One of my machines booted and stopped at the ram disk loading screen.
Is this a grub issue?
If so, the instructions say
Ensure that you are booting the ISO via UEFI mode.
Best of my knowledge none of them are efi installs.
So question is the new live iso has no uefi boot option in the menu
If this is grub issue, how do I do normal grub fix from terminal in live usb the proper way so nothing
gets further messed up?
Regardless of what the problem is, I need help resolving it.
I assume you just boot on the live ISO and arch-chroot and try running the update first. If that doesn’t work then try reinstalling grub and update grub. If the system is Bios and not UEFI it will boot in Bios mode.
