Does it also work on integrated with optimus?
Yes, now it’s working on the three modes (integrated, nvidia, hybrid) as expected, able to control brightness and also a resolution issue I faced seem to been fixed by this.
The culprit was with using discrete graphics in uefi settings.
/usr/share/X11/xorg.conf.d
these are droplet configs and you simply can add the 10-nvidia.conf there and put in the conifgs you want to change so they do not need a full xorg.conf file only the parts to be changed…
But I am not sure if these options are xorg options? they may need to be added as kernel parameter or module options…
seems both possible…
Xorg:
Section "Device"
Identifier "NVIDIA Card"
VendorName "NVIDIA Corporation"
Driver "nvidia"
Option "RegistryDwords" "EnableBrightnessControl=1"
EndSection
or as a kernel parameter:
nvidia.NVreg_RegistryDwords=EnableBrightnessControl=1
https://wiki.archlinux.org/title/NVIDIA#Enabling_brightness_control
I think the issue was just with me using, discrete graphics in uefi settings for a hybrid graphics card, as I said above. after changing it to discrete and download optimus-manager, everything is working fine in all three modes. I don’t want to break it again changing uefi again to discrete graphics, to try out this xorg approach. ![]()
yea if it works it works no need to break your system ![]()
