Booting problem in dualboot
I am new to Arch. I am using Endeavour and Windows 11 in dualboot. My DE is GNOME, but I decided to switch to KDE, so I installed plasma and so on. I successfully switched and changed some settings regarding virtual desktops and then shortcuts. After that my mouse buttons froze or something so I restarted my pc.
It only boot BIOS for some reason and even after i exit it or exit with saving changes (even if I do or dont do anything) it turns off my pc then it start without me doing something.
When I hold power button longer to turn it off and then turn on again, still boot only BIOS. I couldnt even boot Windows until I didnt enable secure boot, but that ofc does not allow me boot Linux.
Any idea what can I do about this or what causes the problem?
:eye: The latest grub package update needs some manual intervention
Welcome to EnOS community!
:enos: :handshake:t5:
If following that information does not work for you, post information about your setup - disk info, and inxi -Faz results for instance. Probably as indicated by the above message, though…
Welcome to the forum @arcanebuchta :enos_flag: :partying_face::tada:
This would still be the wrong forum-thread for that…
The correct one:
@moderators
I see. Is there any way how to reinstall grub if I cant get to the Endeavour? Or I have to reinstall the OS and then install grup?
Yes. You need to use your EnOS’ Live USB and follow the instructions given in the link in my previous post.
I’ll try thank you :slight_smile:
