed failed Load/Save Screen Backlight Brightness of backlight:acpi_video0
go to this topic to find solution:
Just to note we never actually resolved the problem.
@aleksmn I went throught the topic you linked. TL;DR still haven’t found fix
long version
no changes to acpi_backlight
works before sleep, problems after wake up
$ systemctl --failed
  UNIT                                            LOAD   ACTIVE SUB    DESCRIPTION
LOAD   = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB    = The low-level unit activation state, values depend on unit type.
1 loaded units listed.
$ systemctl status systemd-backlight@backlight:acpi_video0.service
× systemd-backlight@backlight:acpi_video0.service - Load/Save Screen Backlight Brightness of backlight:acpi_video0
     Loaded: loaded (/usr/lib/systemd/system/systemd-backlight@.service; static)
     Active: failed (Result: exit-code) since Thu 2021-06-10 12:12:53 BST; 57s ago
       Docs: man:systemd-backlight@.service(8)
    Process: 866 ExecStart=/usr/lib/systemd/systemd-backlight load backlight:acpi_video0 (code=exited, status=1/FAILURE)
   Main PID: 866 (code=exited, status=1/FAILURE)
        CPU: 4ms
Jun 10 12:12:53 eldresso-eos systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:acpi_video0...
Jun 10 12:12:53 eldresso-eos systemd-backlight[866]: Failed to get backlight or LED device 'backlight:acpi_video0': No such device
Jun 10 12:12:53 eldresso-eos systemd[1]: systemd-backlight@backlight:acpi_video0.service: Main process exited, code=exited, status=1/FAILURE
Jun 10 12:12:53 eldresso-eos systemd[1]: systemd-backlight@backlight:acpi_video0.service: Failed with result 'exit-code'.
Jun 10 12:12:53 eldresso-eos systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:acpi_video0.
acpi_backlight=video
same behaviour as default
0 loaded units listed.
● systemd-backlight@backlight:acpi_video0.service - Load/Save Screen Backlight Brightness of backlight:acpi_video0
     Active: active (exited) since Thu 2021-06-10 11:46:28 BST; 3min 27s ago
    Process: 891 ExecStart=/usr/lib/systemd/systemd-backlight load backlight:acpi_video0 (code=exited, status=0/SUCCESS)
   Main PID: 891 (code=exited, status=0/SUCCESS)
        CPU: 3ms
acpi_backlight=vendor
brightness control doesn’t work at all
○ systemd-backlight@backlight:acpi_video0.service - Load/Save Screen Backlight Brightness of backlight:acpi_video0
     Active: inactive (dead)
acpi_backlight=native
I’ve got :arrow_double_down: machine:
inxi -MCGz
Machine:   Type: Laptop System: LENOVO product: 82A2 v: Yoga Slim 7 14ARE05 serial: <filter>
           Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter> UEFI: LENOVO v: DMCN38WW date: 01/18/2020
CPU:       Info: 8-Core model: AMD Ryzen 7 4800U with Radeon Graphics bits: 64 type: MT MCP cache: L2: 4 MiB
           Speed: 1397 MHz min/max: 1400/1800 MHz Core speeds (MHz): 1: 1397 2: 1397 3: 1397 4: 1397 5: 1397 6: 1397 7: 1397
           8: 2283 9: 1381 10: 1397 11: 1293 12: 1397 13: 1397 14: 1364 15: 1397 16: 1397
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Renoir driver: amdgpu v: kernel
           Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
           Display: wayland server: X.org 1.20.11 driver: loaded: amdgpu,ati unloaded: fbdev,modesetting,vesa
and the two services in charge of screen and keyboard backlight seem to be:
systemd-backlight@backlight:amdgpu_bl0.service
systemd-backlight@leds:platform::kbd_backlight.service
$ systemctl status systemd-backlight@backlight:amdgpu_bl0.service
● systemd-backlight@backlight:amdgpu_bl0.service - Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0
Active: active (exited) since Thu 2021-06-10 08:48:03 CEST; 6h ago
Process: 972 ExecStart=/usr/lib/systemd/systemd-backlight load backlight:amdgpu_bl0 (code=exited, status=0/SUCCESS)
Main PID: 972 (code=exited, status=0/SUCCESS)
CPU: 7ms
$ systemctl status systemd-backlight@leds:platform::kbd_backlight.service
● systemd-backlight@leds:platform::kbd_backlight.service - Load/Save Screen Backlight Brightness of leds:platform::kbd_backlight
Active: active (exited) since Thu 2021-06-10 08:48:02 CEST; 5h 57min ago
Process: 728 ExecStart=/usr/lib/systemd/systemd-backlight load leds:platform::kbd_backlight (code=exited, status=0/SUCCESS)
Main PID: 728 (code=exited, status=0/SUCCESS)
CPU: 6ms
I have disabled
and things seem to be running fine.
Perhaps something you might want to investigate further.
Sorry to hear, this is obviously not easy to fix problem
 For me ‘acpi_backlight=video’ was enough.
@pebcak I have been searching for solution and found this
then found your reply here.
So i followed it
$ ls /sys/class/backlight
amdgpu_bl0
I disabled/masked acpi_video0.service systemctl mask systemd-backlight@backlight:acpi_video0.service and rebooted.
I got rid of error that was showing after systemctl --failed, but it didn’t fix my issue, even that systemctl status systemd-backlight@backlight:acpi_video0.service gives me no errors
     Active: active (exited) since Thu 2021-06-10 14:25:37 BST; 16min ago
    Process: 2762 ExecStart=/usr/lib/systemd/systemd-backlight load backlight:amdgpu_bl0 (code=exited, status=0/SUCCESS)
   Main PID: 2762 (code=exited, status=0/SUCCESS)
        CPU: 7ms
Jun 10 14:25:37 eldresso-eos systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0...
Jun 10 14:25:37 eldresso-eos systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0.
edit:
only backlight services I have running are systemd-backlight@backlight:amdgpu_bl0.service and system-systemd\x2dbacklight.slice
Keyboard backlight works fine
edit2:
should I try changing grub options with amdgpu_bl0 like I did with acpi_video0 or it doesn’t work this way?
I am afraid I would’nt know that. I haven’t had to do any of the kernel boot parameters stuff. You could have a look at the following passage from Archwiki and see if it is related to you you issue somehow:
https://wiki.archlinux.org/title/Backlight#Backlight_is_always_at_full_brightness_after_a_reboot_with_amdgpu_driver
