One easy solution is to create directory called wine on your ssd and then create symbolic link into the wine folder with the ln -s
command.
So how do symbolic links actually work ?
I am guessing this will so direct wineprefix to the SSD drive as well ?
I printed out the guide done by @keybreak Linux gaming [Guide]
21 pages 0-o but tbh the other guides I see online are so confusing and contradictory as you have the C drive…then wineprefix then someone says there the same… I don’t want to break anything more XD
@Auron111, on top of that ntfs comes from windows and there are some forbidden characters like *"?<>
and filenames like CON
PRT
. Linux has only one forbidden character /
edit: forbidden means they cannot be user in the name of the file or folder.
I don’t remember exactly how the paths are but for example lets say your ssd is mounted at /ssd
and the wine path is ~/.wine/C_Drive
You can do this:
mkdir /ssd/wine
ln -s /ssd/wine ~/.wine/C_Drive/ssd
Once you do that anything you put in ~/.wine/C_Drive/ssd
will really be stored on your SSD.
Basically, the same directory can be connected in the filesystem in more than one place.
I would say it is not exactly like that. Wine creates a directory ~/.wine
. Not a drive. Linux does not operate with the concept of drives like windows (c:, d:, …).
Under this directory you can find all configs for that one wine prefix and additional libraries.
You can specify a different path for wine with WINEPREFIX
shell variable - e.g. WINEPREFIX=/ssd winecfg
will create a new wine structure in /ssd
directory. If you do it you will have to always define WINEPREFIX like when running any wine software - e.g. WINEPREFIX=/ssd wine virus.exe
. Or put export WINEPREFIX=/ssd
in your .bashrc if you use only one prefix.
This is very handy if you have multiple instances of wine each for a different software (32 vs 64-bit, different directx, different dlls).
Since linux works with directories and not drives you do not have to install software in the ~/.wine/drive_c
but you can chose a totaly different location - e.g. /ssd/games/
. Usually root /
is listed under wine as drive z:
if you are looking at the paths directly from running windows application (so z:/ssd/games
). But you can run anything like WINEPREFIX=/ssd/games/.wine wine /ssd/games/not_in_wine/virus.exe
It is just more practical to have everything installed under wine’s ~/.wine
(or other WINEPREFIX) when you need to do a cleanup.
Also for a security reason I usually disable drive z:
. I do not want windows software access any file outside its dedicated ~/.wine
directory (probably a weak security attempt but why tempt the fate ).
Did I make it confusing enough?
@vlkon Very confusing
Since I will be using Lutris to install my games, it installs a new wineprefix (I think) for each game I install in /home/[user]/Games/ …can’t I just change an option in Lutris to install them in my SSD to ?
What you say makes sense. I’m just finding this out using wine (play on linux variant). Drives and Directories can be confusing, it had me going for a while! I think I’ve got them sussed now and things are working together. I prefer the Unix way of things, it makes more sense to me but now I have Photoshop as well as Gimp so I am happy with both. Don’t get me started on one vs the other, they are both good.
