Brave Browser and VSCode take long to load
I use eos booting from flash drive, to be able to use the same system on my pc and laptop. When on the laptop though, the brave browser takes up to around 10 secs to load.
Tested on Gnome and Xfce (btw. laptop being not powerful enough is NOT the problem).
The same happens when opening VS Code on the laptop too. Firefox works fine on both devices.
Any ideas why this occurs and how to fix it?
Can we see an inxi -Fxxxz from both machines?
it might have something to do with electron, vscode uses electron31 now?
Currently I can provide only the output from my laptop:
  Kernel: 6.10.2-arch1-2 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: tsc
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: LENOVO product: 82NC v: Yoga Slim 7 Pro 14IHU5
    serial: <superuser required> Chassis: type: 10 v: Yoga Slim 7 Pro 14IHU5
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76463 WIN
    serial: <superuser required> part-nu: LENOVO_MT_82NC_BU_idea_FM_Yoga Slim 7
    Pro 14IHU5 uuid: <superuser required> UEFI: LENOVO v: FJCN69WW
    date: 03/21/2022
Battery:
  ID-1: BAT1 charge: 47.7 Wh (85.9%) condition: 55.5/61.0 Wh (91.0%)
    power: 8.2 W volts: 16.6 min: 15.4 model: Sunwoda L19D4PH3 type: Li-poly
    serial: <filter> status: discharging
  Info: quad core model: 11th Gen Intel Core i5-11320H bits: 64 type: MT MCP
    smt: enabled arch: Tiger Lake rev: 2 cache: L1: 320 KiB L2: 5 MiB L3: 8 MiB
  Speed (MHz): avg: 441 high: 731 min/max: 400/4500 cores: 1: 400 2: 731
    3: 400 4: 400 5: 400 6: 400 7: 400 8: 400 bogomips: 51008
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
    driver: i915 v: kernel arch: Gen-12.1 ports: active: eDP-1
    empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0 chip-ID: 8086:9a49
    class-ID: 0300
  Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 bus-ID: 3-1:2 chip-ID: 04f2:b6cb class-ID: fe01
    serial: <filter>
  Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver:
    X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 2240x1400 s-dpi: 96 s-size: 592x370mm (23.31x14.57")
    s-diag: 698mm (27.48")
  Monitor-1: eDP-1 model: AU Optronics 0x2698 res: 2240x1400 hz: 60 dpi: 190
    size: 300x188mm (11.81x7.4") diag: 354mm (13.9") modes: 2240x1400
  API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.5-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
    device-ID: 8086:9a49
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
    driver: sof-audio-pci-intel-tgl bus-ID: 00:1f.3 chip-ID: 8086:a0c8
    class-ID: 0401
  API: ALSA v: k6.10.2-arch1-2 status: kernel-api
  Server-2: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
    chip-ID: 8086:a0f0 class-ID: 0280
Bluetooth:
  Device-1: Intel AX201 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 bus-ID: 3-10:4 chip-ID: 8087:0026 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 4 state: down bt-service: disabled
  Local Storage: total: 1.16 TiB used: 15.07 GiB (1.3%)
  ID-1: /dev/nvme0n1 vendor: SK Hynix model: HFS001TDE9X084N
    size: 953.87 GiB speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter>
    fw-rev: 41010C22 temp: 40.9 C scheme: GPT
  ID-2: /dev/sda vendor: Samsung model: Flash Drive FIT size: 239.02 GiB
    type: USB rev: 3.1 spd: 5 Gb/s lanes: 1 tech: SSD serial: <filter>
    fw-rev: 1100 scheme: GPT
  ID-1: / size: 219.04 GiB used: 15.07 GiB (6.9%) fs: ext4 dev: /dev/sda3
  ID-2: /boot/efi size: 511 MiB used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1
  ID-1: swap-1 type: partition size: 14.9 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda2
  System Temperatures: cpu: 37.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 16 GiB note: est. available: 15.41 GiB used: 1.81 GiB (11.7%)
  Processes: 288 Power: uptime: 5m states: freeze,mem,disk suspend: s2idle
    wakeups: 0 hibernate: platform Init: systemd v: 256 default: graphical
  Packages: pm: pacman pkgs: 930 Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9
    running-in: kitty inxi: 3.3.35
Try running brave from the terminal and see if there is any output there.
I’ve been just writing it to EDIT of mu original post…
Here it is:
[2703:11:0807/170851.153396:ERROR:native_extension_bindings_system.cc(613)] Failed to create API on Chrome object.
[2703:11:0807/170851.155060:ERROR:native_extension_bindings_system.cc(613)] Failed to create API on Chrome object.
[2703:11:0807/170851.155624:ERROR:native_extension_bindings_system.cc(613)] Failed to create API on Chrome object.
[2703:11:0807/170851.156176:ERROR:native_extension_bindings_system.cc(613)] Failed to create API on Chrome object.
[2703:11:0807/170851.156854:ERROR:native_extension_bindings_system.cc(613)] Failed to create API on Chrome object.
[2703:11:0807/170851.157535:ERROR:native_extension_bindings_system.cc(613)] Failed to create API on Chrome object.
[2703:11:0807/170851.158287:ERROR:native_extension_bindings_system.cc(613)] Failed to create API on Chrome object.
[2703:11:0807/170851.159117:ERROR:native_extension_bindings_system.cc(613)] Failed to create API on Chrome object.
[2703:11:0807/170851.159932:ERROR:native_extension_bindings_system.cc(613)] Failed to create API on Chrome object.
[2703:11:0807/170851.160466:ERROR:native_extension_bindings_system.cc(613)] Failed to create API on Chrome object.
[2703:11:0807/170851.161213:ERROR:native_extension_bindings_system.cc(613)] Failed to create API on Chrome object.
[2703:11:0807/170851.162007:ERROR:native_extension_bindings_system.cc(613)] Failed to create API on Chrome object.
[2703:11:0807/170851.162488:ERROR:native_extension_bindings_system.cc(613)] Failed to create API on Chrome object.
[2703:11:0807/170851.163234:ERROR:native_extension_bindings_system.cc(613)] Failed to create API on Chrome object.
[2703:11:0807/170851.164244:ERROR:native_extension_bindings_system.cc(613)] Failed to create API on Chrome object.
[2703:11:0807/170851.165096:ERROR:native_extension_bindings_system.cc(613)] Failed to create API on Chrome object.
[2703:11:0807/170851.165566:ERROR:native_extension_bindings_system.cc(613)] Failed to create API on Chrome object.
[2703:11:0807/170851.166269:ERROR:native_extension_bindings_system.cc(613)] Failed to create API on Chrome object.
btw. when running VSCode (which behaves the same way as Brave does) from terminal, there is no output. Based on what I’ve found on the web, I have also tried running code --disable-gpu, which hasn’t solved the problem.
Solution here:
https://forum.endeavouros.com/t/how-to-set-up-system-wide-variable-on-log-in-to-fix-slow-launch-of-chromium-based-apps-on-non-nvidia-devices/59259/5?u=misam
